How to Make a Mini USB VACUUM CLEANER
10,318
197
6
About: https://www.youtube.com/dashboard?o=U
How to make a mini USB VACUUM CLEANER part 1
How to make a mini USB vacuum cleaner part 2
Supplies:
Step 1: To Do a Mini USB Vacuum Cleaner You Need!!!
In today's video I'm going to show you the next idea of crafts and home made things, actually how to make a mini USB vacuum cleaner with your own hands at home!
Step 2: It Is Very Easy to Make a Mini USB Vacuum Cleaner With Your Own Hands, But It Takes a Bit More Time to Construct It!
Step 3: With the Help of the Simplest Hand Made USB Vacuum Cleaner You'll Be Able to Remove Some Rubbish From Your Key Board (crumblings, Dust Etc.)
Step 4: The Mini USB Vacuum Cleaner Can Help You After You Have Painted or Drawn the Sketch for Removing the Eraser Bits.
Step 5: Step by Step!
Step 6:
Step 7:
Step 8: All Parts of the Miniature Hand Made USB Vacuum Cleaner You May Construct From the Make-shifts at Home!
Step 9: The Construction of the Miniature Hand Made USB Vacuum Cleaner Has a Little Deference From the Real Vacuum Cleaner, As the Air Is Sucked Through the Turbine As Well!
Step 10: Good Luck in the Creativity and Watch With Pleasure!
    • Classroom Science Contest
    • Party Challenge
      Party Challenge
    • Gardening Contest
      Gardening Contest
    6 Discussions
    revanth001
    3 years ago
    where we goin to cut the sheet of tin can u plz give a solution
    totemgoatrevanth001
    Reply 3 years ago
    tuna can? you'd have to flatten it in a vise or something if it has surface bumps though
    loboat
    Reply 3 years ago
    I already reported his video on YouTube. Except that, that's all I can do...
    loboat
    3 years ago
    Can I ask you a question romanursuhack ?
    Akin Yildiz
    3 years ago
    wow this is very creative
