How to Make a Solar Powered Walkway
891,416
2,067
289
About: depotdevoid is short for The Depot Devoid of Thought, the place where you go when you lo...
I sure loves me some sun jars!  They incorporate several of my favorite things to mess around with:  LEDs, Solar panels, hot glue, man it's all there and they look great to boot!
However, there is one big fat problem:  the sun!  When it's dark out, oftentimes the places I'd really like to have a little extra light are just the spots you can't leave a sun jar due to lack of direct exposure to sunlight.
The obvious solution to this dilemma is to separate the solar panel from the sun jar.  I extrapolated this a bit further and realized that the only thing you actually need in the jar is the LED, and since you don't have to cram all the other electronics in there, you don't have to stay with the classic sun jar shape.
With this in mind, I combed craigslist for some suitably shaped glass blocks, went to Home Depot for the appropriate solar light, stocked up on speaker wire and came up with the Solar Powered Walkway!
***UPDATE 5/5/10:  If you build this project yourself, or something similar, post some pictures and I'll send you a patch!***
****UPDATE 1-1-11
If you are the first person to post a picture of your completed light-up walkway to the comments, I've got a 3 month pro membership to instructables that's all yours!
Step 1: The Walkway
Here is the little path that goes from my driveway to the front door.  I decided this was the best place to put the lights, mostly because I wouldn't have to move a bunch of concrete, but also because I'd get to walk the path each night when I came home from work.
I figured I'd put one of the glass blocks in the path first just to see how it would look during the day.  I dug a little hole, just a bit deeper than the end result would be.  I poured a little fine gravel into the bottom of the hole, so you wouldn't just be looking at dirt through the glass.  I filled it back in around the block, and left the top just a bit higher than the surrounding gravel, as I figured it would settle out a bit.  Everyone who saw it thought it looked nice, so it was off to the next step.
Step 2: Solar Power!
I found these awesome solar lights designed to clip on to a patio umbrella at Home Depot for about 8 bucks.  I decided to go with these because the solar panel was separable and the batteries drove six separate LEDs.  If I'd used the standard solar lights it would have meant six little solar panels and a lot more wires running around.
I separated the solar panel from the battery/circuit board case and extended the wires that connected them.  The panel went on my roof just over the front door (see picture) and the battery case went under my newspaper box, with wires running discreetly along the corners and the edge of the window.
****Edit 1/30/10:  It has been brought to my attention that this type of light is no longer available, at least for less than $60 each anyway!  Here are a couple of possible alternatives I'm thinking about trying out for the path I'm going to build for my brother:
http://www.dealextreme.com/details.dx/sku.5501
http://www.dealextreme.com/details.dx/sku.7491
http://www.amazon.com/Designers-Edge-L-949-Rechargeable-Solar/dp/B0013HPNRY/ref=sr_1_fkmr0_1?ie=UTF8&qid=1264605147&sr=8-1-fkmr0
***Update 4/26/10  --  User Candor has pointed out this alternative to the lights I used, looks like it might be a good one:
http://www.ikea.com/us/en/catalog/products/70177439
***Update 3/2/11  --  IMPORTANT  --  Looks like the IKEA link above is dead, here's a new option from their website:
http://www.ikea.com/us/en/catalog/products/70200939
Also, I did a quick amazon search that revealed some possible good options for this project.
I just want to say that I don't recommend the dealextreme lights for the walkway project, they were a bit dimmer than I would like for this.  They worked out well for the bottle lights instructable I did, but I don't think they'd be so good for this one.
7/30/12 -- IMPORTANT UPDATE
I don't recommend ANY of the christmas light options for this, they are all too dim. All of the other links above are dead or useless . . .
*** Update 5/8/13  --  Thanks to Liv Laster and wickedq for some more suggestions for solar lights!
http://www.reusablerevolution.com/
http://www.rakuten.com/prod/solar-powered-outdoor-beach-pool-and-patio-umbrella-led-light/246976804.html?listingId=264737107
http://www.northerntool.com/shop/tools/product_200514205_200514205  <--- I particularly like this one
http://www.kmart.com/smart-solar-san-rafael-solar-string-light-20/p-07129475000P?prdNo=43&blockNo=43&blockType=G43
http://www.walmart.com/ip/Smart-Solar-Solar-30-Piece-Crystal-Ball-Light-String/21397504?findingMethod=rr
Step 3: Get to Work!
Crack open the solar lights and separate the panel from the body. There are three wires that connect them, so measure the distance from where you'll be mounting the panel to where the body will be mounted, and then add several inches. Extend the three wires by that amount.
Within the body of the light, unsolder the LEDs and replace them with about 6-10 inches of speaker wire. Make sure to seal everything up well with epoxy or silicone! Mount this whole assembly on your house first, make sure it works, then prepare your glass blocks. I used epoxy (because I'm an idiot) to mount the panel to the roof and the body under the paper box, and then stapled the wires in place.
At the corner of each of your blocks, mount an LED of your chosen color, tack it in place with hot glue, then cover the whole shebang in epoxy or silicone. Make sure you leave the leads exposed!
Update 8-3-14: It's been mentioned in the comments that speaker wire isn't really meant for outdoor use--you may want to upgrade to something heavier or use some conduit. Also, silicone might not be the best option for sealing these, as it reacts with solder and copper and could cause problems down the line.
Step 4: Get to More Work!
I marked the spots on my path where I wanted the bricks, and measured the distance from there to the case of the solar light, and added about a foot.  I found out the hard way that I probably should have added more like three feet just to be safe!
