How to See in the Dark
87,646
241
42
If you want to be able to see in the dark you can pick up a maglite and shine it every where you want. But if you don't want other people to know you are there you have to figure out an other way to be able to see using a lightbeam others can't see. in otherwords build your own night vision scope.
what do you need:
- a viewfinder from an old camera.
- an old 380 line black and white camera
- six Infrared LED's
- three 15 ohm resistors
Step 1: The Viewfinder
The viewfinder I used for this night vision scope. Was taken from a CANON UC4000 V8 Camcorder. The Camera was broke but the viewfinder is stil very usefull.
The viewfinder used to be connected to the camera with 5 cables.
When I started measuring them I noticed that I just needed the first three cables those where.
- +5 volt
- Ground
- video-in
ATTENTION:
The viewfinder contains a 0.7 inch picture tube, a high voltage power supply and some calibration pots. The size of this module is only 2,5 x 5 cm.
Therefore the  high voltage power supply could for the picture tube could cause serious injury if you touched it.
This is why in attached new cables to those connection points en put the viewfinder back together.
Now our output device is ready.
Step 2: The Camera
After some searching I found a 380 line black/white camera in my garage which was solderd on a piece of stripboard and used a 5 volt power supply (thats nice the same votage as my view finder). This camera cannot see in the dark but it can see IR light (which is invisible for the human’s eye). So fore the record this night vision scope is not an image intensifier this scope needs an Infrared light source.
(Sometimes manufactors put a filter in the lens which blocks the infrared light when you work carefull jou can remove it as described in my Instructable Turning an old webcam into a Night vision cam
Step 3: The Illuminator
For the illuminator I used 6 High Power Infrared Emitter, type SFH4550.
Some specifics on these IR LED's:
- Current: 100 mA
- Wavelength: 860 nm
- Radiant Intensity: 700 mW/sr
- viewing angle: 3 degrees
- voltage: 1,5 Volt
- Diode Case t-1 3/4 (5 mm)
I used the stripboard that was attached to the camera as a base for my illuminator which i made by connecting 2 times 3 LED's in series (3 * 1.5 volts = 4,5 volts) to make it work in my system that has to run on 5 volts becaus of the viewfinder and the camera, I had to place a 5 ohm resistor before the LED's to make the powerdrop I placed 3 resistors of 15 omh in parallel.
Step 4: Connect and Enjoy
After connecting the viewfinder to the camera en connected all the power and ground cables I could see in the dark using the light of the Infrared LED's.
I am stil searching for a case to put it in and when i do I will deside what kind of battery i will use en design a circuit for battery power to the 5 volt working power of the electronics in my scope.
Images of the completed Night vision scope will be added after i have found a nice case to put it in.
Unforunatly i can't let you see what the image looks like when you look trough the night vision scope, But i can gaurantee that it works great.
Happy spying.
Spy Challenge
Finalist in the
Spy Challenge
    • Tape Contest
      Tape Contest
    • Trash to Treasure
      Trash to Treasure
    • Arduino Contest 2019
    42 Discussions
    D006DR
    5 years ago on Step 3
    Hi,
    I read you are using the SFH4550 with a dc current of 100 mA. The datasheet shows that this is the maximum rating. I would use them not at 100 mA. I would prefer 50 mA for a longer life of the leds.
    Velkov
    5 years ago on Introduction
    Great idea! I want to make the same gadget and I managed to find an old camera already - canon uc800. If you know please let me know where can I find the service manual for this camera. I would like to see the schematics of the viewfinder. Thanks!
    elklikoVelkov
    Reply 5 years ago on Introduction
    I always say that Google is youre best friend for finding stuff on the web.
    fmasi
    5 years ago on Step 4
    Couple of quick ideas
    1) this design is easy to double and go stereoscopic ...
    2) on some chinese ebay shops I spotted 1w/3w/5w IR high power LEDs (850 and 940nm, but I would go for 850), along with drivers, heatsinks, DC-DC converters and optics to change the focus degrees between 5 and 120 degrees.
    Very nice stuff for powerful and deep field illuminators.
    elklikofmasi
    That is also a posibility, thanx for the idea, unfortunatly my viewfinder is broken when it fell from the table. so I couldn't finnish the project.
    nvnusman
    6 years ago on Step 4
    So, thanks for the inspiration ...
    But I don't see three LEDs in parallel in the diagram, which I think is accurate and what most folks would follow. What I see are two parallel circuits of three LEDs in series ... am I right? Wouldn't want to fry a bunch of emitters! And, um ... power switch?
    emdarcher
    6 years ago on Introduction
    here is a camera from sparkfun that is perfect for this, it has ir leds and a cmos camera with rca output. all you need is the veiwfinder.
    https://www.sparkfun.com/products/8773
    50-50
    this does not make you 100% undetectable, when the IR leds are pointed at someone they can look and see a red glow from the leds.this happens even if they are military NVGs.
    elkliko50-50
    Reply 6 years ago on Introduction
    I disagree with you on this matter, if you have the correct LED's, you can not see the light(or glow) with the naked eye.
    Can you see the LED on the remotecontrol of your tv? This also works with a IR LED.
    The only way that this light can be seen is with a camera that is sensitive to IR light or a night scope.
    Also some animals can see this.
    sokamiwohalielkliko
    it matters not the ir led...all ir led's can be seen if in the right condition. for the ones that you "cant see" if your close enough to the LED then you can see the light it emits. this is what the military uses. also, they use a HIGHLY sensitive sensor to pick up the light in the NVG's. i used to be military, and used these almost all the time.
    50-50elkliko
    OK I admit that you cant see some of them but it happens to some of them.
    elkliko50-50
    So you have to find the one's that you can't see, or harvest some from old remote controlles.
    jeronimoooelkliko
    Problem here is that the camera can see these LED's when you look into them but they won't give enough light to have decent picture. The camera will not be sensitive enough at that wave length.
    elklikojeronimooo
    You can see a decent beam from the leds since the angle of the LED's i used is only 3 degrees. I can see for about 25 - 30 feet, but am considering to make a IR flashlight using more LED's for a stronger beam.
    GrumpyOldGoat50-50
    850nm IR LEDs have the 'red glow' while the 940 IR LEDs do not.
    WWW,ledshoppe.com.
    Lights my driveway nicely.... well, to a camera it's lit up.
    That is correct. If you have a security system with video the IR lights on the cam might not be enough. A battery of LED illuminators scattered thru the field of view really lights things up. The best thing is the bad guys don't even see it.
    Mr Jaderman
    6 years ago on Step 2
    Great instructable! I just have one question. I have a CCD security camera with a 4 pin S-video output. Is there a way to use that?
    mirusev
    re: if you have the correct LED's
    What are the correct LED's? Mean, it is for sure true, but do you know what exactly type are they - their name? To may search about...
