How to Program an Attiny85 From an Arduino Uno
9,818
18
5
About: I make things, sometimes they brake
Quick tutorial showing how to program the ATtiny85 from the Arduino IDE with the help of the Arduino Uno!
This tutorial was requested by my friend Orlando so hope it helps !
Comments,Concerns,Feedback,Requests welcomed:
@NemesisContrer8
Step 1: Add Support for the ATtiny85 to the Arduino URL Board Manager
By default the Arduino IDE does not support the ATtiny85 it's required to add support for the Attiny85 to the Arduino Board Manager:
  • From the Arduino IDE Go to Arduino->Preferences then scroll down to Additional Board Managers URLs
  • Copy & paste the following (if you already have a board manager URL just add a comma before pasting)
Thanks David-one of the Arduino founders for writing the code!
<p>https://raw.githubusercontent.com/damellis/attiny/ide-1.6.x-boards-manager/package_damellis_attiny_index.json</p>
  • Press "OK" at the bottom then restart the Arduino IDE
Step 2: Install the ATtiny Board Package
  • From the Arduino IDE go to Tools--> Board-->Boards Manager
  • A new tab will open and at the top of the tab type: attiny
  • Select Install on the Attiny by David. A Mellis
  • Restart the Arduino IDE
  • The ATtiny85 board should now be added ! Go to Tools--> Board-->Attiny85
Step 3: Set the Arduino Uno Into ISP Mode
Since what we want is to be able to program the ATtiny85 from the Arduino IDE which requires to burn the bootloader to the ATtiny85 we will need to "prep" the Arduino fist by uploading the ISP sketch to it.
In the Arduino IDE select File-->Examples--> 11. Arduino ISP-->ArduinoISP
the ISP sketch should open and upload it to your Arduino Uno
Step 4: How a Microcontrollers Pins Are Labeled
Before the connections are made there is a very important fact to know how pins on microcrontrollers/ICs are labeled.
Pin numbers used to program a chip on the Arduino IDE are based on how the chip manufacturer has internally named/aranged the pins . The manufacturer of the ATtiny85 is ATMEL (the AT in ATtiny85-actually stands for ATMEL);It's common for chips to have the first two initials of the company who makes them.
Pins are gathered into groups called "ports" these ports are labeled A,B,C etc. Each port has a number of pins which are labeled 0,1,2,3 etc and stick out on different parts of the chip which is why a microcontroller's physical pin often time will be different than the pin number used when programming the chip.
An example:
PB0 (in the above datasheet) just means pin 0 is located on Port B of the Chip.
If pin 0 was located on Port A the name would look something like PA0 (Port A pin 0)
To add to the complexity pins can have more than one fuction and be labeled multiple names.
Wrapping it all together! :
Writing a program to light an LED on pin 0 on the ATtiny85 might be confusing at first because just by looking at the chip , there is no pin 0! However, by checking the datasheet of the ATtiny85 from ATMEL-snippet shown above-pin 0 is internally located on the chip's port B (and is actually the chip's physical pin 5 )!
Step 5: Connecting the Arduino to the ATtiny Pins
Have an electrolytic capacitor-10uF is recommend but I used a 22uF and it worked fine- to prevent the Arduino from restarting it's self connected to GND & RESET on the Arduino
Use a breadboard and jumper wires to make the connections bellow from the Arduino Uno to the ATtiny85:
Arduino--> ATtiny85
5V            Vcc
GND           GND
Pin 13        Pin 2
Pin 12        Pin 1
Pin 11        Pin 0
Pin 10        Reset
Step 6: Making the ATtiny85 Arduino Compatible
By default any fresh microcontroller chip bought will not be able to be programmed with the Arduino IDE out of the box. This is why it's required to burn the Arduino bootloader onto the chip to make sure the chip will accept any programs uploaded via the Arduino IDE.
Quick checklist before pressing "burn bootloader"
  • Go to Tools -> Board scroll to the bottom select ATtiny25/45/85
  • Under Tools -> Processor--> 8 MHz (internal)
  • Under Tools-->Programmer-->Arduino as ISP
  • Check that all wiring, capacitor, and board selections are correct
  • Finally select Burn Bootloader
  • leave the wires connected they will be used in the next step
A message will appear saying "Done Burning Bootloader"
Step 7: Uploading the Blink Sketch
Test that the ATtiny85 can now receive sketches from the Arduino IDE by uploading the blink example
  • Go to File-->Example-->01.Basics-->blink
  • Edit the sketch by replacing pin 13 with 0
  • Make sure to still have the ATtiny85 board settings from the previous step selected
  • Make sure all wiring is the same as the previous step
  • Upload the sketch
  • Wire an LED by connecting the anode to pin 0 (physical pin 5 ) and the cathode to a 1K resistor connected to ground (physical pin 4)
  • While a resistor is not needed since the battery provides 3v (not enough to blow up an LED) it is recommended to lower the brightness of the LED
Any request for future tutorials all welcomed! Just leave a comment bellow
    • Arduino Contest 2019
    • Tape Contest
      Tape Contest
    • Trash to Treasure
      Trash to Treasure
    5 Discussions
    NemesisCjeanroccoj
    Reply 6 months ago
    Really honored to be able to help. Thank you for using me as a reference!
    JarH2
    7 months ago
    If i understand all right, when do you start this create your own program for ATtiny85.
    1. Install Arduino UNO, Setting your Arduino Preferences and check this Additional Board Managers URLs is this address
    "https://raw.githubusercontent.com/damellis/attiny/ide-1.6.x-boards-manager/package_damellis_attiny_index.json"
    Press "OK" at the bottom then restart the Arduino IDE.
    2. Install the ATtiny Board Package
    3. You t do first Arduino UNO setting
    - Go to Tools -> Board scroll to the bottom select ATtiny25/45/85
    - Under Tools -> Processor--> 8 MHz (internal)
    - Under Tools-->Programmer-->Arduino as ISP
    4. Then you do wrote your program and then press Sketch after it matter you press Verify/Compile. Uou get info "Done Compling".
    5. After it you do start prepare ATtiny85 for Arduino UNO doing get ATtiny85 compatible with Arduino UNO. CONNECT NOW ARDUINO UNO TO YOUR COMPUTER. You start coupling ATtiny85 to Arduino UNO with wiring it, then you check again
    - Under Tools -> Port -> select your Arduino UNO port from this menu
    - Finally select Burn Bootloader and press it, when it is ready you can see info "Done Burning Bootloader".
    But not take off your ATtiny85 wiring and coupling.
    6. Go to get your own wrote program and open it in Arduino Uno. Then Upload the your sketch, press Upload. When it is ready, you do get info "Done Uploading"
    7. Now you can do test your ATtiny85 program result, Take off ATtiny from Arduino UNO, do this coupling for it and see how it work.
    JarH2
    Question 7 months ago on Introduction
    If i understand all right, when do you start this create your own program for ATtiny85 and programmig it this kind. Right?????
    ohoilett
    2 years ago
    Cool! This is super helpful for my next research project. Thanks a bunches.