Cut speaker wire to these lengths.  Make sure you label them for easy installation later.  Strip the ends of the wires and solder up one end to each of the bricks.  After these are attached, epoxy or silicone any exposed wire or solder.
As described in step one, dig the holes in the path, fill the bottom with gravel, and install your blocks.  In addition, you'll need to dig out a little trench between each block, to run your wires through.  For this reason, I started with the one that was farthest from the solar light, accumulating more wires in the trench with each brick I added.
Eventually I ended up at the solar light and soldered each of the block wires to one of the loose wires installed where the LEDs used to be in the solar light.  Let me tell you, soldering outdoors in the dark is a little bit trickier than doing it at the workbench!  Make sure you coat all your exposed wires in epoxy or silicone to keep the rain out.
When you're done, bury all the wires, flip the switch, and enjoy your Solar Powered Walkway!
Step 5: Final Thoughts
I guess the one downside (if you see it as a downside) to having a glowing path in front of your house and visible from the street is that it seems to draw in weirdos like moths to a flame.  I have on two separate occasions gone out of my garage for a smoke and caught someone on the path--one guy was just standing there staring, and one lady (who was in her forties and clearly on LSD or maybe extasy) was hopping from brick to brick.  On the other hand, everyone oohs and aahs over it when they come to visit and I like walking on it, so on the whole it's a good thing.
This was one of the first electronics projects I did after we bought our new house last spring.  I'd been moving and unpacking and fixing up little things for a month and a half and was just sick of neglecting my more eccentric hobbies, so this was a nice entry back into doing strange things with multicolored lights. I haven't posted it until now because I had other projects going, and then somewhere during the month of October while I was busy making my proton pack extra awesome, a big wind storm came through and knocked the solar light out from under the newspaper box, banging it up a bit.  It's still attached, but the lights don't work all the time.  I finally rigged up some battery power for the lights so I could take some decent pictures of the path.  My plan is to either repair it or replace it with one of the other ones I picked up.  I hope I can repair it, as I'd like to add more lights around the yard once I've done more with the landscaping.
As always, thank you for looking!  Please take the time to leave a rating and a comment, they are always appreciated.  I would also love to see pictures if you decide to make something like this yourself.  If you post your pictures in the comments section, I'll send you a DIY patch!
****UPDATE 1-1-11
3 People Made This Project!
  • Trash to Treasure
    Trash to Treasure
  • Tape Contest
    Tape Contest
  • Arduino Contest 2019
289 Discussions
I have a suggestion for waterproofing the connections. They make plastic shrinkwrap sleeves for waterproofing electric connections. Just slide tube over wire BEFORE soldering them together. After soldered just use hairdryer to shrink the cover and it will be waterproof. It also will not react with the solder or wire as it is meant for electrical connections. Hope this helps everyone.
They also sell tape that is for under water use. It's made by 3M u can get it at a part store. It comes in a box good stuff.
Quiggley
Question 1 year ago
I like the potential of this project. Any chance of you updating/re-writing it taking into consideration reader tips and where supplies can be found now in 2018? Thanks.
1 answer
depotdevoidQuiggley
Answer 1 year ago
That's not a bad idea! I never really considered the longevity of this project when I first wrote it up.
Pa1963
Tip 1 year ago
Use wire for Malibu lights.
lilmagill
1 year ago
Can you actually walk on the glass blocks like stepping stones? Will they break?
depotdevoidlilmagill
Reply 1 year ago
Yeah these blocks are pretty sturdy. The real issue is slippage, if they're even a little wet they become really slick!
edelaex
2 years ago
You're surely bored...
elsiecamping
4 years ago on Introduction
I love this project. Its so pretty to look at and who doesn't love lights around the yard that free. I love LED's and Solar ANYTHING. Great Job.
CindyH117depotdevoid
Reply 2 years ago
What type of glass brick is this and where can u get some like that ? I would love to try this idea .How u did it ?
ChadH33
3 years ago
At this point you could just buy some LED's off ebay and wire them to a low voltage transformer with a timer for probably $20.
VartraA
3 years ago
A few cheap, but reasonable options (If you don't mind the extended shipping, usually around 6 weeks) for solar panels, some with battery packs attached, some you'd need to add one to. I'm linking just the search page followed by two I'd suggest.
https://www.wish.com/geek/m/search/Solar%20panel
https://www.wish.com/geek/m/c/55d44f835bde3a1063e6da12
https://www.wish.com/geek/m/c/56068769f195a44f1270ae37
JenniferK72
3 years ago
Not the best pic but i just used weed liner and layed the blocks over a 16 foot lenght of solar rope lights then fill around it with rubber mulch
depotdevoidJenniferK72
Reply 3 years ago
Very cool, thanks for sharing! Patch and pro membership are on the way!
JenniferK72
3 years ago
I made a similar project but just used a16ft solar rope light
JamesKB2
3 years ago
I have a few ideas here. One, use a small diamond bit to create a hole in the glass block and insert the LED into it then seal it with a high quality polyurethane sealant. Two, paint the perimeter edge and perhaps even the bottom of the glass block with while spray paint to create a 'light box' effect, which would illuminate the top surface very well.
CarinHJamesKB2
Reply 3 years ago
I think that would give a different look, more "light fixture" and less "glowing glass." By placing the LEDs directly against the glass, the light travels through the glass, rather than emanating from the space inside it.
