How to Do Simple Paint Job for Airsoft Guns.
41,046
5
29
In this instructable, i will show how to do a simple airsoft paint job to use on your gun. I am using a cheap plastic mini auto in case i make a mistake.
Step 1: Materials
1 roll of thin masking tape
Spraypaint can(s)
Scissors
Newspaper
Step 2: Masking Tape
Mask off any areas that you do not want to be painted. Make sure to cover safety, tip of barrel, trigger, loading port, and any other functional spots. I chose a striped design
Step 3: Painting
Lay down newspaper so u dont get paint on the floor.
Spray paint in breif strokes, holding the can about 10 inches above the gun. Let dry for about 10-15mins if inside or 5-10mins if outside. Gently peel off the masking tape, and try not to scratch the paint. The pain becomes more scratch resistant in about 2 days.
Step 4: Finished
Congradulations, you have just spray painted you airsoft gun. Choose different colors as you please. Dark reds, browns greens, tans, and blacks make the perfect camo for woodland, i chose silver because it was all i had at the time. Please comment, i can change some steps and answer questions. This was my first instructable. Picture 4 is my paintjob for my AEG, enjoy.
P.S. To add a worn look, use sandpaper and rub off the paint on corners, edges, and on the base.
    • IoT Challenge
      IoT Challenge
    • Fandom Contest
      Fandom Contest
    • Arduino Contest 2019
    29 Discussions
    EpicMinecrafter870
    2 years ago
    Finally I can at least make my crap AEG look good...
    h8864
    7 years ago on Step 4
    you rifle is not legal. Remember Kids only you can stop people from painting orange tips.
    Capt. Kiddh8864
    Reply 7 years ago on Step 4
    If you look real close, you can see that he taped the orange tip and so didn't paint it. He also added a label to it in the diagram where he taped the stripes.
    Not to revive a old post, but that is done to keep paint from going INSIDE THE BARREL! You don't want to screw your accuracy
    crazyblade1209h8864
    Reply 4 years ago
    You are entirely wrong. The orange tip is only required for SALES from stores. In fact on higher end aegs they are removable and black ( or other color) flashhiders can be purchased.
    shorts5555
    4 years ago
    I just painted my gun and instead of using masking tape, I made a paper stencil by folding an a4 in half and tearing out a strip in the middle then spraying diagonal lines. Looks much more camouflage-y and better than simply masking tape.
    zap89
    8 years ago on Step 4
    your gun is more of a fail then my m83b2
    Jonnyboy46
    11 years ago on Step 4
    I just painted my gun(which I really liked a lot) but the paint is already wearing off. I am really dissapointed. Is there any coat to put on top. It is ultra flat paint so a gloss coat wouldnt make sense.
    IshukoneJonnyboy46
    Reply 10 years ago on Step 4
    Well after you apply the paint and have the desired effect. add a layer of spray polyurethane, which creates a invisible layer protective finish. that should last you for a year or so.
    bitch hunterJonnyboy46
    well by sanding the gun b4 the paint and then letting it dry in a warm and dry area it should stay on longer
    Jonnyboy46bitch hunter
    I did sand it, and i let it dry outside, in sacramento. I did find the answer to my question. It is a flat top coat. But even that is wearing. Im about to buy some army tape and wrap the crap out of the spots that wear.
    KaelessinJonnyboy46
    well that certainly will work but if you do still want a good paint job then i'd reccomend springing for some "krylon fusion" paints . . .they're chemically engineered to bind with plastics and they have official (albeit u.s. )cammo colors available. No primer is needed . . .though if your surface is particularly shiny then a sanding with high grit(ie fine) sandpaper would be a good idea. I've used the stuff and it's sheer brilliance! I will let you in on a secret though . . .it's expensive( :( ) depending on where you get it. Make sure you shop around first. I've found that walmart has it for the least around where I live.
    KaelessinPumpkin$
    nothing really unless you wanted to paint your rifle with the official cammo pattern and colors . . .
