How to Make GRBL + CNC V3 Shield Based Mini CNC Machine From Scrap DVD Drive
73,532
212
32
About: Electrical engineer by profession
This CNC is based on GRBL0.9 Firmware and CNC V3 shield GRBL is Hacked for Z-axis Servo.
CNC Shield & GRBL combinly works very preciselyIt is loaded with very useful functions like Hard limit, Soft limit, Homing, etc
This is about how to make
GRBL+CNCV3 shield+Arduino based CNC machine
This guide include all necessary instruction required
like How to assemble CNC machine
How to Load GRBL to arduino
Inkscape extension installation
GRBL Configuration & G-code streaming
It is loaded with very useful functions like Hard limit, Soft limit, Homing, i will guide you in detail how to Make GRBL Based mini CNC machine at home
Step 1: Watch Video to Know How to Make
Watch this video it will clear you how to make and operate CNC machine
Step 2: Material Required
This are the list of some use full material required
  1. Arduino UNO--------------------------------------QTY- 1
  2. CNC V3 Shield------------------------------------QTY-1
  3. servo motor----------------------------------------QTY-1
  4. A4988 Stepper driver shield--------------------QTY-2
  5. Old scrap DVD Drives---------------------------QTY-2
  6. Some push buttons as limit S/W---------------QTY-2
  7. A acrylic sheet for base
  8. Pen holder (slavege from DVD Drive)
  9. Some wires
  10. Hardware like nut bots etc.
Step 3: Software Required
1. Arduino IDE
GRBL LIBRARY :- Click here to download
2. INKSCAPE
SERVO CONTROL EXTENSION :-Click here to download
3. UNIVERSAL G-CODE SENDER : - Click here to download
Step 4: Machine Assembley
  1. Place X-axis Horizontally on the bolt mounted on acrylic sheet
  2. Four bolt mounted on a metal sheet to fit Y-axis on it
  3. Now place the Pen up down holder on y axis whit the help of A bolt through the center
  4. Now place Y-axis on metal sheet and place it vertically on X-axis
  5. Now fit servo motor so that it will move z-axis which is our pen up and down
  6. Now mount CNC shield on Ardunino
  7. Do wiring A shown in wiring circuit as in Next step
For better understand please watch Video & pic attached here
Step 5: Wiring Diagram
Do wiring as shown here in image
Limit switch are optional
You can use them by changing the GRBL setting as below
$21=0 (hard limits, bool)
to
$21=1 (hard limits, bool)
Step 6: GRBL Loading to Arduino
Link to download GRBL Setup
http://www.mediafire.com/file/c36xny4qw9b7s5k/MI_G...
Download the library file unzip it
and load to arduino
Now go to File>Example>grbl upload compile and upload code to arduino
Note:- delete any previously loaded GRBL library
Step 7: G-CODE Setup in Inkscape
Again we are using here INKSCAPE software to make G-code
As we are using GRBL & CNC Shield for this machine s
o it will not support a servo motor as a Z-Axis
so here some hack by doing so we can able to manage Servo works on Z-axis
you need to add MI Extension here to get it work with Z-axis Servo
Download link http://www.mediafire.com/file/nl4w871suk192x2/MI_...
after download add this files to the
inkscape directory>Share>Extension folder
Now open inkscape set page size 40 x 40mm
draw what you want to plot
select image go to convert to path
then go to extension click on MI GRBL Z-AXIS SERVO CONTORL
Servo up = M3
Servo down = M5
X-axis speed = 2000
Y-axis speed = 2000 S
ervo angle = 90
Delay = 1
Directory = as per you convenient or keep as it is
File name = as per you convenient or keep as it is
Clik on Apply now you G-code is saved @ location you mention
Step 8: GRBL Configuration & Streaming G-code
Download link for Universal Gcode sender
https://www.mediafire.com/?2l16dvqivwgc9el
Open Universal G-code sender (Arduino must stay connected with PC/LAPTOP)
Select COM port
Set Baud rate 115200
clik on "OPEN"
go in "COMMANDS" Tab
enter $$ for GRBL configuration
Example Suppose we want to change the $0(step pulse, usec) value from 10 to 20
so enter in command line $0=20 & hit enter its done
My GRBL SETTING
$0=10 (step pulse, usec)
$1=25 (step idle delay, msec)
$2=0 (step port invert mask:00000000)
$3=0 (dir port invert mask:00000000)
$4=0 (step enable invert, bool)
$5=0 (limit pins invert, bool)
$6=0 (probe pin invert, bool)
$10=3 (status report mask:00000011)
$11=0.010 (junction deviation, mm)
$12=0.002 (arc tolerance, mm)
$13=0 (report inches, bool)
$20=0 (soft limits, bool)
$22=0 (homing cycle, bool)
$23=0 (homing dir invert mask:00000000)
$24=25.000 (homing feed, mm/min)
$25=500.000 (homing seek, mm/min)
$26=250 (homing debounce, msec)
$27=1.000 (homing pull-off, mm)
$100=5.000 (x, step/mm)
$101=5.000 (y, step/mm)
$102=100.000 (z, step/mm)
$110=500.000 (x max rate, mm/min)
$111=500.000 (y max rate, mm/min)
$112=500.000 (z max rate, mm/min)
$120=10.000 (x accel, mm/sec^2)
$121=10.000 (y accel, mm/sec^2)
$122=10.000 (z accel, mm/sec^2)
$130=40.000 (x max travel, mm)
$131=40.000 (y max travel, mm)
$132=200.000 (z max travel, mm)
ok
Now time to stream Gcode to machine go to "FILE MODE" Tab Brows your gcode file and hit enter thats it
youR machine start plotting Hope you like this Comment below if any doubt
3 People Made This Project!
  • Tape Contest
    Tape Contest
  • Arduino Contest 2019
  • Trash to Treasure
    Trash to Treasure
32 Discussions
RomanR59
5 weeks ago
I have a 180x200 mm table. What to do to draw the whole table?
