How to Use XBee Modules As Transmitter & Receiver - Arduino Tutorial
85,332
58
19
About: Arduino Tutorials by Codebender.cc Team
In this tutorial we will use two xBee (series 1) modules with the Arduino uno board. We will configure them to act as a receiver and transmitter to control the brightness of an LED wirelessly by using one potentiometer.
The xBee - series 1 - modules take the 802.15.4 stack (the basis for Zigbee) and wrap it into a simple to use serial command set. These modules allow a very reliable and simple communication between micro controllers, computers or other systems by using just a serial port!
They can communicate up to 300 Ft (~100m), they have 2.4GHz frequency , use the 802.15.4 protocol and have data rate up to 250kbps. They have also a 1mW wire antenna on them. They supports Point to point and multi-point networks.
You can see the result of this tutorial on the below video :
So, let's get started!
Step 1: What You Will Need
For this tutorial you will need:
  • 2x Arduino uno boards
  • 2x xBee series 1 modules
  • 2x XBee Explorer Regulated boards
  • XBee Explorer USB
  • 220 Ohm resistor
  • potentiometer (e.g. 2k)
  • led
  • 2x breadboards
  • some breadboard cables
Step 2: XCTU - Setup Your XBee Modules
Download the XCTU software from here.
Run the program and connect the XBee Explorer USB board with your computer.
Click on the "Discover devices" icon to add your xBee in the XCTU software.
Now click on it (first image above) and set the CH field to e.g. "C" and the ID field to e.g. "1001". These values must be the same to all xBee modules to communicate with each other. Now as this xBee will be our transmitter, set the CE field as "Coordinator". If the baud rate isn't set to 9600bps, change it to this value.
Now click the "Write" button to save the changes in your xBee module.
Disconnect the xBee explorer board from your computer and connect the other xBee module on it.
Connect the explorer board with your computer again and follow the same procedure (second image above) but this time set the CE field as "End device".
Finally the configuration for our xBees must be:
For xBee transmitter:
  • CH: C
  • ID: 1001
  • CE: Coordinator
  • Baud rate: 9600 bps
For xBee receiver:
  • CH: C
  • ID: 1001
  • CE: End point
  • Baund rate: 9600 bps
Step 3: The Code
Here's the "xBee Transmitter" code, embedded using Codebender!
Try downloading the Codebender plugin and clicking on the "Run on Arduino" button to program your Arduino board with this sketch. And that's it, you've programmed your Arduino uno board with this sketch!
And here's the "xbee Receiver" code, connect the second Arduino uno board with your computer and press the "Run on Arduino " button.
Step 4: The Circuit
The connections are pretty easy, see the above image with the breadboard circuit schematics.
Power on both Arduino uno boards and try to fade the led by turning the potentiometer.
Step 5: Well Done!
You have successfully completed one more "How to" tutorial and you learned how to fade an LED wirelessly by using the xBee S1 modules.
I hope you liked this, let me know in the comments.
There will be more of them, so make sure to click Follow button!
  • Tape Contest
    Tape Contest
  • Trash to Treasure
    Trash to Treasure
  • Arduino Contest 2019
19 Discussions
EmdadulH2
Question 20 days ago
Can I made it using xBEE Series 2??
KartikB4
2 months ago
I am trying to transfer button pulse values for 9 buttons
100010010
Each digit giving the status of a button
Is this the right way or is there a better way of doing it?
How do I transfer these values?
SahlaS
Question 5 months ago on Step 5
Can a zigbee module act as transmitter and reciever at the same time?
ScienceTrip
Question 7 months ago on Step 1
Is it possible to have 2 transmitters talking to 1 receiver module?
engrshaukat
9 months ago
is it possible to connect multiple arduinos without master-salve configuration??
kurakulaanusha8
10 months ago
Hi
I am doing a project based on ZigBee on both the sides transmitter and receiver but m not using arduino instead of that m using micro controller so plz can u help me in coding
ThierryV
Question 11 months ago on Step 5
Hello,
I want to know if I can be able to understand by learning a zigbee thermostat and be able to send commands to it ?
Best regards and thanks for the post
PRAKASHS69
1 year ago
what shld be done in case of xbee s2c?
zeesh1979
1 year ago
is it possible to connect Zigbee directly to some sensor like temperature sensor? i was thinking to connect the sensor to RX of zigbee which will be sent wirlessly to other zigbee with arduino....is it possible or i always have to use an arduino on both ends?
HeruS24zeesh1979
Reply 1 year ago
I think, you should use the MCU to process the sensor data and then send it to the Xbee using TX port. But, when you find the sensor with TX port as output, we think you can directly connected with Xbee.
MuhammadI275
1 year ago
Does the receiver code have to use all three programs?
Hello friend, would there be a difference if S1 Pros were used instead of regular S1?
Gelfling6HemaA2
Reply 2 years ago
for the Series-1, it SHOULD be within the first page, as shown, at the bottom.. (step 2, of this instructable) at least for the S1 (series-1).. I can't remember (or find mine at this time) where exactly it is on the S2 versions in the set-up parameters. One radio, must be configured as a coordinator, and for S1's others are as End devices, and I believe S2's have a 3rd mode, Router, which relay signals to the end points.
Gelfling6Gelfling6
Reply 2 years ago
All else failes, You can return the device to Factory default (on the read, Write Restore, click Restore, then re-read the settings. it should be default (S1 & S2) as coordinator.
FahdA8
2 years ago
hi everyone
I want to ask about the Xbee
I want to send analog signal by Xbee and receiver the signal by arduino because i have ECG signal please i need help
123smile
2 years ago
Can i use the same procedure to transfer data?
xMarYx
2 years ago
Hi, Great tutorial.
I am doing something similar. Just one thing though, i cant seems to properly tweak the receiving coding to get another set of analog input to control another LED. I have 2 POT and 2 LED. One to control another
AndrewW180
3 years ago
Nice Job! Well done!
