How to Service a Sewing Machine
69,981
434
62
About: You can also find me on iFixit.com and Twitter @pleriche. Volunteer with TheRestartProject.org and keen to share my knowledge and skills and do anything I can to encourage girls to follow STEM subjects.
Huge numbers of sewing machines have been manufactured over the years. The older vintage machines are virtually indestructible, indeed one highly skilled and experienced seamstress told me that she still uses a 1929 treadle machine as her daily workhorse. Newer machines, especially the very cheap ones, have many more plastic parts and a much shorter life. Nevertheless, the life and effectiveness of any machine can be extended with simple maintenance, and my aim here is to show you how.
For demonstration purposes in this Instructable I will use a vintage machine probably dating from the 1950's or 60's because it's easier to show the mechanism, however, all machines work in the same way. If you can get hold of such a machine, so long as it's complete, you should be able to keep it running indefinitely and certainly much longer than a modern machine.
You can find an expanded version of this Instructable, including a description of sewing machine principles and common problems and their solutions in the Sewing Machines page on the Restart Project wiki.
Many spare parts, particularly for older machines, are readily available on eBay and probably elsewhere.
Supplies:
Step 1: Removing Fluff and Dust
The first thing to do is to remove all dust and fluff, wherever you can find it. Between the feed dogs is a favourite place for it to collect. Remove the needle, the foot and the needle plate to facilitate cleaning. The needle plate is a plate beneath the foot with cut-outs through which the feed dogs protrude, generally secured by one or two screws. Where the dust and fluff has become matted you can pick it out with a pin or a needle, otherwise use a brush and/or a vacuum cleaner crevice tool. You can use a can of compressed air or simply blow but there is a risk you might just blow the fluff further into the mechanism. Look out for any pieces of broken needle which might have come to rest here and could jam the mechanism.
Also, check for and remove any dust, fluff or pieces of broken thread where the thread passes between the discs of the upper tension adjuster, and at any other points in the threading path of the upper thread where it might have collected. Good quality thread sheds less fluff than cheaper brands and so is advised.
Replace the foot. Check the needle before refitting it. Run it between your fingers from the shank down to the tip. Any roughness can be carefully removed with fine emery, but it is better replaced if it has seen more than 6 - 8 hours' service. Always replace a bent needle as it will cause nothing but trouble.
Step 2: Checking the Bobbin
In a vintage machine the bobbin is often accessed by sliding away a plate next to the needle plate, as shown in the first photo. In modern front loading machines a very similar mechanism is accessed from the front of the machine. In modern top loading machines the bobbin is dropped horizontally into a mechanism in front of the needle plate.
Many very old (like pre-war) machines have a completely different bobbin fitting into a bullet-shaped shuttle which is thrown through a loop in the upper thread to make each stitch.
On a vintage machine as shown, the mechanism is hinged on a wooden base and can be lowered into a horizontal position and rested on a pile of fat books for easy access to the underneath. The remaining photos were taken with it in this position.
Remove the bobbin and bobbin case and remove the bobbin from its case. Blow out any dust.
The bobbin case fits into a bobbin case holder which rotates as the machine operates. It should be easily removed, for example by releasing a pair of clips on a retaining ring.
The bobbin case holder has a sharp point known as the hook (shown in the last photo), designed to catch the upper thread so as to engage it with the lower thread and make a stitch. Run your finger over this and if it feels rough (probably due to needle strikes) then smooth off any burrs with fine emery. Take care to reassemble it correctly.
In the case of a second hand machine, make sure that all the bobbins that came with it (and any extra ones that you buy) are of the right sort. There are several types, superficially similar, and the wrong ones will cause problems if they work at all.
Step 3: Lubrication
This is easy on a vintage machine. The bottom mechanism is accessed by tipping it on its side as in the previous step, and the top mechanism can generally be accessed by removing a couple of screws retaining the top cover.
On a modern plastic machine you will generally have to remove a number of screws, and you may then have to release a series of clips holding 2 halves of the plastic case together. Probe the crack between them with a thin spatula or blunt scalpel or thin knife in order to determine where the clips are. Take care not to insert it too far or to damage the plastic. Angling the spatula so as to lift one side of the case whilst depressing the other should release a nearby clip. Insert an old credit card, plastic prying tool, guitar plectrum or anything similar in the gap so created to prevent the clip re-engaging while you probe for the next one. Stubborn refusal of the case to come apart often means there's one more screw, possibly hidden under a label or a rubber foot.
Having gained access to the top and bottom mechanisms, gently turn the hand wheel to see which bits move. Anything that moves needs oiling on its bearings, joints or sliding surfaces, except for nylon gears, wheels or cams - these are generally greased for life.
Use only sewing machine oil. Never use bicycle oil, or motor oil, or grease, or olive oil, or Vaseline, or anything else. None of these are sewing machine friendly.
Apply no more than a drop of oil to each bearing or connection. Wipe away any excess before it has a chance to drip.
In the case of a vintage machine that has been out of use for a long time, the mechanism may be very stiff or have seized up completely. Oil it thoroughly (but wiping away any excess) and leave it for a while for the oil to penetrate. Repeat as necessary until it operates smoothly.
