How to Make a Festivus Pole
12,305
32
18
About: My name is Jason Poel Smith I am a Community Manager here at Instructables. In my free time, I am an Inventor, Maker, Hacker, Tinker, and all around Mad Genius
Festivus is just around the corner. So to prepare, I am going to show you how to make a simple Festivus Pole.
Before we get started, you might be wondering "What is Festivus?" and "What is a Festivus Pole?"
Festivus is a holiday that was popularized by the American sitcom Seinfeld (Season 9 Episode 10 "The Strike"). It is celebrated on December 23rd. The holiday is promoted as "an alternative to participating in the pressures and commercialism of the Christmas season." One of the central elements of a Festivus Celebration is an unadorned aluminum pole which has been appropriately named the Festivus Pole. The Festivus Pole serves as a counter part to the traditional Christmas Tree. However, it is not decorated and there are no presents. It is just admired for its simplicity.
Here is how to make one.
Step 1: Materials
Here are the materials and tools that you will need to complete this project.
Materials:
An Aluminum Pole
Scrap pieces of 2 x 4
Tools:
Wood Saw
Wood Glue
Hole Saw (with a diameter that is slightly larger than the base of the aluminum pole)
Clamps
Pencil
Step 2: Selecting the Aluminum Pole
A Festivus Pole can be made from any kind of aluminum pole. You can use anything from an aluminum broom handle to an Aluminum Fence post. You can just look around your local hardware store to see what you can find.
If you want to accurately recreate the pole used the Seinfeld episode, you will want a pole that is about 2 inches in diameter and about 6 feet long.
I chose to use a 2" Aluminum flag pole. These are typically sold in sections that can be fit together to make any length that you want.
Step 3: Cut the Sections of 2 X 4 for the Base
To hold the pole in place, I constructed a simple base from scrap pieces of 2 x 4. For this, I chose a simple x-frame design (sometimes called a "Charlie Brown tree stand").
To make the stand, I cut two pieces that were about 20 inches long and two pieces that were 3 1/2 inches long.
Step 4: Mark and Apply Glue to the Overlapping Sections
Stack the pieces of 2 x 4 together in the way that they will be assembled. Then use a pencil to mark the sections of wood that overlap. Take your favorite wood glue and apply a generous amount to these areas.
Step 5: Fit the Pieces Together and Clamp Them
Fit the pieces of 2 x 4 together as shown. Then clamp the boards together at each glue joint. Some glue may be squeezed out when the boards are pressed together. You can just wipe this off so that it doesn't leave a trail of dried glue on the outside of your stand. Allow the glue to dry overnight to fully cure.
Step 6: Drill a Hole in the Stand for the Pole
Next you need to use a hole saw to cut a hole in the stand for the aluminum pole to fit in. The pole that I am using 2 inches in diameter. But the base of the pole is 1 7/8" in diameter (this lets you fit multiple sections of the flag pole together). So I used a hole saw that was also 1 7/8" in diameter.
Because my hole saw was not long enough to cut all the way through both boards, I needed to cut the hole from both sides. To make sure that the holes line up, I first drilled a pilot hole all the way through both boards using the hole saws pilot drill bit. This gave me a common guide for both holes. When cutting with the hole saw, I alternated between the top and bottom sides so that the holes met evenly in the middle.
Step 7: Assemble the Finished Festivus Pole
Once the hole is cut, you can insert your aluminum pole. If you have tall ceilings and would like to make your Festivus Pole taller, you can add additional flag pole sections to achieve the desired height. All the pieces should be loosely fit together to make them easier to disassemble after the Holiday.
Step 8: Celebrate Festivus!
Place your Festivus Pole in a prominent location and you are ready to celebrate Festivus.
Other activities that you can participate in to celebrate Festivus include Festivus dinner, the Airing of Grievances, Feats of Strength, declaring Festivus miracles, or watching "The Strike" (Season 9 Episode 10 of Seinfeld).
Festivus Dinner: In the Seinfeld episode the dinner was a generic meatloaf. But it can be anything. What matters is that the whole family is together.
The Airing of Grievances: At the end of Festivus Dinner comes the Airing of Grievances. This is when each person takes a turn expressing all the ways that they have been disappointed by something in the last year. This is sometimes focused on ways that the other attendees have disappointed you, but many people avoid this in an attempt to keep the event less hostile.
Feats of Strength: After dinner and the Airing of Grievances is completed, the evening is concluded with the Feats of Strength. In this event, the head of the household challenges one of the attendees to a contest of Strength. In the episode, the feat of strength was a wrestling match. However many people substitute a simpler challenge such as thumb wrestling. Festivus is not over until the head of the household is defeated at the selected challenge.
Festivus miracles: Throughout the holiday, it is common to declare any minor coincidence as a "Festivus Miracle." This is most often intentionally absurd and serves to help participants better appreciate the random coincidences that are constantly happening around us.
Well. I hope that you will make your own Festivus Pole and join in the celebrations this December 23rd. Happy Festivus Everyone!
    • Epilog X Contest
      Epilog X Contest
    • Cardboard Challenge
      Cardboard Challenge
    • Warm and Fuzzy Contest
    18 Discussions
    CaptCyn
    Tip 6 weeks ago
    While your wooden base looks awesome yet is still minimalist in the Festivus tradition, we took a flag pole like you suggested and just put it in a coffee can of cement. You can even mix the concrete mix with water right in the coffee can. Just thought I'd offer that suggestion to others who might not have a drill or scrap wood. :)
    gulux
    4 months ago
    I've never seen this TV show, but what you say about "Festivus" makes perfect sense to me. :)
    Braydenku
    7 months ago
    This is a very useful and funny project, I actually celebrate festivus
    every year.
    muhammajunaid
    2 years ago
    Hi Jason poel,
    I just have a question about the instructables app.
    Is there a way to browse question and answers in the app, we can do it in the web but I could not find a similar option in the app.
    thanks
    Junaif
    katvanlew
    2 years ago
    We made a Festivus pole very similar to this one. During the rest of the year you can add some coat hooks to the top of the pole. Attach them with poster putty, then tightly wrap a couple of zip ties around them. It will be very handy and functional.
    A very Happy Festivus to you and yours!
    Cats Dragon
    2 years ago
    I am sorry that I have not heard of this holiday sooner.(maybe because I have no TV access, my choice. Just get movies from the library.) This sounds like my kind of holiday. Happy Festivus to all!
    2stoned2see
    2 years ago
    Festivus for the rest of us heathen that dont partake in the holiday season.
    offseid
    2 years ago
    Well done, sir!
    jdonato
    2 years ago
    Happy Festivus 2016 to everyone!
    jdonato
    2 years ago
    mtobin4
    2 years ago
    I acquired my festivus pole from the local steel/metal supplier. asked for the cheapest aluminum pole about 2 in diameter and about X tall. it sits in a Christmas tree stand. I like the look of the wood stand. I may make one. It's a festivus miracle!
    Mollysmama
    2 years ago
    too funny, thanks
