How to Edit Your Photos With GIMP
64,882
19
About: I like programming computer programs in Microsoft visual C# 2010/12 express. Make, Fix, and Tinker with electronics. Fix Vehicles, and Small Engines. Build with K'nex.
This is a tutorial for editing your photos in a program called GIMP. First you need to have the program, if you don't you can get it here: http://www.gimp.org/
Supplies:
Step 1: Open Up Your Project
When you have GIMP installed, open it up and click File>Open and then go to where you have your pictures and click it then click Open.
Step 2: Crop Your Image
NOTE: If you don't want your image cropped then skip this step.
Click on the "Toolbox - Tool Options" window and click the Rectangle Select, Then Select the part of your photo you want cropped, then click on Image>Crop to Selection and it will remove the part that is not selected.
Step 3: Change the Brightness
When you take your photos, sometimes it is too dark, this is where the Brightness-Contrast comes in.
Click on Colors>Brightness-Contrast. The brightness slider makes it Brighter/Darker and the Contrast slider makes the colors show more if you move it towards the direction of the brightness slider.
Step 4: Export Your Files
When you are done editing your image, click on File>Export and then click on the file you edited, then click Export,
NOTE: You don't save your file because if you do it will say that you can only use "save" for saving it in a GIMP File Format.
Step 5: Compare the Difference
This is the difference between when i started doing it and when i finished.
There is a large difference.
  • IoT Challenge
    IoT Challenge
  • Classroom Science Contest
  • Woodworking Contest
    Woodworking Contest
3 Discussions
YanHri
2 years ago
Have you tried anything else?
dozer789
6 years ago on Introduction
In case anyone is wondering what the thing that i edited is, it is my Knex Fly that you can find how to make in my profile.
