How to Solder Headers Straight
1,887
35
8
About: I make things, sometimes they brake
Showing how to use a breadboard to solder headers straight for any breakout board , microcontroller etc!
The basics is just to stick the headers onto the breadboard, place the module on top of the headers and finally solder the headers to the board.
Questions, Concerns, Compliments all welcomed:
@NemesisContrer8
Step 1: Gather Materials
Here is what will be needed:
-Soldering Iron
-Solder
-Breadboard
-Headers
-Board being soldered to
*Note the Arduino is NOT needed It's included in the picture because it's attached to the breadboard with an acrylic plate I laser cut.
Step 2: Stick the Headers Into a BreadBoard
Sticking the headers into a breadboard will force the headers to be stable and straight.
Next, align the holes of the board to the headers.
Step 3: Solder the Headers to the Board
Before soldering:
- tin the tip of the soldering iron so the solder glides on smoothly rather than staying on the soldering iron.
Then proceed to solder on the headers
Enjoy!
    • Arduino Contest 2019
    • Trash to Treasure
      Trash to Treasure
    • Tape Contest
      Tape Contest
    8 Discussions
    Shanjaq
    2 years ago
    just don't dwell too long, the breadboard plastic will melt!
    ohoilettShanjaq
    Reply 2 years ago
    If you keep your iron right above the solder's melting point and hold the iron on the pad for only a few seconds at a time you'll be fine. This is the way I solder all my headers. Now, if you were using a hot air gun, that would be a different story....
    droiddexter
    2 years ago
    thanks for sharing, I always struggle with Soldering these to breakout boards. Now I don't have to burn my fingers every time
    rafununu
    2 years ago
    A trick I use for ages.
    ceafin
    2 years ago
    o.O genius...
