How to Make Clay Lanterns
52,475
370
36
About: I like sewing and crafts,and trying new things. I'm vegetarian and always looking for new recipes. My cat's name is Mirko and likes to be in the centre of things, so you will see him in several of my instr...
I am not sure if that is the best name to describe this, but it is basically a cup made from air-dry clay in which you can place a tealight or small candle.  I made an impression on the sides of the cup and then poked small holes in the clay allowing the light to pass through.  I saw something similar done with a tin can and really liked how it looked.  The candle light through the holes is subtle and the design impressed onto the clay looks nice even in daylight.
Supplies:
Step 1: What You Will Need:
  • clay -any kind* or colour (I used La Doll Premier Lightweight Stone Clay)
  • clay rolling and cutting tools and a mat to work on
  • stamp, stencils or anything else you want to make an impression (Sculptey has texture making sheets and wheels)
  • cling wrap (to protect mat)
  • bottle the size and shape you want for your lantern
  • sandpaper
  • needle
*check that the clay is not flammable (Crayola air-dry clay is and it warns against using it for making candle holders)
Step 2: Roll Out the Clay
  • Take a hunk of clay and roll it out to about 0.5cm(1/4 in) thickness.
  • Cut the top and bottom edges in a straight line with the desired height (in my case I made it about 9cm(3.5in)).
  • Check that it is long enough by loosely wrapping it around the bottle and trim the edge.
Step 3: Make an Impression
I used a Christmas ornament to make an impression on the clay, stamps work nicely for this too.  Or if you have a steady hand you can draw something yourself.  Try to add even pressure and don't push too hard that it goes through to the other side.  I made the cup large enough that I could make two impressions of the dove.
Step 4: Poke Holes
With a needle or something with a pointy end (I actually used a seam ripper) poke holes all the way through the clay along the pattern you made with the impression.  Space them roughly 2mm apart and make sure the needle enters the clay vertically, not at an angle.  I also used a stencil to add more holes since some areas looked a bit bare.
Step 5: Make a Cup
  • Loosely wrap the clay around the bottle and connect the two ends together.  With the clay I used I just wet the clay and blended the edges together.
  • To make the bottom, roll out some more clay to about the same thickness as the sides.  Place the cylinder piece on top and trim around the edges.
  • Connect the bottom piece by blending the edges of clay together.
  • Allow to dry
Step 6: Sand and Finish
Once the clay has dried you can sand it to smooth out the edges at the rim as well as along the seams.
Drop a tealight in and our done!
Play with Clay Challenge
Finalist in the
DIY Wedding Challenge
Finalist in the
    • Classroom Science Contest
    • Woodworking Contest
      Woodworking Contest
    • Arduino Contest 2019
    36 Discussions
    fonzuzu
    7 years ago on Introduction
    Hers'e the one I made, sorry it took a while to post.I know it's abit messy but I made these lines on it with the pencil, I 'm sure if you do it properly it will be really cute.
    zposner
    2 years ago
    Good idea to check to make sure it isn't flammable. I wouldn't have thought about that.
    Betherga
    3 years ago
    Love this idea!! I will make one and post the photo!! Great idea and tips!
    Thanks
    Mareene
    3 years ago
    Thanks for this instructable! It's really nice looking and easy to do.
    I made one too but I'm not that pleased with the result. The holes are too big... I'll try another one with smaller holes! ^.^
    AddienSpeed
    4 years ago
    where did u buy the white clay? i almost made it but the clay color is brown... :(
    ChrysNAddienSpeed
    Reply 4 years ago on Introduction
    I bought the clay at Michaels. You can also find it on Amazon (http://www.amazon.com/Activa-Premier-Lightweight-Stone-28-Ounce/dp/B002VR0C26). You can always make it with the brown clay and paint it. Or just leave it brown, it may look nice too.
    Master Beorn
    7 years ago on Step 6
    You might try dimpling the bottom a touch and installing a small electric light as well. This also works VERY well with porcelain.
    tjesse
    A pounce wheel could speed things up. Check out my watermelon frog instructable for an example. This project would make a great mother's day gift!
    LifeWarrior
    Very sharp use of stenciling, I've never been good at clay sculpting, but I'm always fascinated by the artistry of it, it's cool to see an actual technique in action. Great 'ible, Thanks
    kasengut
    You can make the base a little bigger with a rim, into which the cylinder can fit, - and don't connect the base and the cylinder. That way you can place the tealight on the base and cover with the cylinder, - you don't have to drop the light in !
    Nice work !
    ChrysNkasengut
    Reply 7 years ago on Step 6
    Great idea, it is a bit awkward putting the candle in, thanks!
