How to Make Vacuum Cleaner Using Plastic Bottle at Home
320,166
36
23
About: hi i am krazykred this channel is all about funny pranks and DIY things and mini projects and science and technology and various crafts and paper arts and also tips and tricks and things from scrap.....
Requirements
Plastic bottle
deodorant bottle
first aid cloth
DC motor
and glue gun and a small bending pipe
Supplies:
Step 1: Cutting the Plastic Bottle and Deodrant Bottle
Take the empty plastic bottle and cut into half and next , Take a deo bottle and cut and you will get a flat sheet as shown in the figure . Lets move on to the next step
Step 2: Making the Fan
1.Sheet From the deo bottle is taken and place the previously cut portion of the bottle and sketch the round bottom opening with the marker and the cut the marked portion you will get a round metal portion
2.Then take a scale and draw 4 lines as shown in figure it gives a middle point and 8 wings portions to cut them later
3.Take a hammer and nail and at middle portion of round sheet place the nail and make a hole
4.Then basing on the lines drawn cut the wings of fan leaving some round area near the middle hole we will get the wings
5.Twist the wings means all the wings in the same direction as shown in figure.
6.Your fan is ready
Step 3: Attaching the Fan to Motor
1.Take the 12 v DC toy motor and to the rotating rod attach the ball point pen refill and press it to tighten.
2.Cut the excess portion of refill and then take the fan previously prepared and fix it to the refill placing the refill portion into the hole of the fan.
3.Apply hot glue for extra strength around the joint.
4.Fan is ready
Step 4: Placing the Fan in the Plastic Bottle Bottom Portion
1.In the bottom portion make a round portion with the marker that holds the motor at the centre
2.using the soldering rod or else any heated needle make holes on th entire bottom of the bottle that is usefull for letting suction air outside
3.then make a big hole on the trace to fix the motor after placing the hole apply hot glue and fix the motor in the hole placing fan side inside the bottle and connecting part of motor outside.
Step 5: Fixing Bottle and Attaching Using Plaster
Take the first aid cloth and place the top portion of plastic bottle and place it on the first aid cloth and trace round slightly more than bottle and using double sided tape fix it to the bottle and fix the two portions of the bottle using a tape.
Step 6: Making Suction Pipe
Take the bottle cap and make a hole and place a wire pipe that bends in any direction and fix it to the cap and on the other end fix the small plastic bottle as shown in the figure.and fix it to the bottle
Step 7: Final Steps
For decoration purpose i added red plaster and a handle using the card board sheet and connect the motor withwires and switch on vacuum cleaner.
Thank you
Don't forget to like comment and subscribe my youtube channel....
    • Fandom Contest
      Fandom Contest
    • Woodworking Contest
      Woodworking Contest
    23 Discussions
    jojapurple789
    4 months ago on Introduction
    when i type in deodrant bottle it brings up the one under your arms. Which type of deodrant bottle and can I use a soda can?
    Selena Hendry
    Question 21 days ago
    What size bending pipe do I use?
    BarbaraCox12у331
    6 weeks ago
    I chose my vacuum cleaner very carefully so that it would suck me for a long time. On a special site https://bestvacuum.reviews/vacuum-cleaner-carpet/, I read customer reviews and bought the best one; by the way, I found some tips how best to clean the container. I spent a lot of money, but I am confident that it does not give up in a year.
    i will not tell u
    Tip 3 months ago
    u can use a pepsi can instead of the deo bottle
    imonica1998
    Question 4 months ago on Step 3
    Can we use 9v high rpm motor instead of 12v??? Will it be effective enough to create vacuum cleaner?
    MilanV27
    4 months ago
    your homemade DIY vacuum cleaner is a great project. I also try to make this project at my home. When I make vacuum cleaner at my home i got that problem. Problem is Vacuum cleaner does not suck the dust inside it. How can i do it.? Please reply me dear....https://www.creativitybuzz.org/make-vacuum-cleaner/
    JeremiahS46
    Question 5 months ago on Step 7
    what specific watts and volts does my dc motor have to produce in order to make the vacuum work?
    RishaS
    1 year ago
    Good morning! We are asking for your permission to modify this work for school purposes only. We will cite this, anyway. Thank you for your kind consideration and more projects to come.
    Alvinjhon24
    1 year ago
    What is the Independent Variables in making this Vacuum cleaner made in Plastic bottle?????
    sreeraj n r
    2 years ago
    I tried doing this and unfortunately some glue fell in the motor and blocked it's shaft please be careful.
    ChabuK
    2 years ago
    I thought you said a dc motor was used to make this. So Where did the plug come from in one of the pics in "final steps"? Did you supply ac current? How? Pls tell.
    sreeraj n rChabuK
    Reply 2 years ago
    I think the led driver is acting as the ac to dc converter
    serendepity
    2 years ago
    what is the power source used in this project. please provide the specification if it is a battery.
