How to Make Playdough (Play-doh)
9,778,718
1,770
782
About: I've been posting Instructables since the site's inception, and now build other things at Autodesk. Follow me for food and more!
Playdough (aka Play-doh) is easy to make at home, and fun for kids of all ages.  Here's how to make your own non-toxic toy with custom colors and fragrances.
This is the classic method that involves a bit of cooking on the stovetop - I prefer it because cooked playdough has a better texture than uncooked varieties.  If you want the kids to be able to do it all themselves, try this uncooked playdough recipe.
Warning:  Keep away from dogs and other pets.  Playdough smells like people food but contains lots of salt, and a hungry dog can eat enough to cause a dangerous salt imbalance.
Step 1: Ingredients
Playdough is a classic childhood toy everyone can have fun with, and it's so easy to make at home you'll never buy that stinky store variety again.
Basic ingredient ratios:
2 cups flour
2 cups warm water
1 cup salt
2 Tablespoons vegetable oil
1 Tablespoon cream of tartar (optional for improved elasticity)
food coloring (liquid, powder, or unsweetened Kool-Aid or similar drink mix)
scented oils
Step 2: Mix and Heat
Mix all of the ingredients together, and stir over low heat. The dough will begin to thicken until it resembles mashed potatoes.
When the dough pulls away from the sides and clumps in the center, as shown below, remove the pan from heat and allow the dough to cool enough to handle.
IMPORTANT NOTE: if your playdough is still sticky, you simply need to cook it longer!
Keep stirring and cooking until the dough is dry and feels like playdough.
I've gotten many comments asking about sticky dough, so please just keep cooking a bit longer and it will work!
Step 3: Knead & Color
Turn the dough out onto a clean counter or silicone mat, and knead vigorously until it becomes silky-smooth. Divide the dough into balls for coloring.
Make a divot in the center of the ball, and drop some food coloring1 in. Fold the dough over, working the food color through the body of the playdough, trying to keep the raw dye away from your hands and the counter. You could use gloves, a big ziplock bag, or plastic wrap at this stage to keep your hands clean- only the concentrated dye will color your skin, so as soon as it's worked in bare hands are fine.
Work the dye through, adding more as necessary to achieve your chosen color.
1 If you use Kool-Aid or similar unsweetened drink mix for color, test on a small ball first- it won't go as far as the "real" food coloring.
Step 4: Play and Store
Play with your playdough- I really don't need to help you there. It's entirely edible, if a bit salty, so it's kid-safe.
When you're done, store your playdough in an air-tight container.
- If it begins to dry out, you can knead a bit of water in again to soften the dough back to useability. Once it's dried past a certain point, however, you'll just have to start over; thankfully it's not terribly difficult.
- If it gets soggy, you can re-heat it to drive off the extra water the dough absorbed overnight.  This is usually the result of high humidity, but is fixable!
You can also bake it in the oven to make hard dough figures and ornaments, then paint or otherwise decorate the surface.  One of the comments below even suggests using baked play-dough as a salt lick for your pet rabbit!  (thanks, redcore4!)
The Instructables Book Contest
First Prize in the
39 People Made This Project!
  • Tape Contest
    Tape Contest
  • Trash to Treasure
    Trash to Treasure
  • Jewelry Challenge
    Jewelry Challenge
782 Discussions
MSpitfire
Question 10 months ago on Introduction
Does it matter what type of oil one uses? Will it turn out the same with Coconut oil?
1 answer
TerriT33MSpitfire
Answer 4 months ago
I used olive oil. Worked out just fine.
8312295
1 year ago
i like to make playdoh
LFelton
Tip 1 year ago on Introduction
Add food coloring or the coloring you plan to use to the water. It is much easier than kneading the food color.
ecc0927
1 year ago
This is ingenious!!
352632
1 year ago
I loved it. It was better than store bought ones! my family was very pleased with the results. I really recommend it. We had lots of fun molding it into different objects.
Txhoney521
1 year ago
Made with my grand daughter. When done we put in ziplock and a month later she brought it back to my house to play with it. Lasts long time. Fun to make
FinweMartinez
1 year ago
Made some, but it got soggy overnight. Is ok to reheat in microwave? Do i need to add something else when reheating?
