How to Draw an Eye (updated)
982,250
231
89
I love to draw, and one of the hardest things for me to draw is facial features, like an eye.
This is a tutorial on how to draw the eye below. It is fairly simple but may take a few tries to get right, so keep trying!
 You will need:
2 Different kinds of pencils. A dark 6B or 8B, and a lighter HB
An eraser
Paper
flat surface, like a table or clipboard to draw on.
Also, dont forget to rate!
Step 1: Outline
Okay, to start, draw the basic almond-shaped outline of the eye. Try to make the inner corner (next to the nose) lower than the outer corner. P.S, I'm very sorry the pictures hard to see, my scanner made it very light.
Step 2: Inner Circle
Now draw the inner circle of the eye.
Step 3: Pupil and Highlight
Draw the highlight first, then the pupil under it. Make sure the pupil is in the center of the circle.
Step 4: Fill in the Pupil
Use your dark 6B or 8B to fill it in. You want it as close to black as possible.
Step 5: Upper and Lower Eyelid
Draw the crease of the upper eyelid, and the bottom one too. I'm not sure if its called the lower eyelid, but its the line under the eye.
Step 6: Begin Drawing the Eyelashes
Draw a few eyelashes to show  where you will later draw in larger clumps of lashes. Kinda like a basic outline. Sort of.
Step 7: Darken a Few Things Up
Darken the inner circle in the eye, the outline of the eye, and draw a line in the inner corner (as showed in the picture)
Step 8: Lines and Lashes
Start filling in some more lashes, and add some lines inside the inner circle of the eye.
Step 9: Lines Lines Lines
Fill in some more lines lightly inside the circle
Step 10: LINES LINES LINES LINES LINES
Add even more lines! But this time use the darker pencil to make darker lines.
Step 11: Adding Some Depth
Okay, shade in the inside outer edge of the inner circle of the eye ( yes, that is a lot of words ). Use the darker pencil. This will add a lot of depth and roundness to the eye.
Step 12: More Depth!!!!
Alright, do what you did in the last step to the pupil. Also, add some more lines (depending on the lightness of the color of the eye) to make it a little darker in some areas.
Step 13: LASHES!!!!!
Now, really fill in the lashes with your darker pencil. If drawing a male eye, make the lashes a little lighter than if drawing a female eye.  In this instance, I am drawing a female eye.
Step 14: Shading
Shade inside the eye, and it helps to smudge it with your finger tip or a tortilion. ( Hehe, I just realized how dark I shaded this eye, you can shade it a tad lighter than this.)
Step 15: Finishing Touches
Shade the corners of the eye, and the eyelids. YAY!!!!! your all done!!!!!!
202 People Made This Project!
  • Fandom Contest
    Fandom Contest
  • Classroom Science Contest
  • Woodworking Contest
    Woodworking Contest
89 Discussions
AshleeTea
4 weeks ago
really nice...at my school we also learn japanese. this probably seems pretty off topic of drawing an eye but were giving a project where we must draw a picture of the kanji character. kanji is like a letter in japanese that means a word here. i got “me” which means eye. i have been looking for a good eye but have failed tons. then i found this one! thanks, Ashley
Leahh1234
23 days ago
How do you draw a eye that is 3D
Pooja216
24 days ago
How's it?
sbowman7
7 years ago on Introduction
I think it could use more work, or updated because I see you said you did this when you were twelve in the comments. I'd like to see how much you improved :) When I was twelve I couldn't even draw a heart or square right, I really got into drawing just last year when I was 14 (I'm going to be 16 next month) this is still good for the age when you made it :)
KarenB375got2betoast
Reply 1 year ago
where? I couldn’t find the updated pic. You’re 19 now?
Mine came out too long, more stretched
carolyn_chung04
1 year ago
I drew Tel-Annas from Arena of Valor in her Valentine's skin and the eyes definitely helped me! Please give me some feedback on my drawing :)
Iivã
Question 2 months ago on Step 6
Thank you for this! Now i Can draw an eye
Pandamexic
4 months ago on Step 15
when coloring this in how would u suggest i shade
