How to Crochet a Ball or a Hackey Sack
Learn how to crochet a ball or a hackey sack.
I do the tutorial with fat yarn and a size N crochet hook for better visability. It is also a very good idea for beginners to start out with thicker yarn and a larger hook so they can practice before going down to the skinnier threads and crochet hooks.
The hackey sack can be made using the pattern I will provide here, 1 or more balls of #3 crochet thread, and a size 2 crochet hook.
Step 1: Make the Slip Knot.
Begin by making a slip knot (pics 1 - 4). Slide hook into loop formed by making slip knot.
Gently tighten the noose around the hook (pic 5).
Step 2: Chain 4.
Chain 4.
If necessary, refer to this video:
Step 3: Join With a Slip Stitch to Form a Ring.
Pinch the 4th chain from the hook between your Left thumb and forefinger (pic 1).
Insert hook (pics 2 & 3).
Draw up a loop and pull through the chain and the loop on the hook (pics 4 & 5).
Pic 6 is after the hook is through the chain and the loop.
Step 4: Begin Crocheting Into the Ring.
Round 1: Chain 1 (pic 2) and tuck tail to left of work. You will be working the tail into the crocheting as you go.
Keeping the tail to the left and on the outer area of ring, insert hook into center of the ring (as pictured in view 1). Draw up a loop and pull it through the ring(pic 3). There are now 2 loops on the hook (pic 4).
Draw up a loop and pull it through both loops on hook (pic 5); one single crochet in the ring complete. Make 5 more single crochet in the ring.
Here is Crocheting a Ball - Part 1 (movie)
Step 5: Begin Round 2 and 3.
Join with a slip stitch to the 1st single crochet (6 single crochet or 6sc).
Round 2: Chain 1. (Tip: Place a different colored piece of yarn before you do the next stitch.) Make 1 single crochet (sc) in the same stitch as the join. 2 sc in the next stitch (5 times). You will have 12 sc at the end of the round. Join with a slip stitch (sl) to the chain one spot.
Round 3: Chain 1. (Tip: Place a different colored piece of yarn before you do the next stitch.) 1 sc in same stitch as join. *1 sc in next stitch, 2 sc in next stitch. Repeat from * around to chain 1. Join with a sl to the chain one spot.
Crocheting a Ball - Part 2 (movie)
Step 6: Rounds 4, 5, 6, and 7.
Round 4: Chain 1. Place marker. 1 sc in same stitch as join. *1 sc in each of next 2 sts, 2 sc in next st. Repeat from * around to marker. Join with a sl to chain 1 spot.
round 5: Chain 1. Place marker. 1 sc in same st as join. *1 sc in each of next 3 sts, 2 sc in next st. Repeat from * around to marker. Join with a sl to chain 1 spot.
round 6: Chain 1 and place marker. 1 sc in each st all the way around to marker.
round 7: Remove marker from previous round and place in front of hook. 1 sc in each st all the way around to marker.
Step 7: Begin Decreasing and Finish Ball.
Round 8: remove marker from previous round and place in front of hook. *1 sc in each of next 3 sts, draw up loop in each of next 2 sts; draw up a loop and pull through 3 loops on hook. Repeat from * around to marker.
Round 9: remove marker from previous round and place in front of hook. *1 sc in each of next 2 sts, draw up loop in each of next 2 sts; draw up a loop and pull through 3 loops on hook. Repeat from * around to marker.
Stuff your ball with whatever your heart's desire, just so long as it's not going to fall out.
Round 10: remove marker and place in front of hook. *Draw up a loop in each of next 2 sts; draw up a loop and pull through 3 loops on hook. Repeat from * around to marker.
Final round: remove marker. Draw up a loop in each of next 2 sts; draw up a loop and pull through 3 loops on hook (twice). Weave in ends using crochet hook.
Crocheting a Ball - Part 3 (movie)
Enjoy your ball.
Step 8: Hackey Sack Instructions
Chain 4 and join with sl to form a ring.
Round 5: Chain 1. Place marker. 1 sc in same st as join. *1 sc in each of next 3 sts, 2 sc in next st. Repeat from * around to marker. Join with a sl to chain 1 spot.
Round 6: Chain 1. Place marker. 1 sc in same st as join. *1 sc in each of next 4 sts, 2 sc in next st. Repeat from * around to marker. Join with a sl to chain 1 spot.
