How to Measure Flour
93,672
51
20
About: Check out my etsy shop too! etsy.com/shop/scoochmaroo
It's long been said that ingredients for baking should be weighed for best results. That's all well and good, but I have measuring cups, not a scale. So what's the big deal?
The big deal is a major difference in the texture, density and overall success of your baked goods!
But relax! You don't need a scale for perfect brownies! You just need to follow these simple steps.
If you do enough baking that you finally decide you want to get a scale, I highly recommend this one. (not pictured). It's affordable, and nearly indestructible.  Believe me, I bought it to replace the one in the picture, and have put mine through the paces!
Scoochmaroo provides product links as a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for sites to earn advertising fees by advertising and linking to amazon.com.
Step 1: How Much Does It Weigh?
A cup of all-purpose flour, properly measured, should weigh 120 grams. The flour measured incorrectly by dipping the measuring cup into the flour can weigh anywhere from 150-160 grams. Try it out!
That's like 30% more flour than the recipe needs!
A cookie or cake made with flour measured this way will be tough and dry. Sauces will be too thick, and pie crusts crumbly and dry.
Step 2: What Should I Do?
To measure the flour correctly, lightly spoon flour into a one-cup measuring cup. Don't shake the cup or pack down the flour.
Step 3: Fill 'er Up!
Keep spooning in the flour until it mounds over the cup.
Step 4: Level It Off
Use the flat side of a table knife to level the flour and remove the excess.
Step 5: Check Your Success!
How do we know this has worked?
Check the weight!
As we said, a properly measured cup of flour should weigh 120 grams.
Check out how much extra flour is left over from the originally scooped cup
It's important to remember that not all flour is created equal.
  • One cup of white flour weighs 120 grams.
  • One cup of whole wheat flour weighs 140 grams.
  • One cup of bread flour weighs 130 grams.
  • One cup of cake flour weighs 114 grams.
Use this technique for success in measuring all of your dried goods - but remember, their weights may vary.
    • Arduino Contest 2019
    • Gardening Contest
      Gardening Contest
    • Classroom Science Contest
    20 Discussions
    Sometimes dipping the cup into the bag of flour is actually the correct way to measure it. I've owned two bread makers and the instruction books for both stated to do it this way.
    shazni
    6 years ago on Introduction
    okay...now i have a scale...and when the ingredients say 1 cup i assume it's 8oz...and i weigh bread flour, cake flour , white flour the same...meaning when it asks for one cup...i check if it's 8 oz...so am i right or wrong?
    scoochmarooshazni
    Reply 6 years ago on Introduction
    What that means is 8oz in volume. Because each type of flour has a different weight because of how it's made, the final weights should be different. A little derivation is fine - you'll see websites all over giving different weights for the same volume. Try it out yourself and see what works best!
    For weight in ounces (our system is so confusing!)
    1 cup white flour weighs 4.2 oz
    1 cup whole wheat flour weighs 4.9 oz
    1 cup bread flour weighs 4.5 oz
    1 cup cake flour weighs 4.0 oz
    1 cup=8oz is fluid oz. that's a liquid measurement, and it's only accurate for pure water. For example, pure alcohol would weigh 6oz per cup, honey would weigh 12oz per cup. Something with a LOT of air in it, flour, for example, a cup isn't a measure of weight, it's sort of an arbitraty measure of volume, so everything will weigh something different if you use a cup as a weight. It's not a weight, it's a measure. What you have to do to convert if you want to do recipes by weight is you have to look up the actual weight per cup of whatever substance you are using, or buy recipe books that use weights instead of measures. Conversion is complicated. *everything* weighs something different. Personally I love my calibrated digital kitchen scale. It's something no kitchen should be without.
    pmn9393
    5 years ago on Introduction
    I usually just put my hand on the outside of the bag use that to level it off as i'm pulling the cup out of the bag.
    SeaLion
    8 years ago on Introduction
    Incredible! I never knew that there would be such a massive difference...(I guess now we all know why I never suceeded in baking :P)
    ELF
    9 years ago on Introduction
    I usually just dig in the flour with the cup, and then scoop up the flour I dig loose, since that will be more fluffy. Same result :)
    Buskieboy
    9 years ago on Step 5
    this will help my Yorkshire Puddings which have been rather heavy lately and not rising as high as previously.  I am now sure it was this 120gm vs. 150gm difference!
    Thanks for the excellent visual evidence!
    junits15
    only thing is, does it really matter? I mean ten to twenty grams diffrence in flour when the whole mix can be in the kilogram range, isnt that much.
    frollardjunits15
    its a percentage. Flour is the primary ingredient in many recipes...seconded usually only by sugar. 160/120 isn't just a few grams... its a full THIRD too much. That can make a huge difference.
    frollardJamesRPatrick
    They use the scoop - the gentle scoop described in this instructable. When you lightly spoon it into the measure, it loosens the particles. Scooping compacts them in.
    jeff-o
    Good info! I shall remember this - fluffy flour, not packed. Check.
    theRIAA
    my highschool cooking teacher said to scoop the flour, then "cut" it up in the measuring cup with a butter knife to fluff it up, then level it off. Always worked for me. Though, most always, you can just look at the dough and see if it needs more or less flour..
