How to Make a 30w Mega Flashlight
2,187
20
6
About: I make diy and electronics based projects.
Hi,In this intructable I show how to make 30w mega flashlight
Step 1: Led and Heatsink
first we need a 30w smd led chip and a heatsink.I mount led on the heatsink with screws.and don't forget to add some thermal paste.
Step 2: Adding Fan
I add a fan for more cooling it works good.
Step 3: Making the Box
I maked a box with hardboard for the led.
Step 4: Adding Switch and Female Connector.
added a normal on/off switch and a female power connector for charging the battery.
Step 5: Mounting the Led Into Box
mounted the led into box with screws.
Step 6: Bushes and Screws
Need 4 rubber bushes and 4 screws for base.
Step 7: Drilling the Hole
drill hole in the centre for screws.
Step 8:
mounted the rubber bushes
Step 9: The Battery Pack
Step 10:
mounting battery with double side tape.
Step 11:
Adding a metal sheet for xtra strong.
Step 12: Battery Charger
Iam using a automatic charger with thermal protection.It's output voltage is 12v.so that we can charge 11.1v battery.
Step 13:
Wiring the battery charger and battery.
Step 14:
This is a diy battery level indicator.The ic I used is 3914.If anyone want the circuit diagram comment below I will give you.
Step 15:
final wiring.
Step 16:
make a metal clamp for more strong.
Step 17:
close the top cover and glue it using hot glue.I added a on/off switch and a push on switch.
Step 18: Painting
painting using sparypaint iam using black.
Step 19: Final Look
I added a handle.
Step 20:
Battery level indicator at night
Step 21:
charging before the use charging voltage 230v ac
Step 22:
without led and with led
Step 23:
Without any light,with a regular torch and my mega flashlight.
Step 24:
regards,
Electro maker.
    • Tape Contest
      Tape Contest
    • Pocket Sized Contest
    • Pie Contest
      Pie Contest
    6 Discussions
    lr10cent
    1 year ago
    I like this flashlight. I've got a torchiere lamp in my living room with about the same amount of power going to some LED's. Very bright.
    It's just my personal opinion, but I think you'd have a better chance in the Epilog IX challenge if you added to it. For instance, a complete list of parts and maybe even sources. Also, a circuit diagram and more detailed, step by step instructions. And, of course, schematics.
    Maybe I missed it, but I didn't see a device to limit current. Did you do a test to make sure that the current wasn't greater than the specified maximum allowed for the LED? If this is a 12 volt LED chip, then 30 watts would be around 2.5 amps.
    If I was making one of these, I'd want more protection for the LED. Maybe, if it could withstand the heat, a piece of polycarbonate sheet. Or a piece of tempered glass. Or maybe a wire cage, as you sometimes see on work lights.
    Electro makerlr10cent
    Reply 1 year ago
    This led is only 1ampere and the cooling fan is about 0.5ah.
    rafununu
    1 year ago
    You make the same error than many people wanting to drive a Led without current control and limit. Here, battery act as a current limiter, which means it produces heat internally and the Led is uselessly stressed. Apart from that, it's another 30W Led.
    Electro maker
    Tip 1 year ago
    You can clearly see holes on both sides of the box
    TypeNameHere
    Tip 1 year ago
    ffs please tell me theirs a vent hole and its just not visable on the bottom or something... whats the point of a fan and no vent
