How to Make a Gears Curving Arm Slider
3,341
51
4
About: I recently started translating and film my tutorials in English to share my passions. I am a famous YouTuber in Europe. forgive the mistakes english is not my first language :) RULOF MAKER
FULL VIDEO
this slider can slide in curve and innovative way
Supplies:
Step 1: Metirials for Firs Steps
see my video tutorial:
take 8 brass pipe t connetors 1/2
"complete video here
and many small ball bearings
Step 2: Press Ball Bearings
use the vise to press the ball berings in place
Step 3: Gears Assembly
gears assembly. plexyglass base.
4 big ball bearings.
long stainless steeele screws
opposite movement of the gears.
Step 4: Cut Pipe Connectors Shorter
cut pipe connectors shorter
Step 5: Add Long Pipes
add long pipes
Step 6: Final Result
the slider can slide like a regular slider. or can be used to make a narrow or large curve.
so i can keep the subject in the center or slide around
see video test and tutotorial here:
Make it Move Contest
Second Prize in the
    • Woodworking Contest
      Woodworking Contest
    • Fandom Contest
      Fandom Contest
    4 Discussions
    markzu
    11 months ago
    What a great build!
    I'm very interested how you came up with this deign, how it works and how you worked out the arm lengths, pulley dia/teeth ratios etc.
    Would be great if you could post here or contact me direct. Thanks!
    Yonatan24
    1 year ago
    Great to see you here on Instructables too! :)
