How to Measure LUX With Arduino
10,503
23
About: Arduino Tutorials by Codebender.cc Team
In this tutorial we will use the Adafruit TSL2561 sensor to measure LUX with Arduino.
The TSL2561 luminosity sensor is an advanced digital light sensor, ideal for use in a wide range of light situations. Compared to low cost CdS cells, this sensor is more precise, allowing for exact lux calculations and can be configured for different gain/timing ranges to detect light ranges from up to 0.1 - 40,000+ Lux on the fly.
The best part of this sensor is that it contains both infrared and full spectrum diodes! That means you can separately measure infrared, full-spectrum or human-visible light. Most sensors can only detect one or the other, which does not accurately represent what human eyes see (since we cannot perceive the IR light that is detected by most photo diodes)
So, let's get started!
Step 1: What You Will Need
For this tutorial you will need:
  • Arduino uno
  • Breadboard
  • Adafruit TSL2561 module
  • some breadboard cables
  • and a flashlight
Step 2: Breadboard Circuit Schematic
The connections are pretty easy, see the above image with the breadboard circuit schematic.
Step 3: The Code
Here's the code, embedded using Codebender!
Try downloading the Codebender plugin and clicking on the "Run on Arduino" button to program your Arduino board. And that's it, you've programmed your Arduino with this sketch!
Step 4: Serial Monitor- Testing
Press the connect button to start the serial communication.
Step 5: Well Done!
You have successfully completed one more "How to" tutorial and you learned how to use the Adafruit TSL2561 Luminosity sensor with Arduino.
I hope you liked this, let me know in the comments!
    • Arduino Contest 2019
    • Tape Contest
      Tape Contest
    • Trash to Treasure
      Trash to Treasure
    BazraB
    1 year ago
    It's possible to use 3 tsl2561 sensors on one microcontroller.
    Cause tsl2561 has 3 different addresses.
    am I should add I2C pull up resistors using 3 tsl2561 sensors.
    or not?
    thanks.
