How to Make an Olive Wood Cutting Board
6,606
99
20
About: My name is Suso Caamanho. I like doing all sorts of stuff related to musical instruments, woodworking, computer science, electronics... On my website you will find more information, projects, plans, photos...
I'm going to make this olive wood cutting board for my kitchen. As you can see, I've made it with end grain so it will be sturdier and more stable than if I had used face grain as are usually other cutting boards.
What you'll need:
8 olive wood blocks_60x60x350mm
Table saw
Wood glue
Clamps
Thickness Sander
Mobile devices:
More info:
Supplies:
Step 1: Preparing the Wood
I will use these olive wood blocks. As I said in previous videos, they come from pruning and clearing operations in the Mediterranean, where the trees are harvested for oil production. I'm going to make sure they all fit together perfectly and also make their best-looking surface face up.
I make all preparations and get hold of all the necessary materials and start applying glue. I'll also sprinkle some salt to stop the wood from moving when tightening the clamps because of the glue's viscosity.
There are special bar clamps for this purpose, but since I don't have any, I'll use this long kind, which can also exert a great deal of pressure. It's very important to ensure all surfaces are flat. This will save us a lot of work later. After leaving them to dry for eight hours, I remove the clamps and finish flattening the faces using a hand plane.
Step 2: Endgrain Olive Wood
I even out one of the edges with the table saw. This disc is not big enough, so I'll make two passes. And now I can cut all the necessary parts as shown. I'll make the board 50mm high, 450mm long, and 330mm wide.
Now's the time to decide how to glue the pieces together. I could every second one half a square. I don't think it would look bad. I could also flip some of them to achieve these grain patterns (third pic). But in the end, I decided to stick to the original form and have them fit together like this. I'm going to apply glue just like before, again, making sure the faces are flat.
Step 3: Using the Thickness Sander
Once dry, I remove any leftover glue with a chisel and now I use the thickness sander to make all the faces flat and perfectly straight. I've mounted P80 grit sandpaper on the drum. It's quite thick but still, I'll proceed slowly and make several passes. I made about ten on each face.
Everything seems to be okay, so now I'm going to even out the board with the table saw and make a couple of handles with this router bit. I mark the height and place a couple of stops that will make the process easier. I'll need to make three passes to make each handle.
Step 4: Final Steps
Now all that's left to do is sand all faces and edges with P120 grit and finally apply some pure linseed oil all over the board. It's important that the oil be pure, because some linseed oils you will find in the market are cooked and treated with toxic substances to make them dry faster.
We could also use mineral oil.As always, olive end grain looks impressive! This board will make a nice addition to my kitchen...
    • Party Challenge
      Party Challenge
    • IoT Challenge
      IoT Challenge
    20 Discussions
    nunyafb
    1 year ago
    I was just wondering what would be the consequences of using olive oil instead of linseed oil?
    Olewis5nunyafb
    Reply 7 months ago
    What I hear is that olive oil can go rancid on the wood after some time. I guess that means it will just smell bad is all.
    barben
    1 year ago
    Absolutely beautiful. I also loved your DIY sander and the bar clamps you used are also something I am interested in. Who makes them. I'm writing from Canada.
    fredellarbybarben
    Reply 1 year ago
    bar / pipe clamps are at Princess Auto, Home Depot and Canadian tire. You buy the ends and screw them onto a length of pipe.
    obillo
    1 year ago
    Thanks for the tip re SALT--never heard that before and it should solve a truly pestiferous problem. Unfortunately, these days it is probably neccessary to make a DIY board: those on the market today are generally poor, made with face-grain lumber that wears and warps very quickly (the old super-hard, super-tight-grained ROCK maple seem to be i very short supply. Sadly I have no access to olive--but I DO having a whacking great slab of teak. Do you think that would work?
    Paoson Woodwork
    1 year ago
    hi! as I said in the video, they come from pruning and clearing operations in the Mediterranean, where the trees are harvested for oil production. I am from Spain where it is easy to find, where are you from?
    BIVS2000Paoson Woodwork
    Reply 1 year ago
    USA. And it is not easy to find here. So I have to pay a higher price anyway, which is why I buy it from Israel because the quality is really high
    JohnP493BIVS2000
    Reply 1 year ago
    But it is probably from stolen land and trees (West Bank / Palestine). Personally I won't support the Israeli occupation of Palestine. And this is not trying to make a political statement, it is about human rights. The Palestinians deserve to be treated as humans too. Illegal Israeli settlers (illegal according to the UN and ALL human rights groups) take the land and destroy the trees to feel empowered and demonstrate they are in control. I doubt it is all from "cutting and pruning" if purchased from Israel.
    Paoson WoodworkJohnP493
    Reply 1 year ago
    hi John,
    of course, we should try to obtain wood in an honest, sustainable manner. The olive wood I use comes from southern Spain, where the oil producing trees are pruned yearly. It is also quite expensive compared to other sorts of wood, but it's worth it for small projects!
    BIVS2000
    1 year ago
    How much did all of that olive wood cost you?
    I get mine from Israel and it is kind of expensive!
    WyldStyl3
    1 year ago
    This looks fantastic! I love the way olive wood looks. Do you happen to have any resources on where to get it?
    Mitch371
    1 year ago
    I really enjoy watching how you craft. Nice job. Love the wood!
    dvlr
    1 year ago
    great, thanks. Fotunately the video is much better than my spanish skills... ; -)
    Anyway still impressive, clean, clever job, high level DIYer !
    dvlr
    1 year ago
    great job, but I have to say that I'm very impressed by your tools, especially your sander... could you please détail ?
    Yonatan24dvlr
    Reply 1 year ago
    He has everything on his Youtube channel
    Paoson Woodworkdvlr
    Reply 1 year ago
    thank you! take a look:
    https://www.paoson.com/blog/lathe-sanding-station-thickness-sander-n72
