How to Make Easy No Bake White Chocolate & Cranberry Tiffin
3,901
50
8
About: Helping you create great food with easy to follow step by step recipes. Check out www.kitchenmason.com for more marvelous ideas!
I’m kicking off the start off Christmas with this incredibly delightful and suitably festive White Chocolate & Cranberry Tiffin. It’s a little different to the rich, chocolate version I remember begging my Gran to make as a child, but my word – it’s just as heavenly!
Here is what you will need to make this gorgeous Christmassy treat. Makes up to 24 pieces dependent on how large you cut them.
300g Digestive Biscuits140g Unsalted ButterPinch of Salt3 tbsp Golden Syrup1 tbsp Caster Sugar2 tbsp Malted Milk Powder *140g Dried Cranberries500g White ChocolateRed Food Colouring (Optional)
Essential Equipment
30 x 20 Rectangular Cake/Swiss Roll Tin* I used Horlicks but you don’t need to buy a whole tub, just get one of the little ‘1 cup’ sachets that are about 30p – there’s plenty enough in one of those.
Step 1: Making the Biscuit Base
Lightly grease & line your cake tin and set to one side until needed.
Using either a food processor or a rolling pin and a plastic bag, blitz/bash the digestive biscuits until almost fine crumbs – but you want some chunky bits left in for added texture.
Step 2: Making the Biscuit Base
In a medium saucepan, gently heat the butter, salt, golden syrup, caster sugar & milk powder until the butter has melted and the sugar has dissolved.
Pour the liquid over the breadcrumbs in a large bowl and mix until completely coated.
Step 3: Making the Biscuit Base
Throw in the cranberries and give it a good mix. (You may wish to chop them a little first if they are large cranberries as this will help the mixture bond together better with fewer ‘gaps’)
Step 4: Making the Biscuit Base
Press the mixture into the prepared tin then place into the fridge to harden/set for about 45mins to an hour.
Step 5: The White Chocolate Topping
When the mixture has firmed up, we need to smother it in chocolate!
Break the white chocolate into a large bowl. Either in the microwave or set over barely simmering water, gently melt the chocolate until smooth and shiny.
Pour about 3 quarters of it over the tiffin. (Or all of it if you don’t want to do the following decorative step.)
Step 6: To Decorate
With the remaining quarter, add in some red food colouring & mix. Then pour into a piping bag and snip the end.
Step 7: To Decorate
Work quickly as the chocolate will set and the ‘feathering’ technique won’t work unless it is still melted. Pipe stripes diagonally across the tiffin.
Then take a cocktail stick and draw lines through the chocolate. First stoke down, then the next – upwards. Repeat until you have ‘feathered’ the whole thing.
(Yours will likely work better than mine – as I was taking photos, the chocolate was busy setting!)Allow to chill in the fridge for about 45mins to an hour before slicing.
If you want evenly sized pieces, run a sharp knife under hot water before slicing each piece. This will melt through the chocolate preventing it from snapping into random shapes. Store in an airtight container in the fridge and eat within 4 – 5 days.
Step 8: Tadah!
What's not to like?! Gorgeous, smooth white chocolate with the crunchy/chewy biscuit and wonderful bursts of cranberry sweetness in-between to bring it all together. It’s absolutely exquisite!
For more awesome step by step recipes check out www.kitchenmason.com
    • Fat Challenge
      Fat Challenge
    • Jewelry Challenge
      Jewelry Challenge
    • Pie Contest
      Pie Contest
    8 Discussions
    adillbeck
    2 years ago
    I don't think you can get Digestive Biscuits here... What are some alternatives?
    footfixeradillbeck
    Reply 2 years ago
    Vanilla wafers would be a great alternative as well.
    KitchenMasonadillbeck
    Reply 2 years ago
    Adillbeck is right. If you are from the US, graham crackers is probably your best bet I believe.
    adillbeckadillbeck
    Reply 2 years ago
    Hmm, according to the internet, graham crackers seem like a good alternative.
    JPod
    2 years ago
    Sounds wonderful !! This is a recipe that anyone could master right away too. Thank you so much for sharing it. Merry Christmas too !!
