How to Make a Delicate Red Flower Choker Necklace With Seed Beads and Glass Beads
3,186
48
About: Hi, guys!! I’m Daisy. I love putting beads together to make jewelry work; sharing jewelry designs. If you like jewelry and beads, you are in the right place. I’ll regularly update new jewelry tutorials about...
Today’s tutorial will show you how to make a very beautiful seed bead choker necklace, if you are fond of beaded choker necklaces, you shall never miss this one.
Step 1: Supplies Needed to Make This Beaded Choker Necklace:
4mm Red Seed Beads
2mm Red Seed Beads
2mm White Seed Beads
2mm Golden Seed Beads
8x6mm Faceted Red Glass Beads
2mm Silver Crimp Beads
Silver Bead Tips
Red Nylon Thread
Silver jumprings
Silver Spring Clasp
Long Nose Pliers
Scissor
Step 2: Make the Basic Unit of the First Flower Layers
1st, prepare a long piece of red nylon thread, slide a silver crimp bead, a bead tip, a 2mm white seed bead, two 2mm red seed beads, a 2mm golden seed bead, two 2mm red seed beads, two 2mm white seed beads, a 4mm red seed bead, a red glass bead, a 4mm red seed bead, and twelve 2mm golden seed beads onto the thread;
2nd, cross the thread through the 4mm red seed bead, red glass bead, and 4mm red seed bead pattern, just like the following picture shows;
3rd, tighten the thread to finish the first basic flower layer;
4th, keep adding beads in the same way.
Step 3: Finish All the First Flower Layers
1st, repeat step 1 to finish all 16 flower layers;
2nd, slide two 2mm white seed beads, two 2mm red seed beads, one 2mm golden seed bead, two 2mm red seed beads, one 2mm white seed bead, a sliver bead tip, and a silver crimp bead onto the thread;
3rd, cross the thread back through the previous beads like picture shows.
Step 4: Make the Basic Unit of the Second Flower Layers
1st, add two 2mm white seed beads, three 2mm red seed beads, one 2mm golden seed bead, one 4mm red seed bead, one 2mm golden seed bead, three 2mm red seed beads, and two 2mm white seed beads onto the thread and cross the thread through the third to fifth golden seed bead of the first flower layer;
2nd, tighten the thread to make a seed bead flower petal;
3rd, add two 2mm white seed beads, three 2mm red seed beads, one 2mm golden seed bead, one 4mm red seed bead, one 2mm golden seed bead, and three 2mm red seed beads onto the thread, and cross the thread through two 2mm white seed beads of the first petal and a 2mm golden seed bead of the first flower layer;
4th, tighten the thread to make the second seed bead petal.
Step 5: Finish the First Pattern of the Second Flower Layers
1st, repeat step 3 to finish all the five seed bead flower petals;
2nd, once all five petals are finished, cross the thread back through the nearby seed beads like picture shows;
3rd, add two 2mm white seed beads, three 2mm red seed beads, one 2mm golden seed bead, and a 4mm red seed bead onto the thread, and cross the thread through the golden seed bead on the last petal.
Step 6: Make the Second Pattern of the Second Flower Layers
1st, tighten the thread to connect the first and second pattern;
2nd, add three 2mm red seed beads and two 2mm white seed beads onto the thread and cross them to the nearby golden seed beads like picture show;
3rd, tighten the thread to finish the first petal of the second flower;
4th, make the other four petals of the second flower in the same way.
Step 7: Finish All the Petals of the Second Flower Layers
1st, repeat step 3 to step 5 to finish all the second layer of the 16 flower patterns;
2nd, cross the thread back through the last few seed beads like picture show;
3rd, cross the thread through the lass petal like picture shows, and then add five 2mm golden seed beads onto the thread.
Step 8: Make the Basic Unit of the Third Flower Layers
1st, tighten the thread to make a tiny golden seed bead petal;
2nd, add two 2mm golden seed beads to connect the nearby two petals together;
3rd, add five 2mm golden seed beads onto the thread, cross the thread golden seed beads and 4mm red glass bead on the second petal, then tighten the thread to make the second tiny golden seed bead petal.
Step 9: Finish the Third Layer of All the Flower Patterns
1st, repeat step 7 to finish all the third layer of the first flower pattern;
2nd, cross the thread through the connecting beads to the second flower pattern;
3rd, finish all the third layers of the flower patterns in the same way.
Step 10: Complete the Red Seed Bead Choker Necklace
1st, cut off extra thread and close the crimp beads and bead tips;
2nd, add a spring clasp to one bead tip and a jump ring to another bead tip.
Step 11: Here Is the Finished Seed Bead Choker Necklace:
It might take a while to figure out the arrangement of beads to make the flower patterns, but all the 16 patterns are the same, you just need to learn how to make one flower and how to connect two flowers together, then you can easily finish this delicate beaded choker necklace. Don’t you want to give it a try?
    • Fat Challenge
      Fat Challenge
    • Jewelry Challenge
      Jewelry Challenge
    • Pie Contest
      Pie Contest
    2 Discussions
    DasiyDDIY KING 00
    Reply 2 years ago
    Thank you, you also can have a nice try!
