How to Make a $7 Floating Shelf
96,999
835
60
About: Discover woodworking, concrete, LEDs, home decor and DIY projects you'll love.
For this Instructable, I’ll be making two floating shelves. Affordable, stylish and easy to make! These shelves can improve any space -- either a bathroom, living room, kid's room, etc. The best part about it is that each shelf can be made for only $7.
Materials (per shelf):
1- 2-inches x 6-inches x 8-feet (Spruce Pine) @ your local hardware store
1- pack of keyhole hanger
1- 1/2i-nch x 48 Dowel @ your local hardware store
Other:
- Oil-Rubbed Bronze Paint
Wood Glue
Wood Glues bottle
Self-drilling drywall anchor
Tools Used
- Wood Clamps
- Drill
- Dowel bit
- Dead-blow mallet
- Circular saw
- Miter Saw
- Hand saw
- Sander
Supplies:
Step 1: Cutting the Pieces
I'll be using one 8-foot piece of lumber for each shelf. Cut the large pieces first using a handsaw, or a power tool if you prefer.
Step 2: Putting the Pieces Together
For this project I'll be making two shelves. After all the pieces are cut you should end up with four pieces of lumber measuring at 32 inches, and four pieces of lumber measuring at 6 inches.
I wanted to make this project doable for any beginner, so I used butt joints and dowels. For more experienced viewers, I would suggest Miter Joints. This will give it a cleaner appearance.
Step 3: Glue the Pieces and Sand
Apply wood glue to the corners, clamp the joints in place to prevent any shifting. You could use screws if you like, but to give a cleaner look I used two 1/2-inch dowels per corner. Mark the dowel so that it goes through both pieces of wood. Apply wood glue to the dowel, as well as in the hole. Hammer the dowel down until it reaches a stopping point. Now, take a saw and cut off the excess. Leave the clamps in place and allow enough time for the glue to dry. Next, sand the shelf using 80 grit to remove the rough texture, then use a 120 grit, followed by a 220 grit.
Step 4: Paint or Stain?
As far as finishing, It's a matter of taste. My opinion is that you can't go wrong with either stain or paint.
I found this paint a few months back, and I had to have it. I was a bit hesitant on what the finished product should look like. I chanced it with this Oil-Rubbed Bronze paint, which gave it a nice, rich look to it. It wasn't too appealing after the first coat. The second coat looked amazing. I stopped there, but I have to imagine a third coat would top it off.
Step 5: Mounting the Shelf
Here is a mounting tip I learned a while back:
Take a piece of scrap wood and drill out your mounting holes. Then, use that same scrap wood and mark the shelf and the wall. If carefully done, it will line up every time.
Next, install the Keyhole hangers, Be sure to drill out behind the keyhole hanger. So the screw doesn't interfere.
To mount the shelf, I'll be using self -d rilling drywall anchor, Each one is rated for up to 50 pounds.
Step 6: The Final Touch
Floating shelves are a great project for your home. Not only do they look nice but they save a ton of space. You can use them for many things like displaying collectibles, photos or other decorations.
2 People Made This Project!
  • Arduino Contest 2019
  • Gardening Contest
    Gardening Contest
60 Discussions
FraniQ
12 months ago
You make it look so easy! I am going to try this.I like the paint.Thanks for sharing!!!
ndronet
1 year ago
What is that workbench that you are using please?
dandinosndronet
Reply 1 year ago
Keter folding work table.
$80 on amazon
That's what i have, The one above could be different brand
ndronetdandinos
Reply 1 year ago
Thanks! I found it on Amazon.
YaënD
1 year ago
great DIY, gonna make some for my house. thanks for it
WinsantS
1 year ago
This is a really cool DIY project for home... Must try it some day.....
greatoak
2 years ago
That is awesome! I can place one of them over the towel bar and it would match perfectly.
Thank you!
LeslieGeeegreatoak
Reply 1 year ago
You can also make a towel bar that attaches underneath the shelves either copper or plumbing pipes for an industrial look :)
etupin
2 years ago
If the shelf was made about 3/4 inch longer, so the distance between the keyhole hangers was 32 inches, then the shelf could be hung from screws in two wall studs (wall studs are typically 16 inches apart). This would be a sturdier hang - and would solve the concern about the cat!
ClintC15etupin
Reply 1 year ago
This is true, but not in my house! lol
nervosaetupin
Reply 2 years ago
Man! How heavy is your cat?! He says each screw anchor holds 50 lbs.
LeslieGeeenervosa
Reply 1 year ago
LOL better to be safe than sorry. Even If I use Command Hooks for something, no matter how light the object I am hanging I usually get the hooks that hold more. On an aside I have a 17 lb cat that when he lays on me he feels like he is 27 Lbs. Cats when they jump on something look like they land lightly but, if I am right the pressure of the landing makes the cat heavier. Ever press down on a floor scale and see the gauge go upward if you keep pressing down?
LeslieGeee
1 year ago
Beautiful shelves and great tutorial thank you for sharing :)
ashburn orange
2 years ago
Wonderful !
Great video, I like it that you have kept it simple. Your $7.00 investment looks like $1,000,000 !
sybere
2 years ago
Nicely done. I can't wait to give it a try. Thank you for making this tutorial.
WeirdAlWalker
2 years ago
"Then use that same scrap wood and make the shelf and the wall."
You mean "mark" don't you? Not "make"?
