How to Make a Match Cube
97,272
1,141
59
I show how to make a cube of matches. It is pretty simple once you get through the first few steps. After that it’s very repetitive. Matches are cheap so it is inexpensive to make, I spend $2 for 2 boxes of 250 matches each and ended up using about 294 with about 37 damaged or misshapen. This does not really have any practical purpose just an interesting way to store or display your matches. It is made without any glue or tape, just interlocking matches.
Step 1: Materials
-Wooden Matches (About 300+)
-Time (It is rather time consuming)
Step 2: Watch the Video
http://youtu.be/3te7E51Xf4U
(The video may not show up for mobile viewers)
Lighting one on fire.
4 People Made This Project!
  • Trash to Treasure
    Trash to Treasure
  • Gardening Contest
    Gardening Contest
  • Arduino Contest 2019
59 Discussions
orioza
11 months ago
I made one with the matchsticks and decided I wanted something a little safer, wouldn't want some accident to set the cube on fire when I least expect it.
Presenting the Nail Cube. I used 2.5" nails to make this and it weighs about 1.1kg per cube.
oriozaorioza
Reply 11 months ago
In case, you would like to make one.
1 lesson learnt is that due to the cross section and weight of the nails, it is actually quite impossible for the cube to remain stable after the rubber bands are removed, any disturbance would cause the cube to dismantle on its own.
My trick was to dunk the whole cube in lacquer, so the lacquer protects the nails from rusting and also glue the whole thing together.
erik984
2 years ago
this is awsome
slu6alka
3 years ago
Wow, this is incredible! I made something similar a few years ago, but I used less sticks...and then I burnt it :) Can't wait to try yours, thanks for sharing!
viral1997slu6alka
Reply 3 years ago
@slu6alka can u pls send one more pic of the othr side.? or cann suggest some steps to proceed.
Thank you Vmuch.
AnnaL64slu6alka
Reply 3 years ago
Where did you get those blue matches?!!!!
slu6alkaAnnaL64
Reply 3 years ago
I bought them from LIDL... they have some stores across Europe, not sure about the other continents.. Here's their global site: http://www.lidl-info.com
IndigoOnion
Reply 3 years ago
*slow applause*
SidA2
3 years ago
I was scared in your video that when you burn it, the rubber band will melt and the cube would somewhat explode... good thing that the band isn't needed to make it stay in place :D
SidA2
3 years ago
sgerevini
3 years ago
I *need* to make it!!!
jimofoz
3 years ago
Strange, but cool, er - hot...
needledoc
4 years ago
I only see a video showing how to light it on fire. Where are the instructions people are talking about on how to make it? I already know how to light matches on fire, that's what they are designed to do.
BrianM172
3 years ago
Oof... Make a hut outa this... Mabe put like safety pins for holding the ceiling together? It could be like a treehouse on the ground... And once it gets cold, light it up!
azizkres
3 years ago
Awesome! I don't think I will make one myself, at least not anytime time soon, but it's great seeing it :D
Boomdog02
3 years ago
i think the first step should be : have lots of free time on your hands and be really bored...like during baseball season!
Two hours later..... I DID IT!!!
I was scared to cut the elastics :-)
Good tuto.
(FR)
63445_867290336634523_6583828640701766379_n.jpg10468058_867290376634519_5604425294391486026_n.jpg10731126_867290349967855_4257418784637040206_n.jpg
