How to Make a Bandsaw Box
4,556
40
14
About: My name is Mitch. I make videos about the things I make and what I learn along the way. I have a Youtube Channel called Made by Mitch. I also love the coffee and the outdoors.
I recently got a new bandsaw in the shop. I don’t have any experience with a bandsaw and thought I would create a project that would get me a little practice. I have seen others make bandsaw boxes before so I thought I could give it a try. This was a great learning project. I had to make many different cuts using the bandsaw and this forced me to learn the ins and outs of the new tool. I hope you find this helpful!
Supplies:
Step 1: Tools and Materials
TOOLS
  • Bandsaw
  • Miter saw
  • Table saw
MATERIALS
Step 2: Mill the Wood to Size and Glue Together
The first thing I had to do for this project was mill all the lumber down to useable size. You can use whatever wood you would like for this. I chose maple and walnut. I started with two pieces of rough sawn lumber and used the planer and jointer to prepare the lumber for use. I first used the jointer to get one face and one edge completely flat. I then ran the board through the planer to get the other side flat. I can then use my flat edge along the table saw fence to get my other edge lined up with the first edge. If you do not have a way to mill lumber like this, (i didn’t for a long time) you can purchase small pieces of wood online that is already prepared or you can but your wood from a planing mill that can get it ready for you so you just have to cut it up. Once the boards were prepared, I cut the boards into squares that were about 6 inches by 6 inches. I then stacked them in the order I wanted them and glued them together and clamped them letting the glue dry overnight. This made a giant cube shape.
Step 3: Cut the Box to Shape
The next thing I had to do was cut out the shape my box would be. This can be whatever you want it to be. I started with a template of Mickey Mouse ears but had to scrap it because I messed up on Mickey’s ear. So I just went with a simple rounded top with a flat bottom. You can use a template and spray adhesive to glue it to the box or you can just draw the shape on the box. After you have your shape, you can start to cut it out on the bandsaw. A tip I have learned with cutting with the bandsaw is to just keep the piece moving along but don’t try to go too fast. Also, try to stay outside your line just a little bit. You can sand it later on but it is better to have extra space to work with then cutting too much off. (Like I did with Mickey’s ears) After your shape is cut out, you will need to cut about half of an inch off the back of your box. You will glue this back on later. (Watch my video to understand this fully.) Once the back is cut off you can cut out the drawer.
Step 4: Cut Out the Drawer
Next you can cut out the drawer. You can use whatever shape you want. I drew a few lines on the box using a paint can to make my shape. Once you have your line laid out, you can cut out the shape. You will have to cut from the outside of the box to get to your inside line. This is ok. You will glue this back together once your inside part is cut out. Make sure you go slow and stay steady on this part. You really only have one chance at this part.
*TIP -- Start your cut going with the grain. It is much easier to hide a glue seam going along the grain than one going against the grain. Check out the video to understand fully.
After your inside drawer shape is cut out, you have to cut out the material to make your drawer. To do this you will first need to cut a half inch off the front and the back of the drawer. You will glue this back on later. Next you will determine how much material needs to be removed from the drawer inside. Make a line and then cut this out on your bandsaw.
Step 5: Reassemble
You should now have several pieces that you have cut up and everything is now ready to be put back together.
DRAWER - to reassemble the drawer, you will just need to glue and clamp the front and back of the drawer back to the inside part you cut out. It is a good idea to go ahead and sand the inside of the drawer first. I did not do this, and it was very hard to reach once it was all assembled. MAIN BOX - For the outside part of the box, you will need to glue the seam back together from the cut you made earlier. Once this seam has dried, you can glue the back of the box back on to the main part. When all of the glued parts are dried, you should have a fully functioning box and drawer. After my box was reassembled, I wanted to add a rounded back on my box. This is an optional thing, but I drew the shape using a measuring cup I had in the shop then I cut it out on the bandsaw. This really elevated the look of my box, but again is totally optional.
Step 6: Sand
Now you can sand the box and the drawer. I used a bench belt sander but you can use whatever you have. Make sure to get all of the bandsaw marks out and also the glue seams. I sanded everything up to 220 grit. I also used a ¼” round over bit with my trim router and went around the front of by box and drawer. Doing this with a router hid some of my bad bandsaw cutting skills and make it look a little better.
