How to Make an Inverter Using ARDUINO
33,954
74
45
Hi there, this project is all about designing an inverter from scratch, I am always fantasized by the projects which involves a software controlling an hardware. With this inverter, you can power up various electronic Appliances like TV, Fan etc.
Working : The aim of the inverter circuit is to convert 12VDC to 220VAC, Now to achieve this, we have to first convert 12VDC to 12VAC first followed by 12VAC to 220VAC
In short we can classify the designing of inverter circuit into three stages
1) Driver stage
2) Power stage
3) Transformer
Step 1: MAKING DRIVER STAGE
The tasks that are performed in driver stage are generation of modified sine wave, monitoring the battery voltage, handling the other housekeeping tasks such as short circuit protection etc. Here i have used an Arduino NANO to accomplish all these tasks.
Arduino is generating a modified sine waveform of 5V which is amplified to a level of 12V using L293D ic. Battery voltage is monitored every 20ms using timer interrupt.
Step 2: MAKING POWER STAGE
As the inverter output power is 600VA and it is 75% efficient so the input current at full load comes out to be 75Amp approx. (using ohm's law)
Now this current amplification task is performed by the power stage . In this stage two N-Mosfets are configured in push-pull topology to amplify the current.
Mosfet Chosen are IRF3205
Step 3: TRANSFORMER
Now this is very simple, the output waveform from the pushpull topology is fed into the transformer to generate the 220V.
Step 4: Designing Transformer
Designing transformer
Step 5: Schematics
This is the complete schematics drawn in Eagle software.
Step 6: Code
Here is the complete code of the Arduino.
Step 7: Complete Image of the Inverter
  • Trash to Treasure
    Trash to Treasure
  • Tape Contest
    Tape Contest
  • Arduino Contest 2019
45 Discussions
mhmoudZ
4 months ago
Can you add a tranfirst irfp064 I also suffer from a very large temperature increase in transistors
ShailzaPParthibA
Reply 1 year ago
As it is not a high frequency so i did not use snubber.
TvixenShailzaP
Reply 8 months ago
You must always use snupper circuit when working with sqare waves! Theres a lots of harmonic distortion.
SetiawanP
1 year ago
Hello. How does the code modify if I'm not using battery?
Cool. This will let you automatically turn the inverter on when you need it and turn it off when you don't
There are a lot of ways that you can do it. But the easiest thing that you could do is just get an Arduino shield with an LCD display on it.
manish singhC
1 year ago
Sir could u tell the transformer rating to be used in this circuit & can i use 6-0-6 transformer
JagadeeshM6
1 year ago
After including timer1header in the code it is again showing like this error code
Arduino: 1.8.3 (Windows 7), Board: "Arduino/Genuino Uno"
C:\Users\Hackers\Documents\Arduino\inverter\inverter.ino:1:54: fatal error: Timer1.h: No such file or directory
#include "Timer1.h" // include Timer1.h
compilation terminated.
exit status 1
Error compiling for board Arduino/Genuino Uno.
SwapnilH3
1 year ago
Nice project.But suppose i want to implement this project for synchronisation of grid using zero crossing detector would it be possible?
if yes then what should be the changes in this circuit.
ParthibA
1 year ago
nice post.......... :D
can you please make video on the feedback circuit
ShailzaPParthibA
Reply 1 year ago
Thanks,
I will definetly try to publish that.
Gauravbhaskar
1 year ago
Please give circuit diagram feedback system
Mukulmehta
2 years ago
Hey can u tell me where to connect the probes to view the result of driver stage?
SaifH7ShailzaP
Reply 2 years ago
please provide the simulation results