alpinex19
Question 9 months ago on Step 8
Hello. Servo SG90 is controlled by M3 code but angle was not 90º of action. it went to end of limit servo sg90. M5 code didnt work. servo couldnt turned manually when code M3 was active. Servo could turned by hand when M5 code active. What is the problem? can someone help me?
JonatanS10alpinex19
Answer 3 months ago
same problem. Anyone got an answer? M3 and M4 moves same direction to max, but nothing moves it the other way
ПавелБ16alpinex19
Answer 7 months ago
Hi! I have the same problem. Did you find the solution. I use programm GRBL Controller and I added the command M3 S200 the servo turned. Then I entered M5 and servo didn't move ((( I enter M3 S10 and I hear the sound of the motor but it doesn't move.
Does anybody knows what heppens?
ggarcía-2
4 months ago
You forgot Something, You don't mention how to calibrate the Vref on the A4988 Drivers, in order to set the appropriate current that the DVD Servomotors need.
Remember, If you set a lower value than the motors needs, you will loose strength, otherwise if you set a higher value than motors needs, you will overheat the motors, or burn the motors.
Of Course, How many Current this DVD servomotors needs?
NEMA 17 Stepmotors uses 1.7Amps.
Regards
EduardoP138
Question 6 months ago
Buen día gracias por compartir tu proyecto . Me podrás ayudar mi moto es un 28byj-48 pero alconectar solo gira hacia un lado a si de movimiento a la derecha o a la izquierda gira en una solo.direccion
AndreaD20
10 months ago
Hi, thanks for the instructable. One simple question: What's the Vref at the driver for these type of motors, considering that my driver has an R100 resistor? My calculation is 0.24 8*0.1 = 0.192 Volt, but I want to be sure. Thanks!!
AmitV60
Question 10 months ago on Step 7
What will be do if directary show not be exist after apply
slanwar
11 months ago
my stepper motors works fine but not my servo and I tried 2 arduino unos, 2 cnc shield and 3 servos sg90 ( i have another attached to my 3d printer), I have no idea what to do anymore, connecting the servo to the arduino itself works for a bit but because is drawing the 5 v from my computer usb stops after a few movements. I reinstalled the grbl a few times with no luck
ChipStewart
1 year ago
Now the X Axis is doing it! I tried using another arduino and another driver. I guess I've fried the steppers.
ChipStewart
1 year ago
I build one almost exactly like this, then found this Instructable. Only differences were the use of RJ45 jacks for X, Y, & Z axis inputs; and, floppy drive stepper for pen up/down.
Unfortunately, I'm still trying to get it to work. The X axis works beautifully, moving strongly and smoothly. The Z is a little weak, but will probably suffice. The Y axis, however, has been a PITA from the beginning! First, it wouldn't do anything, which I fixed by re-soldering the connection and covering with U-cure glue for strength. Then it would twitch a little, but not really move. I was able to adjust the trimmer on the driver to get it to move. It's weak, but at least moves most of the time.
Only problem is, it only moves in one direction - regardless of whether I press +Y or -Y! I tried another stepper: same result. Switching another A4988 driver board didn't make a difference either. Should I bump up the voltage a little more? I'm at a measured voltage of 12.02V now. If I go higher, will I fry the steppers?
Any ideas why? Any suggestions? I've added pics of the front and back, and a video of X, A, and Y movement.
Thanks
ChipStewart
1 year ago
I made one almost exactly like this one, before seeing this. The physical build went well, using polycarbonate and steel. I used RJ45 jacks to connect the X, Y, and Z axis, so I can switch machines.
The x-axis stepper works great - seems good and strong. The z is okay, after I got it to work. The Y, however, has been giving me a hard time. I finally got it working - kind of. At first it would only twitch. By fiddling with the driver trimmer, I got it to turn. Only problem is, it goes the same direction whether I jog +Y or -Y. I tried switching drivers, switching steppers, moving the cables around on the Y stepper outputs. Still, no change.
Any ideas?
DariusA4
1 year ago
Guys, anyone know why stepper motors become very hot ? thanks
GaetanoEDariusA4
Reply 1 year ago
Attention you must use the tension of 5 Volt for these engines, even if on the shield there is written 12_36 Volt, otherwise they will end up burning
AbishRmostafa12345
Reply 1 year ago
Reduce the laser power while converting the image to gcoded
in inkscape (use J tech Photonic extension)
AdrianR11
1 year ago
Hi! I'm having troubles when I try to use the extension: I got an error and the gcode file is not generated. Please see the attached image for details. I'm using Inkscape 0.92 Thanks!
