How to Make Lavender Oil
9,217
188
10
About: http://www.shutterstock.com/g/JLprice3
Time:15 minutes
Ingredients/items:
Lavender leaves and flowers
Grapeseed oil
Mason jar with lid
*I will use my lavender oil for candle scents and other holistic creative creations!
Step 1: Cut
First, cut a handful of lavender leaves and flowers from your plant (s).
Next, cut the lavender with sissors and place in a mason jar. Press the lavender down.
OR
Tie the lavender in a bundle and hang to dry it for a few weeks. Than crush the leaves and flowers into a jar.
Step 2: Oil
Pour the grapeseed oil over the lavender until it is covered.
Last, set the lavender oil in a window or on a shelf for 1-2 weeks. After 2 weeks remove the lavender and put the oil in smaller containers. You can also heat the oil and lavender together for a faster infusion. (see last picture )
*Use within 6 months.
OR
If your using the dry method, it will take 4 to 6 weeks to be absorbed by the carrier oil.
    • Party Challenge
      Party Challenge
    • Gardening Contest
      Gardening Contest
    • IoT Challenge
      IoT Challenge
    10 Discussions
    JodyL19
    1 year ago
    if you do not have Olive oil or grapeseed oil will veggie oil from aldis work?
    Jennprice33bcolautto
    Reply 3 years ago
    I've never used mineral oil before, I've used almond oil, sunflower oil, Olive oil, and grapeseed oil. Each has a different smell when infused with the herbs.....probably depends on what you want to use the oil for. Maybe try a little jar and see how it turns out. I am always experimenting! I use my oils for external holistic remedies and for candle scents.
    Just a public service announcement -- anaerobic (no oxygen) environments that contain water are the perfect breeding ground for botulism, a particularly deadly form of food poisoning, and fresh herbs soaking in oil are exactly that sort of environment!
    So only use this oil for external uses -- never put it in food!
    Jennprice33jjdebenedictis
    Reply 3 years ago
    I've been using fresh and dry herbs to create holistic oils for years and never had a problem with anyone ingesting the oil.....
    Sunglowart
    3 years ago
    Lovely recipe! I always thought you first need to dry the herbs so as to reduce water content. This inceases the shelflife too. But your method is much quicker and fresher!
    Jennprice33Sunglowart
    Reply 3 years ago
    Your right, I have done both methods and the fresh way always turns out better in my opinion. The oil has a stronger smelling. When I use dried lavender it takes 4 to 6 weeks to set up.
    Jennprice33ashleyjlong
    Reply 3 years ago
    Olive oil is very heavy and has a strong smell. The grapeseed oil is a better carrier oil to absorb the lavender smell.
    Thanks. My mom is an aromatherapist and has been making her own calendula oil for a while, but I'm just starting to dabble. Your cinnamon oil and this one are on my list to try!