Step 4: Checking the Tension
It's important to check the bobbin tension as you will get poor results and possibly broken or snagging thread if it's wrong. Fit a bobbin of thread to the bobbin case and thread it under the tension spring. Suspend it by the thread. The tension is correct if it is just sufficient to support the weight of the bobbin and case. Shaking it gently should unwind just a little more thread. Adjust with the screw in the tension spring. If you have any difficulty, make sure there isn't any fluff or pieces of broken thread under the tension spring.
Step 5: Checking the Bobbin Winder
Examine the bobbin winder. This often engages with the hand wheel by means of a wheel with a rubber tyre. If the tyre is worn or cracked or perished, replace it. Spares are generally easy to obtain.
Try winding a bobbin. The thread tension should be sufficient to produce a neat and tight (but not excessively tight) pile. Badly wound bobbins can cause trouble.
(I don't have any pictures of a bobbin winder as it's missing on my machine. I wind my bobbins on a piece of dowel fitted to the chuck of an electric drill.)
Step 6: Checking the Electrics
Before touching any of the electrics, double check that your machine isn't still plugged in.
Smooth operation of the foot pedal is essential otherwise it will be very hard to sew successfully. It may simply need lubricating. On older machines it will contain a rheostat, which is a variable resistance wired in series with the motor. Newer machines will more likely have an electronic speed control similar to a dimmer switch.
You will need to examine the foot pedal to determine how to disassemble it. Do not use sewing machine oil, but rather any light lubricating oil, or grease on sliding parts, and keep oil and grease away from all electrical contacts.
Also, check the motor belt tension. You should be able to adjust it by loosening the screws or nuts on its bracket. If the motor is sparking excessively or doesn't appear to be working well, check out the Electric Motors page on the Restart Project wiki. Replacing the brushes or cleaning the commutator might be necessary. If the motor bearings seem to need lubrication you should use grease specially intended for electric motors, preferably as recommended by the manufacturer.
A replacement bulb is easily fitted on older machines but may be wired-in and not so easily changed on newer ones. Consider replacing a filament bulb with a more modern LED equivalent, which will run much cooler. However, if the bulb needs to shine mainly downwards but the LEDs in a LED bulb appear to face sideways it may be less suitable. Take the old one with you to make sure you get a new one with the same sort of base.
Step 7: Checking the Timing
If you are getting unexplained broken threads, it could be that the timing needs adjustment. This is beyond what can be covered in an Instructable at this level and may be best left to a professional with the appropriate service manual, but it's not too difficult to see whether this is indeed the problem.
You need to be able to see the needle and the hook at the point where the hook catches the top thread. In the photo, I've turned my machine on its side so I can see the underneath, and I've removed the bobbin and and the plate which holds the bobbin carrier in place. I had to hold it to stop it dropping out as I turned the handwheel.
With the needle threaded, turn the handwheel until the hook passes the needle, whilst holding the free end of the thread taught, but without pulling on it. The photo shows the thread having been securely caught after the handwheel has been turned a little further.
The tip of the hook should pass the needle just after it has reached its lowest point. Typically, the needle should have risen 3/16 of an inch (1/10 of an inch, or 2.5mm). At this point, the rising needle causes the thread to go slack and form a loop which is caught by the hook.
Turning the handwheel still further, you should see the thread drawn around the bobbin (if you have it in place) so as to make a stitch.
If having come this far you've got the bug, and if the alternative is to scrap the machine, by all means search online for your make and model of machine with the key words "timing adjustment" appended, and you should at least be able to see what is involved in adjusting the timing. You need to ensure both that the lowest point of the needle brings the eye to the right level beneath the hook, and also that the hook passes the needle after it has risen by the prescribed amount. These settings and how to adjust them should be given in the machine's service manual, if you can get hold of it.
Step 8: And Finally ...
I hope you have enjoyed getting to know your machine better and overcome the fear of looking into quite an intricate and a very ingenious mechanism. If you have a good quality machine, hopefully it will now be purring away contentedly like a cat that's had the cream.
    • IoT Challenge
      IoT Challenge
    • Gardening Contest
      Gardening Contest
    • Party Challenge
      Party Challenge
    62 Discussions
    KATJEH
    2 months ago
    Never, ever use compressed air to remove "fluff" from your machine. It will blow bits further into the machine where it can cause real damage. This is especially important with electronic machines. Never adjust the automatic tension on you machine, either. If you are having tension issues, try adjusting the bobbin tension or take it to an "open sewing" time at your local fabric or quilt shop and ask for help.
    Sew much for nakuru
    Question 3 months ago
    How to check if drive belts are too old or loose?
    DoloresR11
    Question 5 months ago
    I have been given a singer 348k or is it just 348? The needle position arm is moving side to side freely. I have done so much research on this machine but cannot find any information on this issue. Can somebody please help me?
    1 answer
    p_lericheDoloresR11
    Answer 4 months ago
    A Google search threw up this video:
    It seems that under the lid on the top you can insert one of a selection of cams for doing zigzag stitching and embroidery. Without a cam in at all I suspect the needle position arm might move sideways as you observe. Hopefully one or more cams came with the machine, or if not, you can set it to straight stitch if you don't need to do anything fancy.
