Make Candles at Home Without Wax From Common Household Materials - Easy, Quick, Minimalist
107,381
69
24
About: Focusing on DIY and self-sufficiency, our goal is to provide how-to information, ranging from cooking to construction and machining to micro-controllers - anything within our ability. We are generalists in...
How to make candles at home from scratch with lard or vegetable shortening, glass jars and yarn - without wax! Making jar candles is easy. They're low cost, odorless, long burning and perfect for emergency or blackout. With patterned jars, they cast an attractive light. The use of vegetable shortening such as Crisco makes the candles vegetarian/vegan.
If burning for a long time, a layer of molten fat might develop on the surface near the wick. When extinguishing, check that the wick is vertical as the fat resets. This makes it easier to relight. Also, maintain the wick as one would with a regular candle. Trim it if there is an accumulation of charred thread.
Burning Questions Contest
Grand Prize in the
    • Arduino Contest 2019
    • Tape Contest
      Tape Contest
    • Trash to Treasure
      Trash to Treasure
    24 Discussions
    Yachtwitchway
    2 years ago
    Hi I made 2 small candles using Crisco vegetable shortening and it worked ok however at room temperature they became very soft and couldn't be handled (I live in the caribbean). I made them without the jars, wanted just the candles alone. Looked fabulous, smelled great but wouldn't reccommend making them unless in fireproof pot!!
    AdeldorYachtwitchway
    Reply 2 years ago
    Hi! Vegetable shortening and lard candles both must be made in jars as shown (or other fireproof containers)! These fats are too soft to make free-standing candles. In the jars they work very well. Without containers they'll be messy at best, and a fire hazard at worst.
    CaitlinP5
    3 years ago
    Hi i made a bunch of candles with this method and the video i watched said to freeze them.. now they are settled and look great but are not firm and have melted into liquid on the top. Did i do something wrong or is there a way to fix this?
    AdeldorCaitlinP5
    Reply 3 years ago
    Hi! Are you saying they're liquid at room temperature? If so, then the fat you're using is too thin. It might be soft, but should be solid at room temperature. When the wick is burning, there will be a liquid layer above the solid fat - melted by the flame. Once the candle is extinguished, the fat should resolidify as it cools. Of course, we're assuming your room temperature is not really high!
    synchrotinaAdeldor
    Reply 2 years ago
    I am also finding that they are 'soft' at room temperatures. Is that just the quality of using vegetable shortening? Or does someone have a 'trick' to make them firm like regular was candles??
    Adeldorsynchrotina
    Reply 2 years ago
    We're guessing the consistency of the fat being used varies. If it's soft when in its container/wrapping at room temperature (before making the candles), it'll be the same afterwards.
    CaitlinP5Adeldor
    Reply 3 years ago
    At room temperature and never lit before about half has a liquid layer on top while the others are very soft. Im very upset because they look great so i wanted to sell them but now im unable to :/
    ArielE5
    3 years ago
    Hi! So I made the candle using vegetable shortening and it worked likes dream! The only concerni have is the possibility of causing a grease fire with this type of candle. Do you know if these candles get hot enough to become a grease fire hazard? Thank you!!
    AdeldorArielE5
    Reply 3 years ago
    Hi! We've never seen the grease/fat burn from anywhere but the wick, but like any candle, these can be a fire hazard if mishandled/misused. Don't put them near anything flammable, don't let them tip over, and make sure there's a free flow of air above them. Beware children and pets. Treat them with caution, as you would any burning object.
    Most food coloring is water pasted, so it will not mix well with the oily/fatty melted candle. The cheapest route would probably be to mix in crayons or certain kinds of makeup.
    Hi Casie,
    We haven't tried coloring them, so we don't have a direct answer. This is just a guess: if food coloring doesn't work, perhaps melted wax crayons might(?)
    Nikki1763
    4 years ago on Introduction
    Hi Cassie,
    I've just made 5 large candles using this method , I added green, orange and yellow food colouring and the colours have come out a soft pastel shade , really lovely. I have also added essential oil , although not sure we can smell anything yet , I'll keep you posted on that one
    britha.zhu
    Why do people use wax if something so much easier to obtained can be used to make candles? Are there any cons of using vegetable shortening?
    Adeldorbritha.zhu
    Reply 4 years ago on Introduction
    Hi Britha,
    The fats used in these jar candles are not suitable for making free standing candles as they are softer than paraffin wax (or beeswax, but that is expensive). Some sort of container is required, unlike "standard" commercial candles.
    Hi Mandie,
    The shelf life is the same as that of the fat used - plus more since the fat won't be eaten. We have had some such candles sitting for a year. There has been neither degradation in function nor bad smell. Hope this helps!
