How to Dress Warm in the COLD (Snow)...
220,512
24
13
About: I think it's fun to shoot guns & build things. Also, I love to play football, baseball, and basketball. I play the piano and I like to build electronics.
This is an Instructable involving basic heat principles.
In this instructable, I will show you the basics of dressing warm...
P.S. This instructable is in the Stay Warm Contest, so do your part... Vote!
Step 1: The Problem
In the cold weather, your body is always losing moisture.
Even if you aren't sweating, you are still losing moisture...
Example - Do you ever see your breath in the cold weather? That's losing moisture.
Step 2: The Solution: Part 1
In this step I will show you the different types of fabric to stay "warm":
Wool:
Wool can keep you warm even when it is damp.
It can feel scratchy to some people.
If you are one of those people I advise you to were a lite tee shirt underneath.
Cotton:
Cotton is good for warm, dry weather.
Once wet, it will NOT keep you warm at all...
That can be very dangerous if you're in a survival situation.
Synthetic:
Many synthetic fabrics offer the comfort of cotton with the warmth of wool.
Clothing made of polypropylene, polar fleece, and other modern materials can insulate you whether it is wet or dry.
Look for these for these fabrics in:
long underwear,
sweaters,
vests,
parkas,
gloves,
and hats...
Step 3: The Solution: Part 2
The first thing you should know about dressing in the winter is - layers!
Your first layer of clothing should consist of:
long underwear (Long Johns),
A Spandex material shirt (Under Armor, Champion Gear),
And Some good socks (Smart Wool, Wigwam).
After you have dressed yourself by following these basic guidelines,
head to the next step!
Step 4: The Solution: Part 3
Next, is the second layer.
This layer should protect you from wind, snow, even some rain...
This layer should consist of:
A Fleece or other light jacket,
A pair of non-cotton pants,
And a WARM hat (fleece).
Also:
A light windbreaker (gore-tex),
Some warm (fleece) gloves,
If your are Going in the snow (sledding, skiing),
You will probably need to switch out your blue jeans for snow pants...
Step 5: Rain Gear
In this step I will go into a little depth of rain gear.
There are two categories:
Non-breathable:
Coated nylon and plastic are used to make many ponchos, rain parkas, and gaiters.
The advantages of are that these items are waterproof and very cheap.
The downside is that moisture given of by your body can be trapped inside, causing you to feel damp and chilled.
And Breathable:
Some fabrics will keep rain out, but let body moisture escape - the ideal combo.
The downside to this is that breathable rain gear is often expensive...
Step 6: User Tips
As you may have seen in some of my previous Instructables. I often dedicate a step to user thoughts, ideas, and tips.
That is what I am doing here.
So if you have a tip or trick about dressing in cold weather post a comment; and it might just end up here.
Comments:
jdege says:
Venting is critical. You need clothes that will block wind, and will keep you warm, but you need clothes that you can open up so as to rid yourself of excess heat.
Moisture is the threat, and sweat is the enemy. Goretex and other vapor-permeable fabrics have their place, but when you start doing real work in the cold, you'll need to dump heat and moisture faster than they can manage.
Temp says:
Kotton Kills!! (cotton) Once it gets wet it will continue to stay wet and NOT insulate you. Wool will let you live like a wooly mammoth(I just made that up) It is very warm and even if it gets wet it will always keep you warm! Don't wear any cotton! It really does stink.
Step 7: Go Outside!
The final step - shoes...
Depending on where you're going, I recommend - Tennis Shoes or sneakers for the city.
Or Boots for the outdoors-men/hiker.
After you have put on your shoes, it's ------------------ Task Accomplished, You're WARM !
Referrers: Google, and the Boy Scout Handbook...
    • Tape Contest
      Tape Contest
    • Trash to Treasure
      Trash to Treasure
    • Arduino Contest 2019
    13 Discussions
    AvaW5
    6 months ago
    Thank you so much for this post. I am from Florida and am moving to North of England next year. I'm excited yet terrified of the cold weather as I know I will not be prepared, even with your tips. However, this does make me feel more confident that I won't be miserable and freeze to death.
    blackwoods
    Question 7 months ago
    Will spraying waterproof spray on the shoes help to keep out the cold?
    Grant.H
    6 years ago on Introduction
    you can also put plastic bags on your feet then put on your shoes/boots, this will keep your feet from getting all wet from slush and water, the down side is it will keep in the moister from sweat.
    dustybacon
    9 years ago on Step 6
    Fire vs. Synthetic Fabrics. Sometimes in the cold you end up near a fire for warmth. Synthetic fabrics, if exposed to heat or open flame will melt and can actually catch on fire themselves. Be aware of this fact! I ultimately gravitate towards wool, felt, animal furs (such as alpaca), and leather. These are natural fabrics that can all keep you very warm.
    abadfart
    9 years ago on Introduction
    nice i wear synthetic long under where with wool and a surplus water proof poncho
    froldt
    10 years ago on Introduction
    I'm currently studying abroad in Ireland (from the US) and managed to pack for the whole semester in only one suitcase (and a carry-on bag). I did so by using most of the tips you provided here. All of my clothes are multi-use and can be layered. Just because I don't have on a bulky coat, doesn't mean that I'm cold. In fact, I found myself over-dressed the first couple of days! Great 'ible!
    temp
    Kotton Kills!! (cotton) Once it gets wet it will continue to stay wet and NOT insulate you. Wool will let you live like a wooly mammoth(I just made that up) It is very warm and even if it gets wet it will always keep you warm! Don't wear any cotton! It really does stink. No jeans whatsoever. They will ruin your day. But very good instructable.
    jdege
    Venting is critical. You need clothes that will block wind, and will keep you warm, but you need clothes that you can open up so as to rid yourself of excess heat. Moisture is the threat, and sweat is the enemy. Goretex and other vapor-permeable fabrics have their place, but when you start doing real work in the cold, you'll need to dump heat and moisture faster than they can manage.
