How to Make an Automatic Night Light
26,657
98
6
About: HI! I am Junez Riyaz, currently doing Bachelor of Technology in the field of Electronics and Communication Engineering. I am much interested in inventing something new yet from my childhood. In my leisure ti...
Automatic night light is a device with turns on light when there is darkness in the surrounding.
Its a portable version of automatic street lights. In this I used LDR (Light Dependent Resistor) which varies resistance with respect to light intensity.
For more projects subscribe my youtube channel [ Subscribe ]
Now I am going to instruct how to make an Automatic Night Light with less number of components.
Get Started..
Step 1: Components Required
LDR -1 ebay / Amazon
Resistor - 10k (x1)
Transistor - BC547 (x1) ebay / Amazon
9V Battery and Snap - 1
PCB -1 ebay / Amazon
LED -2
Step 2: Circuting
Place all components on PCB according to Circuit given above.
Note: adding a resistor of 330 ohms in series with led improves the lifetime of led.
Now solder all components.
Now solder 9V battery snap at respective terminals.
Place a piece of double sided tape on snap and stick the pcb to it.
Now connect battery to it.
For simulation fritzing file is attached
Step 3: Circuit Construction and Testing
For more projects subscribe my youtube channel [Click Here]
Feel free to comment.
    • Trash to Treasure
      Trash to Treasure
    • Tape Contest
      Tape Contest
    • Arduino Contest 2019
    6 Discussions
    gojeshubhangi1999
    Question 1 year ago
    importance of automatic night light?
    gm280
    2 years ago
    I see you didn't use any current limiting resistor in series with the LED(s) and the transistor. When the transistor is turned on, the current will flow through the LEDs without any current limiting. I suspect they won't last long. I would install at least a 330 ohm resister for one LED and at least a 160 ohm resister for two LEDs. JMHO
    JunezRiyazgm280
    Reply 2 years ago
    Thank you for improving this Instructable.
    JunezRiyaz
    Reply 2 years ago
    Thank you.
