How to Make a Mini Cannon From a BBQ Lighter
132,872
847
237
About: I like turning boring things into awesome things! Usually on video.
This is how to make a mini combustion cannon sized to fire airsoft pellets. The only materials required are a BBQ lighter, a few screws, epoxy or other strong glue, and a drill.
2 People Made This Project!
  • Leather Challenge
    Leather Challenge
  • Jewelry Challenge
    Jewelry Challenge
  • Pocket Sized Contest
237 Discussions
Evilcrickett
1 year ago
Um... Can any see this instructable anymore? All I see is this is haw to make mini cannon... Then the download box (I'm not premium) then comments no directions
135811
2 years ago
For my experiment, I have much larger objects that I am propelling instead of airsoft pellets, and I was wondering when you use the exact model of BBQ lighter, could you expand/ enlarge the size of the tube hole so it would be large enough to fit a marble? Thanks!
135811
2 years ago
May I use this for an experiment I'm doing? I'm testing something, and I came across your video and think having a small, hand-held cannon would work best for my experiment.
Sedgseb123
2 years ago
can aerosol be used
Sedgseb123
2 years ago
what is the range
MuktaB
3 years ago
Can we useperfume
MuktaB
3 years ago
Which is liquid used for shooting?
Nathair
7 years ago on Introduction
Ok I'm srry to burst all ur little bubles but one contrary to watnighthawklight said adding oven a miner amount to much fluid nomatter what u use for fuel it could still blow up I know because my little brother was killed when one blow up in hi hand oh and I've taken these kinds of weapons of inmates at my prion that have been used to kill people and are illegal nomatter what they shoot
KJenkinsAFNathair
Reply 4 years ago
I'm sorry your little brother was killed. However, as to the illegality issue. Illegal in prisons yes, by non-felons not incarcerated no.
tato312
Hey, im building this cannon but im using lighter fluid as the fuel for it.
The thing is that I cant get it to ignite. There's a spark and everything, but it just wont ignite. Ive tried using more fuel but still nothing happens.
But when I take the rear bolt out and light the cannon with another lighter.. BOOM!
A lot of fire
I dont know whats wrong... Can someone help?
Thanks
CurtRtato312
Reply 4 years ago on Introduction
Lighter fluid will not work because it doesn't vapourise to give an explosive air/fuel mixture. That's why alcohol, hair spray and ether are best.
Pfarmkidtato312
you might be adding to much gas it also it is a bit harder to make lighter fluid ignite unless its a steady stream of gas
