How to Make a Five-in-One Mini Wood Working Machine
78,215
729
39
About: Makeblock was founded in 2012 as the world's first open-source robot and programing platform. With more than 400 mechanical components, electronic modules, and software tools, we are determined to bring mean...
Recently,I found myself so into wood making. Therefore, on the 18th Maker Marathon of Makeblock holding on Nov. 28th, I decided to DIY a mini wood-working machine which covers the functionalities of the lathe, drill machine, a milling machine, grinder, and sawing machine.
Most parts are from: http://www.makeblock.com/
Supplies:
Step 1: Assemble the Crank.
Using threaded rod to drive the thread-drive beam, the crank comes with high precision;
Step 2: Assemble the Motion Platform of Y-axis
Step 3: Assemble the Motion Platform of X-axis
Step 4: Assemble the Motion Platform of XY-axis
Step 5: Assemble the Accessories for Lathe and Milling
Step 6: Assemble the Support and Stand
Step 7: Install the XY-axis Platform on the Stand
Step 8: Assemble the Bracket for the Spindle Motor.
I drilled an extra hole on the beam to fit them tightly
Step 9: Assemble the Brackets for the Guide Rail
Step 10: Install the Guide Rail and the Motor Bracket of the Main-axis
Step 11: Install the Compression Bar
Step 12: Install the Spindle Motor and Driver Board.
What I used was 555CNC motor with 24V power supply
Step 13: Assemble the Circuit Board and the Motor on the Rack.
Now the assembly has been accomplished!
Step 14: ​Last But Not Least
You can assemble various tools on the motor for processing different kinds of materials, like wood, Acrylic plates, glass fiber board, etc.
To avoid any injuries when the saw blade accidently flies out, it’s required to install a cover plate when use this 5-in-1 machine as a sawing machine.
Step 15: All Parts I Used
Step 16:
    • Classroom Science Contest
    • Arduino Contest 2019
    • IoT Challenge
      IoT Challenge
    39 Discussions
    Cration
    3 years ago
    I calculated the prices. It is about $300, the screws and nuts not included.
    arowe3Cration
    Reply 3 years ago
    $300 not bad! less than what I have wrapped up in my RC Tuck.
    arowe3
    3 years ago
    I'm so going to build one when I get some spare change. Even if I use it once, and just to have it sitting pretty. It's a cool piece of machinery. Sort of like my RC Revo truck....just a sexy big ol nitro powered beast with horizontal shocks. Good job on the craftsmanship.
    bricabracwizard
    3 years ago
    You can use a diamond blade (take out the saw blade) for tile cutting.....mosaics. They have blades as big as your saw blade. Nice build!
    Kreat0r
    3 years ago
    good one!
    I ll build this!
    spryor71
    3 years ago
    In all seriousness, I'm curious why the right thumbnail is left so long?
    jpratt1701spryor71
    Reply 3 years ago
    Left hand fingernails short, right hand long = fingerstyle guitar player.
    Crationjpratt1701
    Reply 3 years ago
    Haha... I'm learning guqin recently. It's a seven-stringed plucked instrument.
    spencer.dai.3Cration
    Reply 3 years ago
    Awesome. perhaps you can build a "Guqin player" by using Makeblock parts.
    spryor71WV_Kokamo_Joe
    Reply 3 years ago
    Aaah yes!, I can see the "wire stripper" over guitar player.
    bungee-
    3 years ago
    Well as I calculated from online prices that is ~ $440 without PP. Unless there is a kit available with all the parts. A bit pricey if you ask me. But still looks good.
    onedumbtruckeronedumbtrucker
    Reply 3 years ago
    My mistake, the bushing blocks are for 8mm shaft but the bearing blocks are still cheaper if the bolt hole pattern is the same.
    treymartin82
    3 years ago
    What was your supplies cost and about how long did it take you to make this?
    Crationtreymartin82
    Reply 3 years ago
    I haven't calculate the cost yet. It was a "Makerathon" (something like a hackathon, but with more mechanical and electronic stuff) and it spent my partner and me about 20 hours.
    pmshah
    3 years ago
    Turning the speed controller counterclockwise to increase speed ? This is a first for me.
    bongodrummer
    3 years ago
    Nice. Could you could rig up a mini tool rest for when you use it as a lathe? Even a micro lathe would be easier to use accurately with a tool rest, right?