Step 7: Make the Handle and Feet
At this point the box and drawer are just about complete. I had a scrap piece of maple that I used to make the handle and feet of the box. I used the table saw to rip the pieces to width and the my crosscut sled to cut them to length. After I cut them out, I sanded them up to 220 grit and glued them on the box. I clamped them up and let it dry for a while. You can get creative with the shape you want your feet and handle to be. Once the glue dried, I used a chisel to get all of the excess glue squeeze out cleaned up.
Step 8: Apply Finish
The last step for me was to apply finish. I used danish oil which is what I use a lot on hardwoods. I applied two coats letting it dry between each coat and after that, the project was complete.
Step 9: Complete
Make sure to check out the video for the full how-to experience and if you have any questions on the steps leave me a comment or send me a message. You can also find me around the web. I hope you enjoyed this project!
Youtube - http://www.youtube.com/madebymitch
Website - http://madebymitch.net
Instagram - http://madebymitch.net
Twitter - http://madebymitch.net
    • Arduino Contest 2019
    • IoT Challenge
      IoT Challenge
    14 Discussions
    Plume1
    Question 3 months ago
    Hi, does the name bandsaw box refer to using it for bandsaw parts and accessories or to the tool you use for making it?
    thank you
    jbarchukPlume1
    Answer 10 days ago
    You don't HAVE to use a bandsaw. Use any saw or cutting implement you like. However, think about those 6" deep internal cuts, and then think of another tool that can do it. Coping saw is all I can think of. There might be industrial size scroll saws. Not much has a blade that long and shallow.
    MadebymitchPlume1
    Answer 3 months ago
    Hello! It is called that because it is made almost exclusively with the bandsaw. I had the same question the first time I came across one. Great question.
    imprettymuchaloser
    3 months ago
    It looks like your blade is flexing a lot. On your upper and lower (beneath table) guides, the should be a bearing that limits how far back your blade can push. You should move those bearings forward and leave less than 1 pair thickness between bearings and blade. There are a number of bandsaw tuning instructables that I've used to get my saw running smoother. =)
    Madebymitchimprettymuchaloser
    Reply 3 months ago
    Yes there was a good bit of flex in the blade. I appreciate the advice! I am totally new with a bandsaw I will take all the help I can get. I really appreciate it!
    jbarchukMadebymitch
    Reply 10 days ago
    Look up vids for tuning/adjusting band saw. By the flex in the blade I think you were pushing too hard. Thick-thick hardwood block, and not a coarse blade, tough work for a small machine. Let the machine cut at its speed. Excellent instructable.
    ndronet
    12 days ago
    What blade size/TPI did you end up using?
    StevenF90
    7 weeks ago
    I bought a bandsaw a few weeks ago for £90, i've been itching to find something to make so i can use it and really appreciate you posting this. I had a strip of walnut or teak (it's like sanding concrete it's so dam hard), i'm not sure which, i've glued together to get the width and had to sand each piece flat by hand. Just come back to watch again so i don't make THAT BAD mistake myself which i'm pretty sure i would have done lol. I'll try and post an image in a few days after watching the glue dry :)
    logwolf
    3 months ago
    Great job! Especially being able to "run with it" after deciding no Mickey Mouse Ears. I made an entire Mickey Mouse Bandsaw box, but painted it with Black & white acylic paint. Gave it to my neice as a Christmas gift. Her sister, mother & her family go to Disney every year!!! I used pine for this. Keep up the good work.
    Madebymitchlogwolf
    Reply 3 months ago
    This is so cool! Very nice work on this. I am going to re-attempt this at some point. I appreciate you sharing this.
    gwlinn123
    3 months ago on Introduction
    Very Nice!! I liked the way you used the tools and skills you have available. I also like that you "just did it" rather than mull over a "best way" forever or start over. That's my problem, thinking too much rather than just trying. These small boxes would be nice gift boxes.
    Madebymitchgwlinn123
    Reply 3 months ago
    Thank you! Yes I tend to go into "fix it" mode and just go for it. It does lead to mistakes but I always learn from it lol. Thanks
    Whitney Fabre
    3 months ago
    I really enjoyed your video and that you explained when you made mistakes. I learned a lot. And your box turned out so cute!
