How to Make LDR Darkness Sensor Circuit Simple DIY
42,310
15
18
About: Electrical engineer by profession
Hello Friends
In this post we will see how to use LDR to make a Darkness sensor circuit.
Basically a darkness sensor circuit turn on a light in darkness and turn off light in brightness.
Step 1: VIDEO
Watch the video to know full procedure
Step 2: Component Required
1) LDR—–1No. http://amzn.to/2rNr33i
2) 50KOHM RESISTOR———1No.
3) 1KOHM RESISTOR———1No.
4) BC547 TRANSISTOR———1No. http://amzn.to/2rNxpjm
5) 9V BATTERY———1No.
Step 3: Circuit Diagram
Step 4: What Is LDR ?
LDR is a photoresistor is a light-controlled variable resistor.
The resistance of a photoresistor decreases with increasing incident light intensity,
in other words, it exhibits photoconductivity.
A photoresistor can be applied in light-sensitive detector circuits, and light- and dark-activated switching circuits.
Step 5:
A photoresistor is made of a high resistance semiconductor.
In the dark, a photoresistor can have a resistance as high as several megohms (MΩ),
while in the light, a photoresistor can have a resistance as low as a few hundred ohms.
Step 6: BC547 Transistor
BC547 is an NPN bi-polar junction transistor. A transistor, stands for transfer of resistance, is commonly used to amplify current. A small current at its base controls a larger current at collector & emitter terminals.
BC547 is mainly used for amplification and switching purposes. It has a maximum current gain of 800. Its equivalent transistors are BC548 and BC549. data sheet
Step 7: Procedure
Follow the step as shown in the Video
50K ohm resistor one end is connected with Positive (9V) of battery and other end is connected in series with LDR and LDR another point is connected with negative of battery
here in video I have used 2 100Kohm resistor in parallel because i dont have 50K one.
1K OHM resistor one end is connected with Positive (9V) of battery and other end is connected with anode (positive) of LED
Cathode (negative) of LED is Connected with C (collectr) of BC 547 Transistor
Emitter (E) of transistor is connected with the negative of battery
Base (B) is connected Junction point of the 50K resistor & LDR
it is a simple and powerful concept , which uses transistor ( BC 547 NPN) as a switch to switch ON and OFF the LED LIGHT automatically .
It automatically switches ON lights when the light goes below the visible region of our eyes. ( e.g in evening after Sunset ). it automatically switches OFF lights when light fall on it ( e.g in morning ) , by using a sensor called LDR (Light Dependent Resistor) which senses the light just like our eyes.
  • Tape Contest
    Tape Contest
  • Trash to Treasure
    Trash to Treasure
  • Arduino Contest 2019
18 Discussions
Samiksha.
Question 6 months ago
I want to connect a buzzer to the circuit such that when the LED glows the buzzer makes a sound.Where should I connect the buzzer in this circuit?
Omega35Samiksha.
Answer 5 weeks ago
Listen , led as well as buzzer has both positive and negative pins , so in order to make them turn on at the same time just connect positive leg of the buzzer to where the positive leg of led is connected and do same with the negative leg also. You will get it working .
sarims3
4 months ago
can i have the block diagram
Samiksha.
6 months ago
In the components required please mention LED,Breadboard and connecting wires so that people can use it as a list while buying the components.
shivanshnegi241
Question 1 year ago on Step 4
Photoresistor's resistance get lowered when light of adequate freguency strikes on it.But in this circuit photoresistor is in reverse function.Why and how?
1 answer
SwarajN1
Question 9 months ago on Step 7
What is that white one used in which the wires and the resistances are fixed???
1 answer
Crs17SwarajN1
Answer 6 months ago
its called the bread board
SonetP
7 months ago on Step 7
Hi. I need to connect this circuit without the breadboard and it is not working. What do you mean by the junction of resistor and ldr joined to transistor? How would I do this without the board?
NickF126SonetP
Reply 7 months ago
Not sure what you mean by won't work. You can build this circuit without breadboard by soldering components to each others legs. One leg of the 50k resistor, one leg of the ldr and the B or base terminal of transistor all connect together as one solder joint. Other leg of ldr, E or emitter leg of transistor and the negative lead from battery get soldered together as one solder joint. Than positive lead from battery get soldered to one leg of 1k resistor. Other leg of 1k gets soldered to positive side of LED. Negative leg on LED (LED has flat spot on it indicating negative side) gets soldered to C or collector leg on transistor. Hope this helps. Reply if it doesn't and I will build this circuit the way I explained and upload a picture.
SonetPNickF126
Reply 7 months ago
Thank you very much all sorted.
NickF126
Tip 7 months ago
This circuit works on the principal that electricity follows the path of lest resistance. When light is hitting the photoresistor its resistance is lower than that of the base of the transistor, therefore the "electricity" will bypass the transistor and flow through the photoresistor, following the least resistance to ground. When no light hits the photoresistor its resistance is higher than that of the transistors base and the electricity will flow into the base of the transistor activating it to turn on the LED.
shivanshnegi241
Question 1 year ago on Step 7
How do transistor and ldr works in this circuit?
