How to Remove the White Background From Images Using GIMP
10,683
18
6
You know the annoying white (or any colour) background on most of the images you download from the internet? Well here's how to remove it... using GIMP. GIMP is a piece of free software that is like an alternative to Photoshop. Download it here:GIMP. I suppose there are other methods, time-consuming ones but this is the easiest I've found...
Supplies:
Step 1: Open GIMP.
The easiest way to open the image in GIMP is to right click it and click "Edit With GIMP". If you were wondering, I will be using GIMP 2.8. It will then load up with a professional-looking box. And yes, I used GIMP for the screenshots.
Step 2: Do Some Right-Clicking!
Now Right-Click your image, go to colours (or colors in this case) and then go to "Colour to Alpha". You could also use the bar at the top. This is the option that will delete the white background by making it transparent.
Step 3: The Menu in More Detail...
Now you simply need to click "OK" and it'll do it. To change the colour just click the block of colour between "From" and "To Alpha", you'll then instantly get you're results. If you don't like it, press Ctrl-Z.
Step 4: Now Save It
Go to file,Export As.... Find a place to save the file and save it! You no longer have an annoying white background!
Step 5: Let's Compare...
So as you can see, it works! Thanks for Reading!
    • Classroom Science Contest
    • IoT Challenge
      IoT Challenge
    6 Discussions
    synapse5
    3 years ago on Introduction
    Actually this is hard way to remove background, you can remove any complex background using PhotoScissors: https://www.photoscissors.com/how-to-remove-background-from-photo.html
    TheBATssynapse5
    Reply 3 years ago on Introduction
    Ok, but using GIMP is the easiest I know, oh and "paintloverM" stop spaming...
    TheBATsTheBATs
    Not trying to rude but the point of the article is to show how to remove a simple black, white, blue, orange background... Although that is a great way to remove a complex background.
    TheBATs
    To make the example image I used another great program called Inkscape.
