How to Use Water Flow Sensor - Arduino Tutorial
145,978
446
27
About: Arduino Tutorials by Codebender.cc Team
In this tutorial you will learn how to use one water flow sensor with an Arduino board.
The water flow sensor consists of a plastic valve body, a water rotor and a hall-effect sensor. When the water flows through the rotor, rotor rolls and the speed of it changes with a different rate of flow. The hall-effect sensor outputs the corresponding pulse signal.
This type of sensor can be found on different diameters, water pressure (MPa) and flow rate (L/m) ranges. Make sure to select one that will cover your needs. The sensor that I have it has 20mm diameter, <1.75Mpa water pressure and ~30 L/m flow rate range.
In this tutorial we will use the serial monitor for printing the water flow rate in liters per hour and the total of liters flowed since starting.
So let's get started!
Step 1: What You Will Need
For this tutorial you will need:
  • Arduino uno
  • Water flow sensor
  • 3 breadboard cables
Step 2: The Circuit
The connections are pretty easy, see the above image with the breadboard circuit schematic.
Step 3: The Code
Here's the code, embedded using Codebender!
Try downloading the Codebender plugin and clicking on the "Run on Arduino" button to program your Arduino board with this sketch. And that's it, you've programmed your Arduino with this sketch!
You can keep playing with that by clicking the "Edit" button and start making your own modifications to the code. For example you can change in the line 58 the "1000" ms delay time.
Step 4: Serial Monitor
Press the connect button below to start the serial communication.
Connect your sensor with your water tap, or just blow on it.
Note: The back side of the sensor show with one arrow the correct flow side.
Step 5: Well Done!
You have successfully completed one more Arduino "How to" tutorial and you learned how to use the water flow sensor.
I hope you liked this, let me know in the comments.
There will be more of them, so make sure to click Follow button!
Find more useful Arduino Tutorials here
  • Arduino Contest 2019
  • Tape Contest
    Tape Contest
  • Trash to Treasure
    Trash to Treasure
27 Discussions
YousafK4
Question 6 days ago on Introduction
How i connect digital display to aurdino and water flow senser
Juliopasos
Question 7 weeks ago on Step 1
Great project. How can I connect 4 sensors to the same Arduino?
Veny_Vena
3 months ago
Hello,
Thanks for the knowledge shared. Well am curious about something concerning the flow rate sensor. I have studied it working principle and in brief the measurement starts when the propeller in it rotates by the passage of liquid. The question is what if there is air flowing and it is strong enough to make it rotate i hope the magnetic field will be generated and the same information as if liquid is passing will be sent to the hall effect sensor and proceed with the measurements. How is the flow rate sensor counter balancing that effect?...thank you in advance i hope to hear from you soon .
venancekafwenji95@gmail.com
Palant1r
Question 5 months ago
Hi,
I am looking at using this type of setup to keep track on how much beer is left in pint in a cask in my local club, any tips and help with the sketch would be of great help. I will have to include a reset button for when the barrel is changed and a over-ride switch for when the pipes are cleaned.
Thanks
Palant1r
nassersoltani
7 months ago
Hello my friend.
I plan to write a program to control the pressure of water with pi3 in the
node. I do not know how to install node.
I wrote a program to control the brightness and temperature with the Node Red.
This is to complete my project. .. Unfortunately, I do not have full
proficiency in English. Also, I can not write a command to do it. Please help me
MohammadA538
9 months ago on Step 5
Can i use this sensor as a gas flow measuring??
gd_
Question 9 months ago
How can I speed up the rate the data is showing up? Would changing the baud rate to 9600 be ok?
edca
2 years ago
I used this codes but it doesn't work accurately. I tested 1 liter of water to the sensor but the output became 2 Liters. What should I do? Thanks.
Abu Bakar Saeededca
Reply 1 year ago
You have to replaced 1000 by 800 to get accurate value, for more accuracy think there must be more little up and down required in 800 value
josmeijer1Abu Bakar Saeed
Reply 10 months ago
I rather think that the flow sensor you use is different from the one in the tutorial. Apparently it delivers 9 pulses per litre instead of the 4.5 from the example so I would change
float calibrationFactor = 4.5; to
float calibrationFactor = 9;
But I am still a complete noob on Arduino programming
(just logical thinking)
meach51
10 months ago on Step 5
Thank you for taking the time to write this up. As a physicist, I undertand Hall Effect, but the application and sample code for arduino really speeds things up!
FYI I am building a very complex project that involves boiling liquid, cooling flow, pumps and ethanol output ;) It is taking some time, which I have. People like you make the whole hobby so much more worthwhile, thanks again!
meach
shifashifu.24
Question 1 year ago on Introduction
How can find the leak in the area between two sensors?? What changes should me made with the code???
biplab15jrc
1 year ago
Hi,
I am very new with Arduino and also hobbyist, so i cant improvise codes.
I need to calculate velocity (cm/sec) of the water passing through a squire box, (5cm). (I attached a diagram.)
As we know 1cm cube area holds 1ml water; so box with WxHxL 5x5x1=25cm cube area hold 25ml water.
So calculation will be Velocity=((1000ml x Flow rate L/min)/25)/60=Velocity cm/sec.
Example: If water flowing 1 Lt/min ....then...
Velocity=((1000x1)/25)60=0.7cm/sec
If water flowing 8 Lt/min ....then...
Velocity=((1000x8)/25)60=5.3cm/sec
I need to include this calculation instead of Total volume (TotalMilliLiters),
Please help me.
Thanks
DiegoF3
2 years ago
Should I make any change in the code, other than the pin number, to use on pins 5 or 6? I can't make it work...
BenE19
2 years ago
I'm looking for something similar that can determine the water either going into or out of the hot water heater. Does this sensor have the proper diameter and will it impede the pressure of the water? Also can it work on the hot side of the water line?
WORMSS
2 years ago
What does the `frac` variable on line 85 supposed to do? I think I am being a derp and not following the code correctly.. Any help?
Also, nice little tutorial, I will try and find one that can easily fit a UK garden hose attachment to. I don't actually NEED it for my project, but I can use it as a confirmation that when I turn the valve on, it actually IS going on. May flash up some red LED's if things are not flowing as expected.. Thank you for the idea.
RFcontrolledSwitchWORMSS
Reply 2 years ago
frac doesn't appear anywhere in the sketch other than the declaration as an unsigned int so it must be some left over code from testing etc.
DougL2
2 years ago
nice project but with that plugin to show the code there is an advertisement at the bottom blocking that last bit of code from view. Maybe add a dozen or so CR lines to the bottom of the sketch so we can read it as posted.
pollux64DougL2
Reply 2 years ago
Insterrupt Service Routine
void pulseCounter()
// Increment the pulse counter
pulseCount++;
