How to Make a Wooden Laptop Stand (Adjustable Angle)
3,252
20
12
About: -----------------------------------------------------------------16 year old, sick with a deadly disease called DIY-itis!-----------------------------------------------------------------Hi FTC! My I'bles con...
I need a laptop stand! I NEED A LAPTOP STAND!
A̶s̶ ̶I̶'̶v̶e̶ ̶d̶e̶c̶l̶a̶r̶e̶d̶ ̶t̶h̶a̶t̶ ̶t̶h̶i̶s̶ ̶i̶s̶ ̶a̶n̶t̶i̶-̶p̶r̶o̶c̶r̶a̶s̶t̶i̶n̶a̶t̶i̶o̶n̶ ̶w̶e̶e̶k̶ ̶(̶k̶i̶n̶d̶ ̶o̶f̶!̶*̶)̶, I thought I would finally make a laptop stand, which Is something I've been needing for so long. This adjustable angle/height laptop stand can be removed easily (I'm not the only user of the laptop I use), and allows me to type FASTER, and with fewer typos, because it's so much more comfortable! It also puts the screen at a more comfortable height, and makes the keyboard backlight actually illuminate the keyboard, instead of me just seeing it from underneath.
Is that not enough? It also helps my laptop keep itself cool!
Let's get started!
(Watch the YouTube video: LINK FOR MOBILE VIEWERS!)
*ᴺᵒᵗ ʳᵉᵃᶫᶫʸ⋅ ᴵ'ᵛᵉ ᵈᵉᶜᶦᵈᵉᵈ ᵗᵒ ᵐᵒᵛᵉ ᶦᵗ ᵗᵒ ᶰᵉˣᵗ ʷᵉᵉᵏ⋅⋅⋅
Supplies:
Step 1: What You'll Need:
Want to make your own laptop stand? Here's what you'll need, or at least what I used!
I made it for FREE since I already had everything that was needed on hand.
Hardware, Materials & Consumables:
Adhesive backed velcro
Wood (European beech)
Screws
Tools:
Handsaw (+DIY Magnetic Handsaw Guide!)
Drill
Drill bit set
Ruler
Subjects: Woodworking
Approximate Time: <1 hour
Difficulty: Simple
ALWAYS USE PROPER PPE.
Step 2: Attach the Velcro!
I decided to use a really nice piece of beech wood that I had for the part that attaches to the laptop, with velcro. I stuck the velcro to the end of the piece of wood, and then flipped my laptop over, and marked the center of its underside. I added the velcro and pressed down onto it for about a minute so it would adhere properly.
Step 3: Cut Off the Excess Wood
Since the piece of wood that I chose was pretty long, I cut off the excess with a handsaw to the length that was needed (or, well, estimated). I cannot live without this homemade life changing saw guide anymore!
Step 4: Make the "legs"
I cut two narrower pieces of beech wood to 13cm long, and clamped one to the side of the piece of wood that I made earlier, to my workbench, as shown in the picture. I drilled a pilot hole at the length of the screw that I was planning on using on both sides and pieces, and then came back and enlarged the pilot hole of each "leg" - without enlarging the pilot of the middle piece.
I used a bigger drill bit to countersink and then drove in the screws just tight enough, while clamping the pieces together, so the narrower piece tightened onto the middle piece when I tightened the screw. Not enough won't hold the weight of the laptop, and too tight will make it so you won't be able to adjust the angle/height of the stand later, or maybe even break the screw or split the wood.
Step 5: DONE! | More Thoughts | Video!
See it in action, on Youtube!
Some more thoughts:
  • If I would make this again, for the piece that attaches to the bottom of the laptop with velcro, I would choose a thinner piece, since it stops the laptop from going down all the way. It isn't that much of an issue, but if it will be, I will just cut off the corner at an angle (I guess that's kind of a bevel...)
  • I think that this makes it harder to type when slouching too - Bonus!
  • Add a phone holder?
  • Add a built in storage container for my flash drive?
  • Add a cup holder?
  • Now that I think of it, this could be turned into a tripod!
I will be giving away free Instructables memberships to members that make their own adjustable angle laptop stand based on this Instructable. Will you be the first one?
Are you following me on Instructables? Join 1000+ members that don't miss my future Instructables by clicking the button! (located at the top of my member page)
On YouTube, I upload quick videos of my projects in action, and more - Subscribe so you don't miss out!
I read ALL comments, and reply to as many as I can, so make sure to leave your questions, suggestions, tips, tricks, and any other ideas in the comments below! - Thanks!
    • Fandom Contest
      Fandom Contest
    • Party Challenge
      Party Challenge
    • Arduino Contest 2019
    12 Discussions
    Yonatan24RiceFlavoredGum
    Reply 1 year ago
    Oh, you were the one that asked me if I could subscribe to your channel on my channel page.
    1. Buying is not the point of this website, so why even ask?
    2. Where did you see a $10 laptop stand?
    3. Why spend $10 when you can make it in 15 minutes?
    RiceFlavoredGumYonatan24
    Reply 1 year ago
    The materials for your stand cost a few dollars. Also, store bought stands are busy finished metal or plastic and yours is rough wood.
    Reply 1 year ago
    Nope, the wood was free, video on that coming soon in a few weeks.
    Yonatan24Yonatan24
    Reply 1 year ago
    Looks like there are some nice, cheap ones on eBay too.
    4DIYers
    2 years ago
    Great work. Keeping a laptop cool is definitely an important thing, mine usually runs quite warm when rendering video.
    Yonatan244DIYers
    Reply 2 years ago
    Thanks, I normally do 3000 things at once, and all the tabs make the laptop heat up like crazy!
    4DIYersYonatan24
    Reply 2 years ago
    Not sure if it's available for a windows laptop. But on my Mac I also have a manual override for the fan so I can control the speed before it gets too hot. Definitely helps out a huge amount besides elevating it too.
    Yonatan244DIYers
    Reply 2 years ago
    I can control how hard the computer will work - something like that. I haven't found it to be really effective, so in the summer, I think I'll put a small computer fan underneath...
    Yonatan24
    2 years ago
    The video is too short by about 0.2 seconds to add an end card, if that explains the black ending of the video...
