How to Make Clear Stickers - DIY Transparent Labels
7,078
13
About: Mix of original & cool videos: Life-hacks, DIY, Mechanics & Tools, Cooking tips, Crafts ideas and much more!
Clear labels are quite pricy but it's possible to make your own at home using packing tape. It’s a really cool, inexpensive and simple DIY image transfer technique. I used black and white but it does work with color also. It can be used just like a clear sticker, with your own custom designs for pantry jars, spice containers, gift tags, on glass, plastic and wood.
Steps (Watch the video for easy and clear steps):
1- Print your image with a laser printer (Take into consideration the width of the tape).
2- Cover the image completely with clear packing tape (The heavier duty tape give much better results than thin tape).
3- Press down with the back of a spoon so that the tape adheres to the image. It will also eliminate bumps and bubbles.
4- Cut along the edge of the printed area and trim away any excess.
5- Soak in water for 5 minutes (The bigger your sticker is, the longer it’ll need to soak).
6- Remove the paper from the tape by rubbing on it. The image is left behind on the tape.
7- Let the tape dry completely so that the stickiness returns.
8- Attach the tape sticker to anything you would use a normal sticker on.
Subscribe to Fixitsamo:https://www.youtube.com/subscription_center?add_user=fixitsamo
All Videos Here:http://www.youtube.com/user/fixitsamo/videos
Follow us on:
Instagram: https://www.instagram.com/fixitsamo
Facebook: https://www.instagram.com/fixitsamo
Pinterest: https://www.instagram.com/fixitsamo
Tumblr: https://www.instagram.com/fixitsamo
Google+: google.com/+fixitsamo
Always happy to hear from you! Your comments, shares and all other interactions are very welcome. Thanks for watching!
Supplies:
    • Arduino Contest 2019
    • Classroom Science Contest
    • IoT Challenge
      IoT Challenge
    Suhey
    Question 1 year ago
    Can this be made with a inkjet printer ? Or has to be laser ? Thanks
