How to Make a Japanese Bokken
50,041
206
33
This instructable will teach you how to make a good japanese bokken.
Supplies:
Step 1: Gather Materials
Two 3/4-by-1-1/2 inch white oak or maples, cut 42 inches long
Hammer
Stain
Paintbrush
Wood glue
Clamp
Planer or sand paper
Saw
Wood chisel
Step 2: Make the Blade
Join the 2 pieces of wood together on their 1-1/2-inch sides with wood glue. Coat the wood with wood glue so they are connected all the way down the blade. Clamp the wood together until it dries. Let it dry for about 4 hours. Remove any excess glue around the edges.
Step 3: Sand the Edges
Plane or sand the wood until you have a 1/8-inch bow in the center of the board. Cut the sides of the boards down to 1 1/8 inch. Plane or sand the Bokken until the sides are smooth.
Step 4: Make the Edge on the Blade
Cut the sides and ends of the sword with the router to make a 1/2-inch round edge.
Step 5: Angle the Blade
Use the chisel to angle the end of the blade to 45 degrees. Sand the rough edges until the wood is smooth.
Step 6: Stain and Let Dry
Apply 2 coats of stain and allow it to dry. If there are any rough edges after the first coat of stain, sand them down before applying the second coat.
    • Party Challenge
      Party Challenge
    • IoT Challenge
      IoT Challenge
    • Gardening Contest
      Gardening Contest
    33 Discussions
    Necrojoker
    10 years ago on Step 6
    Agreed, more pictures would be nice. Also...why did you glue two pieces of wood together? I know wood glue is strong, but I would think that having a glue core would weaken the blade considering the striking direction... Yeah...Not so sure about this one. I'd think it would be much easier to use a 1" thick piece of wood that has been planed, draw the shape of the blade, cut with a jigsaw, router all the edges needed, sand to a smooth finish, then stain or oil the entirety of the bokken for the perfect finish. NEVER use a laquer or paint unless your bokken is for show. The oil strengthens the wood and allows it to breath. Using a paint or other such finish will cause the bokken to be less than durable for 2+ person kata.
    StephanS10Necrojoker
    Reply 3 years ago on Step 6
    it seems most bokken made to represent katanas are made with two pieces of wood. i assume it's just tradition.
    jmscnny.StephanS10
    Reply 2 years ago
    I have had a bokken for about 30 years that was made from a single piece of Japanese white oak. It is pretty banged up, but still in one piece. I have never encountered one made from two pieces of wood, I have to admit that I have never made a study of the traditional manufacturing techniques, but it was made in Japan.
    Camisado
    10 years ago on Introduction
    This is a very good I'ble! 5 stars! P.S: Although the method you used in describing this is cool and all, but try not to use boards for your bokken. That thing is so fragile and sucks more than pine ( well, the bad ones ). Bokkens are meant to be used for full combat practice or Kendo, so use hardwood instead of boards. But, nice job!
    CamisadoRye2121
    Tight-grained pine will also work, but since most pines are not tight-grained, this can be hard to fine. Although Oak, Maple, Balsa, Hickory and all other hardwood works better, I just made a European Knight sword Bokken using tight-grained pine, and it works pretty well, and it also lasted a good couple of hard whacks. It will be dented a bit, but most of my pine swords recover from their dents when exposed to sandpaper ( I wonder why ).
    raven0811Camisado
    did you say... BALSA? as in lightweight, flexible BALSA used in making model airplanes BALSA??
    GINJA NINJA
    nice, but I don't understand why you use two bits of wood, it would be stronger if it was just one piece wouldn't it?
    greenjedi
    wouldnt planing make it easier to break than if you had curved the wood? with a curved one the grain of the wood flows from end to end. with this method it's just cut, i could see half of it snapping off after striking something. unless of course you just intended this as an aesthetic piece, in which case, nevermind, lol.
    yourworstnightmare
    9 years ago on Step 6
    could u plz add how to make the wrap that is around the handle anda sheath?also very nice instructable!