KoBobFinweMartinez
Reply 1 year ago
Hello FinweMartinez,
I'm not sure how you batch would get soggy overnight, sounds like interesting story. As for your microwave question I have not tried, but I lets consider the normal instructions to warm the dough at low temperatures. When finished, the dough is still "dough" and pliable. When you cook food from a microwave it usually it comes out fast and hot. If you set the time to thirty seconds the dough batch the water evaporates and "cooks". Your microwave may have a defrost feature and it may be possible to warm the dough, like I said earlier I have not tried. If you are going to microwave the dough batch let us know how it turns out. What would be the worst that can happen, throw away a bad batch. I'm sure other people would be interested in your results.
Best regards,
KoBob
Dewny
1 year ago
A salt dose ranging from 0.75 grams to 3 grams per kilogram of body weight can kill someone. The one cup of salt in this recipe equates to 240 grams. Therefore consumption this batch has the ability to kill between 80 and 320 lbs of body weight.
A 26 lbs child eating 1/3 of a batch will die if not receiving emergency medical treatment.
I don't think many kids would enjoy eating this but to say it's "entirely edible... kid-safe" is flippantly irresponsible.
Please note, I do not have a problem with this Instructable. I think it's a great idea, recipe and craft. My only objection is to the insinuation that it is "entirely eatable". If a kid eats a small amount there should be no problems. But in every kindergarten class seems to have that one kid that will eat the entire jar of paste or the whole box of crayons. If that kid eats this stuff, the kid will be in serious need of emergency treatment.
gabrielledearmanDewny
Reply 1 year ago
I think the author made that statement to say that the recipe is non-toxic, so if curious little ones take a bite, it won't be toxic... but, wasn't said to encourage eating.
Dewnygabrielledearman
Reply 1 year ago
Everything is "non-toxic" if one is exposed to a small enough amount. Considering the age of the children uneducated parents may allow to play with this stuff, Google salt toxicity and do the math. One bite of this stuff may be all that's needed to put a small kid in the hospital or worse.
coburgcraftstuffc
1 year ago
I have been making play dough for over 25 years - very similar recipe, but the Australian version has 4 tbspn cream of tartar, the recipe is on the container! I always add the food dye to the water, that way you can see what the colour will be like ( eg when mixing primary colours to make purple/ orange/green etc). The recipe can be halved for a smaller batch, and when making it with young kids, no need to cook on the stove, just mix in boiling water to dry ingredients, the result is the same. I would make a full batch for my kids when they were young, but divide it into 3- 2 in zip lock bags to put into the frezer (or give to friends), one to store in the fridge & play with. That way if the first lot dried out or got dropped on the floor too often, I could bin it & have a fresh lot once it thawed out overnight. If kept in an airtight comtainer in the fridge it pretty much lasts forever ( and can quickly be warmed up with a 10 second zap in the microwave), if not kept in the fridge the oil will eventually go off & the playdough won't smell so good. And don't use olive oil, it doesn't work & stays sticky even with a ton of extra flour! ( I made this mistake only once!!!)
Mrs Martin421
1 year ago
I made this. I followed the directions as written, it was not complicated at all and it came out perfect! My kids are loving it. I used Vanilla extract and it smells like cupcakes. Thank you for sharing.
KellyB141
2 years ago
Very excited about this. My daughter chose dumbo as her theme for her baby shower. We had lots of fun making it and I'm pretty proud of the results. You be the judge.
clutzyKellyB141
Reply 1 year ago
Hi. Great work of art. How thick is your piece and how long did it take to harden? I just tried a piece that was about 2/8" thick. The top harden, but underneath it was soggy. I experimented with uncolored playdoh and it yellowed a bit. Did you have any color issues?
Thanks for any information that you can provide.
pmk222
1 year ago
I've seem some comments/suggestions about using baking soda instead of cream of tartar, but everyone says to "use a bit more". What is the suggested amount of baking soda instead of cream of tartar?
