How to Make Small Wind Turbine Homemade
27,877
60
9
About: Hi Friends, Follow me for more Physics related projects.. I'm a renewable energy passionate. Join me, Have FUN
So here we are going to make a small wind turbine. You can make it easily at home. Almost 90 percent of the parts are made of PVC fittings and pipes. So it is very easy to assemble or disassemble and carry it to your classroom. I have uploaded my own video making this small mini wind turbine on youtube. I have also embedded that here. Let's make it. watch video you can learn it on my blog here Make small wind turbine
For More DIY Projects Like this, visit New Physicist
Step 1: Step 1: Making Propeller
Buy a 10 inch PVC Pipe (3inch in diameter)
equally divide the edge perimeterCut the pipe into blades as shown in video- watch video
Make holes as shown in the picture on anything round in shape with 2.5 inches.
Then screw 3 blades to it using cycle screws.
Step 2: Step 2: Making Wind Turbine Base
The turbine base and the post holds the propeller, dynamo, tail, and autorotation mechanism. It is very easy to make the turbine base. Buy some PVC fittings.
Elbow – 4PVC T – 3PVC pipe piecesConnect these fittings as shown in the figure.
Step 3: Step 3: ​Make Small Wind Turbine Tail
Most of the DIY wind turbine videos on youtube doesn’t have a tail- autorotation mechanism (yaw mechanism). Without a tail-autorotation mechanism, a Small wind turbine is not complete. What is the purpose of a tail? The tail auto rotation mechanism will help the propeller to change the direction to face the wind. Th tail will force the propeller to face the wind even at higher wind speeds.
cut GI sheetPVC Pipe, reducer
Step 4: Step 4: Making Dynamo Casing
wire
A piece of pen
PVC Fitting T
Buy 2 bearings
Buy a dynamo 3V
Connect the dynamo to the PVC fitting.
Connect the two bearings to a common axis.
A piece of a pen can be used as the axis.
connect one bearing to the PVC T
Step 5: Step 5: Mini Wind Turbine Is Ready
Place the wind turbine in front of a fan
connect a multimeter to the output wires of the dynamo.Yes, Multimeter needle is indicating a current flow through it. If you are using an efficient Dynamo, you can use this dynamo to charge your 3 v rechargeable battery. Besides, You can build a larger wind turbine than this to charge your smartphone too.
http://www.newphysicist.com/make-small-wind-turbine/
    • Trash to Treasure
      Trash to Treasure
    • Tape Contest
      Tape Contest
    • Arduino Contest 2019
    9 Discussions
    chronistergama
    1 year ago
    Go to Inplix if you'd like to build it yourself.
    Uncle Kudzu
    2 years ago
    Very clever! That's cool that you were able to make so much of it from plain old PVC. Is any DC motor a dynamo?
    Newphysicist_comUncle Kudzu
    Reply 2 years ago
    It's a dc motor.. Not a dynamo.. However we think its helpful to understand how a horizontal axis windturbine works.. Am I right?
    Uncle KudzuNewphysicist_com
    Reply 2 years ago
    Are all DC motors capable of producing current? Reason I ask is that I have a hefty 12V motor from an old automobile radiator fan and a 15V motor from a cordless weed whacker and I wonder if I could use them in a project like yours.
    nehmoUncle Kudzu
    Reply 2 years ago
    All brushed DC motors can be used directly as generators. The motors you described are brushed.
    Brushless can also be used as generators, but the circuitry would be different.
    nehmo
    2 years ago
    Large wind turbines use 3 blades fro harmonic reasons. 6 also works, but it is too expensive for the yield. In this case, considering the size, harmonic vibration wouldn't be a problem. So, the more of the "disc" that is occupied with solid blades, the better.
    SHOE0007
    2 years ago
    I think that this is cool. Making alternative energy through wind power. I just have a few questions about risks including accidently killing birds if you place it in very high places.
    Do you know of the 100 thousand birds of pray at the wind farm in California? The cheaper and less efficient types that only produced 100 kW killed a lot more than the 1 Mw types.
    Newphysicist_com
    2 years ago
    Thank you for your kind words. Let me know when you complete yours..
    That's really cool. I always wanted to know how to make my own wind turbine.
