How to Make a Cursor With Photoshop
130,059
37
60
This is how to make a cursor with photoshop.
I will be making my cell phone as a cursor.
Step 1: Open Explorer
First download the attached plugin and put it in the directory C:\Program Files\Adobe\Adobe Photoshop CS2\Plug-Ins\File Formats.
Step 2: Open Photoshop
Open Photoshop and create a new file, 32x32 and give it a solid color background---(it wont show up later)
Step 3: Make Cursor
Make what you want your cursor to look like.
Then use the magic wand tool and select the background color.
Step 4: Now Add It to an Alpha Channel
Now we are going to add it to an alpha channel by pressing Select--->Save Selection...
Then we name it like BG or something.
Then Deselect (Ctrl+D)
Step 5: Now Save
Go File--->Save as...---> Type name and use scrollbox to select *.cur
Step 6: Apply Cursor
Go to control panel ---> Mouse ---> Pointer ---> Browse
Then find your cursor and press ok
Step 7: DONE!!!
Now we are done.
    • Classroom Science Contest
    • Party Challenge
      Party Challenge
    • Fandom Contest
      Fandom Contest
    60 Discussions
    eileen.c.carmody
    1 year ago
    I cannot find the downloadable plugin, where is it?
    LauraR5
    4 years ago
    Where can I find the plug-in?
    This doesn't seem to apply to Windows 8... any suggestions??? I am DYING to make this.
    naz3
    10 years ago on Step 4
    I found it much easier to just use the Alpha 1 channel from the Channel drop down, instead of creating a new channel. For some reason it wouldn't work correctly with the above instructions.
    nenomnaz3
    Reply 9 years ago on Step 4
    How do i do that? I'm new to photoshop
    Energyzednenom
    1. Make the Background behind your cursor black. 2. Make sure the picture and the background color are on the same layer (Merge/Flatten Image if need be). 3. Using the wand tool select your background color (also make sure the "Contiguous" box is checked for the wand tool's settings, and nothing else; this should be at the top of the window including "anti-alias" & "sample all layers") 4. Save your selection as a new channel, name it whatever you want (Select>Save Selection). 5. Deselect. 6.Zoom in on your picture at 800% and select 1 pixel somewhere in the top left corner (This is for the hotspot). 7. Save the selected pixel as a new alpha channel (same as last time). 8. Save as a .CUR file and you're done! :D
    Energyzedasdffsdaf
    DirtyBrain
    8 years ago on Introduction
    Doesn't work. I am in CS3 and the bg is solid...I tried white, black, green, and none, and it doesn't show right when applied.
    EnergyzedDirtyBrain
    I have Adobe Photoshop Elements 8.0 and when I open the file it asks me if I want to allow the file to open in the Editor. If I click allow, it will only open the program. My dilema is, I'm not able to open the file and move it to my programs.
    If anyone has any tips on how I can fix this, please respond or PM me ASAP!
    Thanks.
    gandora99
    8 years ago on Step 6
    mine has worked fine great instructable
    thanks!!
    Thank you for this instructables! Used it today. You would think that for an expensive piece of software, Photoshop would already export icons without any help but I guess not.