Round 7: Chain 1. Place marker. 1 sc in same st as join. *1 sc in each of next 5 sts, 2 sc in next st. Repeat from * around to marker. Join with a sl to chain 1 spot.
Round 8: Chain 1. Place marker. 1 sc in same st as join. *1 sc in each of next 6 sts, 2 sc in next st. Repeat from * around to marker. Join with a sl to chain 1 spot.
Round 9 and middle of hackey sack: Chain 1 and place marker (you don't need it now, but if it makes you comfortable, use it). 1 sc in each st all the way around to marker. Keep making 1 sc in each st around until the ball is about 1-1/2 inches high when placed on a flat surface like a hat.
Round 10: Place marker in front of hook. *1 sc in each of next 6 sts; pull up a loop in next 2 sts; pull up loop and draw through 3 loops on hook. Repeat from * around to marker.
Round 11: Place marker in front of hook. *1 sc in each of next 5 sts; pull up a loop in next 2 sts; pull up loop and draw through 3 loops on hook. Repeat from * around to marker.
Round 12: Place marker in front of hook. *1 sc in each of next 4 sts; pull up a loop in next 2 sts; pull up loop and draw through 3 loops on hook. Repeat from * around to marker.
Stuff toe of thin sock with resin beads. Make sure they have enough freedom to move (sorta like a beanbag) and sew sock shut. Push into hackey sack.
Round 13: Place marker in front of hook. *1 sc in each of next 3 sts; pull up a loop in next 2 sts; pull up loop and draw through 3 loops on hook. Repeat from * around to marker.
Round 14: Place marker in front of hook. *1 sc in each of next 2 sts; pull up a loop in next 2 sts; pull up loop and draw through 3 loops on hook. Repeat from * around to marker.
Round 15: Place marker in front of hook. *Pull up a loop in next 2 sts; pull up loop and draw through 3 loops on hook. Repeat from * around to marker.
Final Round: Cut thread leaving a 12 inch tail. Draw thread through loop on hook and pull thread all the way through. Thread needle with tail and draw through final sts. Pull tight and weave in ends.
I will post the rest of the pics when I've finished the hackey sack.
TLMacD
    • Organization Contest
    • Paper Contest
      Paper Contest
    • Pie Contest
      Pie Contest
    24 Discussions
    Cool beans! I love it. I'm going to make myself a set for juggling...
    6 ball fountain, here I come!
    zoerainbows
    1 year ago
    amazing and I love how you also gave the instructions for the hacky sack
    1HorseGirl78
    6 years ago on Introduction
    ummmm not trying to be rude but the first chrochet class I went to the teacher said "have you ever chrocheted" I said "no...." she said" well then start with a very thin yarn and a size 4.00 hook"
    Every teacher differs in their teaching style. I've learned that teaching fat yarn and big hooks usually works much, much better than starting out small and thin.
    1HorseGirl78
    but i also just stuck my chrochet hook in backwards (lol) I still love it though 4 stars
    aguest1
    7 years ago on Step 7
    Hey, thanks for the tut! Im hoping to crochet a cover around a tennis ball -- do you have any thoughts on the best way to do this?
    Thanks!
    icewings2005
    8 years ago on Step 4
    IT IS HARD I DON'T GET IT HOW HOw how do i do it??? TT-TT
    I have been looking to learn crochet for ages...ever since I found the creepy cute crouchet book on Amazon. I have been practising the steps and re-watching the video until I got it perfect. Only problem is my "circle" isn't looking...well...very circular! Going to try with thicker wool. Thank you very much for your tutorial. Hope to be making super cute zombies in no time! x
    tldudenhoeffermartin8510
    Reply 10 years ago on Step 3
    Insert your hook into the very last chain (where it's being pinched by the thumb & forefinger). Yarn over the hook, draw through the chain and the loop on the hook. You will see a nice little ring formed. Let me know if you need more help. Leigh MacD
    I use just about anything I can get my hands on for stuffing the soft ball (read: fiberfil). For the hackey sack, you'll have to get pretty creative. I've used lentils, pea gravel, composite plastics, recycled old bean bags (they're usually filled with plastic junk). Basically, anything that will make it feel right. Check around at a hobby & craft store also. Leigh MacD
