How to Make a Your Own Glass Pipette
432
4
About: 日本の人ですよ I live in japan! 真空管を作る研究をしています... vacuum tube manufacturing researching is in progress...
I want to use chemicals... wait, I don't have pipette!
time to handle a medium amount chemicals.
I want to use pipette for transfer it. but I don't have a pipette.
the solution is... LET'S MAKE A PIPETTE!
Step 1: Materials, Tools and Cautions
Materials:
  • 15 cm length φ15 Soda-lime glass tubing
    (you can use borosilicate glass (pyrex) if you have oxy-propane torch.)
  • Laboratory pipette dropper cap
    (or 30 cm length Silicone tube, inside diameter is 5 mm)
Tools:
  • Gas torch
  • Metal file
  • Safety glasses (Glass may crack and splash.)
Cautions:
Caution of burning:
Glass is low thermal conductivity, it keeps high temperature for few minutes even after stopping heating.
Caution of injury:
Glass breaks into sharp fragments and splash. please wear protective glasses and please work in a place that easy to clean.
Caution of fire:
will use a fire. Please do not place inflammable objects nearby.
Caution of accidental ingestion:
When using silicone tube instead of pipette dropper cap, please pay attention to accidental ingestion of chemicals. Also, please do not use dangerous chemicals (e.g. toluene, sulfic acid and sodium hydroxide) when using silicone tube.
Step 2: Glass Work
I don't write text of about glass work. because it would take forever...
but I made a video. please watch it, video is better way to understand than text.
Step 3: Done!
With this I can use chemicals!
If you change the strength of pull the melting glass, you can make a thinner / thicker the tip.
Besides, you can make a pipette for each purpose, such as bending the tip, making it larger capacity, etc.
    • Trash to Treasure
      Trash to Treasure
    • Arduino Contest 2019
    • Tape Contest
      Tape Contest
    SHOE0007
    6 months ago
    Very cool concept but cannot you buy them glass ones for 10 dollars on Ebay? I find this method if you don't know what exactly your doing to be dangerous. Still as a concept it very cool.
