How to Make an Apothecary Cabinet
21,142
237
21
About: Hey, This is Alpaca Studio.
I built this apothecary cabinet last week in my workshop. And here is the video of the building process.
It's a 400mm*400mm cabinet which has 9 small drawers and 2 large drawers. I used 4/4 beech to build the outside part of the cabinet. To make the cabinet lighter, I used 15mm birch plywood to build the inner section. I used some beech strip to cover the edge of the plywood so that it won't be seen from the outside.
Material:
4/4 beech
15mm birch plywood
tung wood panel *(see update1)
11* drawer pull
The detailed dimension can be found here:
http://alpacastudio.org/plans/
update 1:
Someone told me in the comments that tung wood panel does not exist. So I checked Google and here is the answer. The wood panel I used is actually called Paulownia. Both Paulownia and Tung is called “桐” in Chinese. I subconsciously thought these two species are the same. This wood is extremely light and easy to work with.
Step 1: Dimension the Lumber
Most of my projects start with this step. All my rough saw beech needed to be strictly treated by my jointer, my miter saw, my planer and my table saw. After all these steps, I finally got some useful dimensioned boards.
Sometimes I might rearrange the order of this process. but this time, I started with the miter saw. I first cut the very end of each board to remove the split part of the wood. The blue paint is also removed at the same time. Then I used my jointer to get two flat surfaces which are perpendicular to each other. I put the lumber on the table saw to square two edges. finally, I used the planner to bring all the boards to the same thickness. The thickness here is 20mm.
Step 2: Cut the Dovetail ( Pins)
I used the table saw to cut the pin first. I set the angle to 7 degrees which is the same as 1:8. This is the fastest way I found to cut the pin. Then I used a coping saw to cut the most of the materials.
Step 3: Cut the Dovetail (tails)
Step 4: Cut the Grooves
The plywood is 15mm thick. You can use either a router or a table saw to cut the groove which fits the plywood. If you have a dado saw blade. this job can be done in several minutes. But I don't have one. So I just move the fence gently and cut the groove step by step.
Step 5: Cover the Plywood Edge With Beech
To hide the edges of the plywood, I cut some beech strips slightly thicker than 15mm. I glued the strip to the plywood and used some tape to clamp them.
After the glue dried, I used my router to trim all the excess material. This allows you to have a flush surface. Tips: you can clamp all three panels together. This makes the works much easier.
Step 6: Resaw the Wood
I want to use 5mm beech for the back panel. However, I don't have a bandsaw large enough for this kind of job. So I decided to use the table saw. Normally, I don't recommend you to do this kind of work. First, you will lose more material. Secondly, you need to be extremely careful when you dealing with the table saw. The height of the wood is limited as well. Since I only need 10 cm board. So my table saw still can handle the job.
Step 7: Assembly the Main Body
Step 8: Cover the Plywood Edge With Beech 2.0
It' always good to have more material than what it really needs. Because it's easier to trim flush with a hand plane than to glue on more wood.
Step 9: Make the Drawer (1)
The cabinet has 11 drawers. If you want to dovetail all the drawers, It can take you a few days. So here I choose to use a quick way which I found in the woodworking book. It's not as strong as dovetail drawer. But it's strong enough for drawers like this size.
All you need to do is use the table saw to cut grooves on the edge. The structure is shown here. You can understand how to make it when you see it.
Step 10: Make the Drawer (2)
To get a nice fit, I plane the sides of the drawers. And I also add some drawer pulls which I found online. These pulls are made of brass. The screws are kind of brittle. Rember to predrill the hole and drill in a steel screw first. This prevents the brass screws from broken.
Update 2
I found these pulls on Taobao which is the personal version of Alibaba. It might not be available outside China mainland. BUT, I found the same kind of products on Amazon.
Here is the link:
https://www.amazon.com/s?k=apothecary+cabinet+pull...
Also, try "apothecary cabinet pulls" and you can find more somewhere else.
Step 11: Finish With Boiled Linseed Oil
I used boiled linseed oil to finish the whole piece. I really like how the color and grain turned out. I might apply some PU later together with some of my other projects.
So, here is the cabinet.
If you like this one please check some of my other projects on my youtube channel.
Appreciate it if you give me a thumb up on the video. If you have any question about the process, let me know in the comments.
Have a good day!
Organization Contest
Second Prize in the
    • Gardening Contest
      Gardening Contest
    • Tape Contest
      Tape Contest
    • Trash to Treasure
      Trash to Treasure
    21 Discussions
    Ninzerbean
    14 days ago
    So well done - thank you for sharing. I hope you win the contest.
    OutofPatience
    18 days ago
    Nice work! I'd love about 4 of these for my art studio!
    Bardman
    23 days ago
    tung wood panel's do not exists. Ony wood with tung oil applied. Fake and spam.
    jboffshoreBardman
    Reply 22 days ago
    Fake and spam?
    That's a little extreme.
    PizzafaceBardman
    Reply 23 days ago
    Is it possible he meant tongue as in tongue and groove and just isn't the best speller?
    Alpaca StudioPizzaface
    Reply 23 days ago
    My bad. The wood panel I used is actually called Paulownia. Both Paulownia and Tung is called “桐” in Chinese. I subconsciously thought these two species are the same.
    PizzafaceAlpaca Studio
    Reply 23 days ago
    I looked up tung wood and WIkipedia says there is a tung wood. It says, "Vernicia fordii, usually known as the tung tree (Chinese: , tóng)" and also, "The wood of the tree is lightweight and strong, and is sometimes used as a substitute for balsa or basswood." So you apparently were correct anyway.
    BardmanPizzaface
    Reply 23 days ago
    Nope, balsa or basswood you mention are so lightweigt and prono to dents its not used for cabinets. As alpaca studio already wrote he used Paulownia, and that is a very nice wood for cabinets:-)
    zacker
    23 days ago
    Very nice..great job cutting the Dovetails too! this came out really nice!
    dpeach
    23 days ago
    This is beautiful and inspiring.
    When I first saw it I thought it was a card catalog box from the library. But I guess you are probably too young to know what that is. :-)
    Thanks for sharing. Beautiful work.
    DanPro
    23 days ago
    Nicely done!
    Adding a link to where you purchased the pulls might be helpful to others.
    cheapdawgs
    23 days ago on Step 11
    This is outstanding! Nice work with the joinery. Nice to see you didn’t take shortcuts. Thanks for sharing this video and instructable.
    Yonatan24
    23 days ago
    I wonder if I could build it using only the hand tools that I have.
    Only a Japanese saw, and sandpaper. It wouldn't look as nice as yours, but I think I could saw accurately enough for it to at least be useable. Instead of making grooves/dados, I'd drive screws into the horizontal shelves through, sides. I'd maybe use acrylic for the front face of the drawers so I could see through them.
    Even without dovetails it would probably take forever though! :)
    dpeachYonatan24
    Reply 23 days ago
    I've seen amazing work done using very limited tools. Even if it doesn't look as nice as someone else's piece (in your own opinion), I'm sure it would be inspiring to others to see what you can make. Post pictures!
    WmC1
    23 days ago
    Excellent work!
    MarcellS2
    23 days ago
    That looks very nice!
