Make a Wrestling Ring Bed
12,768
52
18
About: DIY'er, Shop Owner of Wood'n Hooks handmade, Mom, and Wife who loves anything rustic and crafty.
My son wanted a WWE wrestling bed. I couldn't find one on the web so I set out to make my own. I had no clue how I was going to do it but I was determined to make him happy. After I posted his reaction on YouTube I got a lot of requests asking how I made it. So, here it is!
Step 1: Find an Old Bed Frame
I had to cut the head and foot board off of this bed frame to leave just the posts sticking up
Step 2: Make the Post Corners
Cut 4 PVC pipes equal lengths. For this bed they were apx 4 feet tall. I made sure the diameter of the PVC pipes was large enough to fit over the existing bed posts. Top the PVC posts with PVC caps. Slide the PVC posts over the corner of the bed poles. Drill 3 holes equal lengths apart down each pipe where you want the ropes to go. You will install eye hooks in these holes so make sure the hole drilled is the diameter needed for the eye hooks you have.
Step 3: Paint the Posts
Spray paint the PVC pipes black and let dry. Put the PVC pipes back over the bed posts.
Step 4: Add Support
Cut extra 2x2 support strips for under the mattress. Cut 2x8 boards (not pictured) and screw them between the base of the 2 front and 2 back legs. I had to do this step to stable the posts since the support of the headboards were now gone to prevent the posts from bowing in when the ropes were put on.
Step 5: Attach the Hardware for the Ropes
Screw eye bolts in all the holes drilled Before. I used small springs (turnbuckles were too long for a twin bed) and hooked them to the eyebolt. Add a metal ring on the other end to run the rope through.
Step 6: Attach the Ropes
Double over the rope through the 1st ring and tape together well. Run the rope through the other rings all the way around the bed. Repeat this for the other 2 ropes.
Step 7: Attach to the Turnbuckle
Once the rope is all the way around tape it to one end of a turnbuckle and hook the other end as shown. This allows tightening of the ropes and makes it easier to take down the front ropes if wanted.
Step 8: Cover Ropes *Do Not Skip This Step*
Trim excess rope. Cover all the ropes with pipe insulation and tape around each one with electric tape. **THIS IS A MUST TO HELP AVOID CHOKING/STRANGLING HAZARDS**.
This step makes the ropes much less bendable, kind of like a "super duty" pool noodle wrapped in tape. If you try to bend it, it "pops" back straight again to avoid any kind of entanglement.
Step 9: Cover the Springs
Cover the corner springs with pipe insulation also to prevent any "pinching of fingers".
Add an awesome wall graphic too!
Step 10: Make the Turnbuckle Covers
I cut rectangular pieces out of a mattress pad to use as padding for the turnbuckle covers and used vinyl fabric to cover the pads. (The mattress pad was much cheaper than buying foam pieces)
Fold the vinyl around the padding and put eyelets on each corner for the strings to run through to attach them to the posts.
Step 11: Cover the Turnbuckles
Fold the pads over the corner springs and tie.
Step 12: Paint a WWE Symbol on the Fitted Sheet
I painted this emblem in the center of a plain white fitted sheet to give the mattress the look of an official ring. I used a bunk bed board instead of a box spring to keep the mattress low. If you don't have a bunk bed board you can use a large 1 inch board (cut to fit) under the top mattress.
Step 13: Add the Extras
Add a metal trash can (perfect toy storage!) small black commentator table (for homework), steps, small ladder and a black bed skirt.
Step 14: Result:
One very Happy Little Man. See his reaction on You Tube!
Beyond the Comfort Zone Contest
Runner Up in the
    • Warm and Fuzzy Contest
    • Paper Contest
      Paper Contest
    • Organization Contest
    18 Discussions
    allangee
    2 years ago
    This LOOKS awesome! Wouldn't their be a choking hazard if the child rolls to the edge in his/her sleep?
    Tracy4dj8allangee
    Reply 2 years ago
    Not if the ropes are correctly wrapped as instructed in the tutorial.
    steffelemTracy4dj8
    Reply 2 years ago
    Thank you. This bed is fantastic! It turned out beautifully
    steffelem
    2 years ago
    May I ask where you got the Cens graphic?
    blkhawk
    2 years ago
    Let's get ready to RUMBLE!
    KrazyK4
    2 years ago
    this is so good! your son must have loved this!!!!!
    mr.incredible
    2 years ago
    Awesome Job! He's a lucky boy. I agree the graphic makes the difference.
    One structural issue. Since you cut the head board and foot board you may loose some strength. I suggest making the under sides between the post solid with maybe some drawers cut into the front side. So the base is a big box with the ring poles standing up from it. Extra storage is always nice.
    Tracy4dj8mr.incredible
    Reply 2 years ago
    I did add large wood braces between the front and back legs for support but building a box all the way around would definitely do the trick! Thanks for the advice! I see a future use for the drawers in my old nightstands I am repurposing!??
    parisusa
    2 years ago
    This is fantastic! Friendly suggestion: change the first photo to show the actual bed. More people will click on it! Voted! Great job...lucky boy!
    gravityisweakparisusa
    Reply 2 years ago
    Agreed! That cover photo is fantastic. I had to look more than once to realize that was a wall graphic.
    Tracy4dj8parisusa
    Reply 2 years ago
    Thank you! This is my first day posting on instructables. Thank you for the suggestion!! I changed it :)
    xxlauraxx
    2 years ago
    omg, this is rad! The wall graphics totally make it.
    He's totally still going to be bragging about this bed when he's an adult. Well done!