    Haze4500
    Question 11 months ago on Step 8
    I had a jam in my machine (Singer 40S) Removed the bobbin case to remove material. All back together and now the needle hits the metal plate a out 3mm before the slot is aligned. How can that be corrected??
    1 answer
    p_lericheHaze4500
    Answer 11 months ago
    Not quite sure what this metal plate is. Is it part of the bobbin case, or the plate the foot presses down on? Could be that you haven't reassembled it quite right, or you have the needle incorrectly fitted. Or you might have put the timing out. Try looking at a selection of YouTube videos about threading and adjusting the timing and you may be able to see what's wrong. If not, post a photo of it as the needle is on the point of striking the plate, and it may be clearer. A picture is worth 1,000 words!
    FroukjeF
    1 year ago
    Hi, thanks for the great instruction! Very happy to stumble upon it, since I just bought the exact same machine as shown above (except mine is called Combi and more roundish, but the rest the same). Do you have any idea what the brand is? Because I couldn't find anything on google.. and that might help with finding an instruction manual on it.
    I'm currently servicing it and with your instructions do the rest as well. Things are going better (it was sewing very slowly on high speed) and after cleaning the lower bits it's running already much faster and smoother. And on top of the motor casing there was a plastic screw with a spring in it. Do you have an idea if tightening this might have amped up the motor or something?
    p_lericheFroukjeF
    Reply 11 months ago
    I'm sorry, I've only just seen your question. No, I'm afraid I don't know what brand it is and I've never found anything online about my specific machine either. Mine was rebranded by a sewing machine shop in the small town where I live.
    Is there a second plastic screw with a spring directly opposite it on the other side of the motor, both of them at the same end of the motor as the wires? These hold the carbon brushes in place which carry the electric current to the rotor. They're not adjustments and should simply be tightened sufficiently not to work loose. The brushes eventually wear down and can be replaced, if you can find the exact same sort. Take a look at he Electric Motors page on the Restart Wiki.
    DeniseP73
    Question 11 months ago on Introduction
    Hi, we have a Reeds sewing machine. It will no longer go through several layers of fabric, breaks thread. We think something may have been bent - sewing pins or a needle. We have cleaned and oiled it and it still won't work correctly....Any suggestions? Or a repair place in MD that services these fine machines?
    1 answer
    p_lericheDeniseP73
    I think I give just a little more detail in the version on the Restart Wiki at https://therestartproject.org/wiki/Sewing_machines
    If you still can't fix it and it's an older machine with metal rather than plastic gears then it would probably be well worth searching online for a sewing machine repair specialist local to yourself to look at it for you. More modern machines wear out quite quickly and aren't easily repaired.
    chevyl2
    1 year ago
    Thank You. Great pictures and explaining. Helped me tons!
    p_lerichechevyl2
    Reply 1 year ago
    Glad you found it useful - happy sewing, and thanks for stopping by!
    AhmadF154
    1 year ago
    This blog is very good, I appreciate it, thanks to your writing, so I can spirit in writing in blog for better like you. I am from Indonesia greeting friendship
    p_lericheAhmadF154
    Reply 1 year ago
    Glad you liked it, and thanks for dropping by to say so!
    Bee Gianni
    2 years ago
    my Janome has been in its case for the last 10 years. I knew it needed service but I could not remember how. Your tutorial is fabulous and a service is in my near future. Thanks again.
    p_lericheBee Gianni
    Reply 2 years ago
    Glad you liked it, and thanks for stopping by to say so. Have fun!
    Kind regards - Philip
    RubenFerol
    3 years ago
    I have a problem with my wife's sewing machine. Can you help me with a link to a good forum?
    ShiseijiRubenFerol
    Reply 2 years ago
    On Yahoo (at least for now . . . )
    We Fix it is huge, a query will often lead to the answer you need. Can be off topic a lot but good people. Some of the other sites are very much "On-topic" moderated by a retired mechanic.
    Often the group files have A LOT of information that is well worth looking over before posting a question that's been asked 1,000 times before. Also links to some great "How to's"
    https://groups.yahoo.com/neo/groups/wefixit/conver...
    https://groups.yahoo.com/neo/groups/vintagejapanse...
    https://groups.yahoo.com/neo/groups/VintageSewingM...
    https://groups.yahoo.com/neo/groups/vintagesingers...
    https://groups.yahoo.com/neo/groups/singerslantsew...
    https://groups.yahoo.com/neo/groups/singermachines...
    https://groups.yahoo.com/neo/groups/sewingmachiner...
    https://groups.yahoo.com/neo/groups/VintageKenmore...
    Ron (with too many machines I'm trying to pare down).
    RubenFerolShiseiji
    Reply 2 years ago
    Thanks, but i just bought a new one this may. I still have the old one but i was considering to sell it for parts.
    ShiseijiRubenFerol
    Reply 2 years ago
    The posting will live for a long time, perhaps it will help someone else out.
