How to Make Pom Poms
36,460
121
20
About: Instructables Community Manager - I am powered by sugar and rainbows! For realz!
Yarn pom poms are great on their own and they're perfect for various knitting and crochet projects. They're really easy to make and there are lots of different methods (and products) you can use to make them.
This is the way I've come up with that is cheap and easy, leaves you open to any size, and doesn't require you to cut yarn off your ball to wrap them.
In the last few steps, I'll also show you how to make the pom pom fluffier and how to do a multi-colored pom pom.
Step 1: Supplies
Here's what you are going to need to make your pom poms.
  • Yarn of choice
  • Cardboard (I used cardboard from a cereal box)
  • Scissors - the less bulky they are, the easier time you will have getting them under the yarn and cutting, also, make sure they are sharp enough to cut yarn, no safety scissors
  • Pencil
  • Circle objects to trace (I used the bottom of a glass and a small spool of thread)
Don't want to deal with all of this? There are lots of pom pom making products to make it super easy on you. I have never tried any so I don't know how well they work.
Step 2: Pom Pom Wrapper
First you need to cut out the cardboard for something to wrap your yarn around. A popular shape for this is a donut, but I find that a little inconvenient since you will have to cut the yarn off your skein to do this. My solution was to make a cut donut.
  1. Start by tracing your large circle with the smaller circle inside (Don't make the inside circle too big or too small if you can help it. Too small and you won't be able to wrap the yarn in there, too big, and the pom pom might have too much extra space when you go to tie it.)
  2. You want to make one cut through the donut and cut out the center of the circle.
  3. Fold up the ends of your cardboard as shown in the photo.
The folds may annoy you and you can cut them off entirely if you want, but I find them handy for holding the yarn on while you wind it, and also you can fold them down when you go to cut the yarn which keeps the pieces from falling off.
Step 3: Wrap Yarn
Time to wrap the yarn!
Put your pieces together so the flaps face out on both sides.
Now wrap. Just keep going and try to keep it as even as you can. If you have big bulges, you are going to have longer pieces that will just have to be trimmed later, but it isn't too big of a deal. It is hard to wrap the yarn near the ends, so it might be easier to stay more towards the middle like I did.
Step 4: Cut and Trim Pom Pom
Time to cut all your yarn!
Go along the edge of the cardboard and just start cutting.
After all of the yarn has been cut, take another piece of yarn and wrap it around your pom pom going between the pieces of cards board.
Tie it up! I liked to tie two knots on one side, then wrap the yarn around to the opposite side and tie two more knots. You won't see them so you probably can't knot it too much.
Trim off the excess yarn and try to make it as circular as you can (it will be uneven).
As you can see from the last image, the pom pom should have pretty much the same diameter as your cardboard circle.
Step 5: Tips!
  • It helps to fold down the tabs when you start cutting. Then those yarn pieces won't try to escape through the opening.
  • I found holding as much of the pom pom as I could while cutting made it hard for stray pieces of yarn to escape. Though, the more you cut, the more they'll hold themselves in place.
  • If you want to hang this, make sure to use a long enough piece of yarn to tie up your pom pom and then leave one or both of them long.
You can see what my cardboard pom pom maker looked like after making 7 pom poms. Mine mostly got beat up because I kept clipping it with my scissors.
Step 6: How to Make a Pom Pom Fluffier
Brush it!
The best way to do this is to take an old brush that you don't care about (though, it is pretty easy to pick the fluff out when you are done). It is also good to use a brush that doesn't have little nubs at the end of the bristles. Those nubs will just get in the way of catching on the yarn.
Hold the pom pom tightly in one hand and start brushing with the other. If you brush hard you could pull out some of the yarn pieces, but if you grab it good enough, you shouldn't have that problem. Just keep rotating the pom pom in your hand and try to brush all over so it is fluffy all over the outside.
If you look inside the pom pom after you are done, you'll probably notice that the yarn strands are still pretty intact, but the outside of the pom pom should be nice and fluffy now.
Step 7: How to Make a Multi-Colored Pom Pom
It's really easy, just wrap two (or more) colors of yarn at the same time. Wrapping them together ensures you'll get a more even distribution of the colors throughout the pom pom. Also, the more colors you do, the less times you'll have to wrap since you'll be wrapping more than one strand at a time.
Step 8: Have Fun Making Pom Poms!
They're fun to make and they're just so soft and cute! I couldn't help making them in all colors.
2 People Made This Project!
  • Party Challenge
    Party Challenge
  • Fandom Contest
    Fandom Contest
  • Gardening Contest
    Gardening Contest
20 Discussions
SanjaK3
6 weeks ago on Step 6
I tried it this way and did everything as instructed, but when I started cutting, my yarn just turned into many tiny pieces.
Penolopy BulnickSanjaK3
Reply 6 weeks ago
Do you have any pictures? Was it lose? If you don't wrap it enough I think it won't hold itself in place.
SanjaK3Penolopy Bulnick
Reply 6 weeks ago
The first few just fell apart. Then I found another instruction, how to do it with a fork, and got slightly better results. I could only make small pom-poms that way and they were still far from perfect. Here is a picture of them:
yezsocrafty
3 years ago
I love adding pom poms to hats. I will have to try this method out. Thanks for sharing.
Greenman2
3 years ago
I have always have used a different method but this one looks easier. Thanks, must try this.
milliepearce89
3 years ago
I will do some with my little niece, looks so fun and easy, thanks :)
audreyobscura
3 years ago
I never thought of taking a brush to a pom pom to make it fluffier. You are a wizard.
