How to Make Mini CNC 2D Plotter Using Scrap DVD Drive, L293d Motor Shield & Arduino
106,349
552
49
About: Electrical engineer by profession
this a mini CNC 2D plotter made from old DVD drive and L293D motor shield very cheap but intresting
let see how to make in
Step 1: Video
Step 2: Material Need for This Project
1) 2 X SCRAP DVD DRIVE
2) 1 X ARDUINO
3) 1 X L293D MOTOR SHIELD
4) 1 X SERVO MOTOR (TOWER PRO 9G)
5) JUMPER WIRES
6) SOME HARDWARE NUT BOTS ETC
7) DOUBLE SIDE 3M TAPE
You can buy this material from below links of Amazon
Simple Lab's L293D Motor Shield for Arduino
Arduino Uno R3 ATmega328P ATMEGA16U2 Compatible with USB Cable
REES52 Tower Pro SG90 9g Servo Motor For Arduino ARM Raspberry AND Other MCU
Librairy For Adafruit Shield Driver Motors
extract the file and past them to
arduino/libraries
Step 3: Assembling the Machine
Open the scrap DVD Drive and rremove internal moving tray..
This tray having stepper mechanism on it this will act as our X-axis & Y-axis.
Go through the attached pictures for understanding how to assemble your machine.
make hole on empty DVD drive case mount our X-axis and Y-axis on respective DVD case with the help of
nut bolts.
Now place them perpendicular
Step 4: Wiring Details
watch the picture carefully and wire components accordingly
Step 5: CNC Code for Arduino
upload the code to arduino using arduino IDE
Step 6: G Code
To make gcode files that are compatible with this cnc machine you have to use the Inkscape.
Inkscape is professional quality vector graphics software which runs on Windows, Mac OS X and Linux. It is used by design professionals and hobbyists worldwide, for creating a wide variety of graphics such as illustrations, icons, logos, diagrams, maps and web graphics. Inkscape uses the W3C open standard SVG (Scalable Vector Graphics) as its native format, and is free and open-source software. Download and install Inkscape from
https://inkscape.org/en/download/windows/
(Important: download 0.48.5 version)
Now you need to install an Add-on that enables the export images to gcode files. This add on can be found here with installation notes.
https://github.com/martymcguire/inkscape-unicorn
please follow the video on you tube how to create G-code file
some ready made G-code files
Step 7: Processing IDE Program (GCTRL)
Upload the gctrl file to processing IDE
and click on PLAY button in processing window.
first press 'p' to select you com port
if you want you can set jog speed by pressing 1,2, or 3 button from keyboard
press 'g' to load G-code file
your machine is ready to plot as soon as you hit enter by selecting g code file
now you have done your plotter is ready
thanks for your attention
Step 8: How to Connect Stepper Motor With L293D Shield
6 People Made This Project!
  • Trash to Treasure
    Trash to Treasure
  • Tape Contest
    Tape Contest
  • Arduino Contest 2019
49 Discussions
8_bitGuy
2 years ago
I am using 2 DVD stepper motors, but still, the output is not what I expected it to be.. but the motors which I am using have different pin-out for wires..? does that means they do have different steps/rev..?
The output for STAR is in the picture.
The Gcode for star and elliptical are
config i am using in the code are-
steps/rev = 20; steps/mm(x&y)=360; x=(0:40) y=(0:40)
Help me out !!
RavshanF8_bitGuy
Reply 4 weeks ago
Hello, I’m from Uzbekistan and I’m interested in a typewriter with CNC and created but I have the same problem with drawing a machine like you. wrote about it 2 years ago you found a problem help to solve this problem
Sumit Agrawal
1 year ago
Hi sir I completed this project with the help of your videos but the image can not drawing perfect please help me
ManuelG136Sumit Agrawal
Reply 1 year ago
same Problem Here. It draw but very bad. U cant see what it draw.
HristoBManuelG136
Reply 1 year ago
Same here, I dopped the stepper speeds in the IDE. seems smoother
AnkitS226
2 years ago
i have downloaded the af library but still there is error in <afmotor.h>
please help me out in removing this
ManuelG136
1 year ago
Hi sry for my bad eng. (German)
I rebuild it and its drawing but u cant imagine what it draw. He also want to be in one corner.
I followed your instructables.
I use a Arduino Motorshield.
Powersuply ist 9V battery & 3,6V.
is it possible to wire the motors wrong?
is the code oke for a shield?
Do u have any tips?
Thx
Hsyin_secer
1 year ago
I made it but I have a trouble.I used ardunio mega 2560 and 2xL293d integrated. I haven't adafruit shield.
(* Stepper myStepperX(stepsPerRevolution, 8,9,10,11) *) this step motor not working.
PWM channels 8,9,10,11 dont have voltage.I tried to increase feed voltaje and it didnt work again. Another step motor is working and 2,3,4,5 channels have voltage. What is the problem anybody knows that ?
AmitN39
1 year ago
What is power supply voltage to motor shield??
matelot2
1 year ago
I looked at this because I was curious to know how you connected the two units at 90 degrees from one another.
It was brilliant, one moment they were side by side on the table the next they were fastened to one another. I can't seem to get mine to do that?
m.mohanlalJ
2 years ago
mr.innovative,pls ans my comments posted 2days before,.Again my project of mini is stuck .no further going.pls let me know how to align pen in centre and rectify error message M18 (drives off)
At first it plott on may be 2or3 line correctly then printing every thing in one corner.and at last when it stopped and give message M 18 (drives off)pls give solution.l am tottaly newbie in software
m.mohanlalJ
2 years ago
sir,when I run g code in processing p 3 at the end of run the plotting is all jumble up,and message shows : M18 ( drives off )
Command not recognise : M18
Pls give the solution to correct the error.
Wisem3
2 years ago
Hello, sir i am getting m18 drives off error in processing ide. Then it all stops and the drawing so formed its any good,
cdubs61
2 years ago
Hi! So I have successfully uploaded the CNC Code and have processed the GTRL interface using Processor; however, when I attempt the jog the axes using the arrows keys of my PC, nothing moves. I hear a high-pitched hum (hums when I move up and right keys, but stops when I press the down and left keys) and I can feel the stepper motors trying to work, but the leadscrews won't budge! Also, when I try to move the x and y sleds by hand while this is happening, the leadscrews resist my hand. It's like the motors are preventing movement rather than creating it.... What do I do??? (stepper motors did work when I tested them)
NnaemekaN2cdubs61
Reply 2 years ago
yea i have exactly same problem with mine. and when i test with the one revolution code it works perfectly but when i tried streaming a g code nothing moves, and i made my own motor shield on a bread board using l293d and am not sure whereto connect the input pins on the ardiuno board please i need help on this.
MiguelM214
2 years ago
thanks for your proyect
i do the machine. prove the axis with your programs and the axis are good
i donwload the file "gctrl.pde" but download a file "FLTW2G9IRXTABCW.pde"
i open arduino program and transfer this file. i dont have error.
now.... where i select the file to print?
i dont understan the step 7 of your proyect. thanks
Siliffe
2 years ago
Hi there,
I have tried to upload the arduino code but i got this error message when verifying the code:
cdubs61Siliffe
Reply 2 years ago
In his code it includes the library for the L293D Motor Shield, but you have not downloaded that library onto your own computer. That's why it says "AFMotor.h: No such file or directory #include <AFMotor.h>". If you go to step 2, he has the file for the motor shield library that you download. Once you download it, it should be able to compile. :)
