How to Make Electroluminescent (EL) Paint!!
89,374
671
65
About: I love making things, so naturally this website is amazing! Mainly I love lighting and nearly everything to do with lighting and making relaxing spaces,
I first came across EL Paint when researching how to make my own EL Panels. Lighting is something I really love and the applications for this type of lighting are endless!
This is my first instructable, it's also very long - so apologies for that.
****I must warn everyone of the following before you begin****
- Ensure you read ALL safety directions and the MSDS (Material Safety Data Sheet) for each chemical prior to using it,
- This project deals with high voltage AC, it's very easy to electrocute yourself if you do not seal the circuits prior to applying power!
- Ensure you use all PPE (Personal Protective Equipment) when handling the paints and chemicals, and
- Store all chemicals in a safe place, away from children.
Supplies:
Step 1: What You Need to Start!
Before you begin, have these things handy:
1. Nitrile Gloves: They can be expensive, but are resistant to a fair amount of chemicals.
2. Particulate Mask: You need these!!! (or equivalent) - the powders in this project can be super fine ~10nm or smaller.
3. Eye protection
4. Emergency eye wash.
Please use this equipment!
This project is also VERY EXPENSIVE to get started. Fair warning ;)
This is a (non-exhaustive) list of basic equipment you will need:Prices are in $AUD
1. Heat Gun ~$60
2. Multimeter ~$10
3. Rotary Tool with stirring attachement (or something that can stir smal amounts of paint) - I used a rotary tool with milk frothing attachment ~$100
4. Paint Brushes x 5 smal to medium size. One for each type of additive plus spares ~$20
5. DC to AC Inverter - This is what drives your paint. These are cheap and come in many varieties and power outputs. I suggest using the battery power type while you get started - it's cheaper! ~$5
6. UV Blacklight - To see where you apply the phosphor layer ~$15
7. Glass jars (or equivalent) These are to store the paint once mixed with the additives. Any container with an airtight lid will work. ~$10
This is a list of the paint additives you will need - All ingredients can be substituted to suit your locations and suppliers, EXCEPT where it states "cannot be substituted" - this means that type of ingredient must be used.
1. Any clear coat polyurethane paint (water based is best). Must be a single stage/pack type of paint. Wood varnish is easiest to work with while starting out. ALL of your additives will be mixed with this paint. ~$50
2. Electroluminescent Phosphor - CANNOT BE SUBSTITUTED It costs ~$300/kg (this is true only for unecapsulated phoshpor, which is the cheapest). Do not confuse this with photoluminescent phosphor, that's glow-in-the dark powder and will not work.
3. Baruim Titanate (BaTiO3) CANNOT BE SUBSTITUTED - This is the Dielectric additive. It costs ~$80 for 250g.
4. a. Copper Paste/Paint - Cheapest and highly conductive, but messy and uneven to work with. Not transparent enought for the top layer, use for the base layer only. ~$70
b. PEDOT:PSS - Very expensive. Electrically conductive and transparent when applied properly. ~$700/kg
c. Silver Nano-Wires - Very expensive. Electrically conductive and transparent when applied properly. ~$990/kg
d. Double sided copper tape - Excellent for the base layer, cannot be used for the top layer. The glue can react porrly with the PEDOT:PSS though.
e. Any other conductive substrate for the base layer - such as aluminium sheeting (that can be sealed).
Step 2: Getting Started
** This instructable will only show you how to make your first EL Lamp on paper with a paint brush. Air Brushing/Spray painting and applying this to various substrates such as cars, textiles and wood are more complicated and will not be covered**
The 'functional' EL paint is made up from 5 seperate layers of paint with different additives dispersed within. The layers work together to produce light via electroluminescence. (This is a really basic description).
The layers are comprised of the following (from base to top coat):
1. Electrically conductive base layer
2. Dielectric layer
3. Phosphor Layer (electroluminescent)
4. Electrically conductive clear layer
5. Bus Bar
Using this basic construction, this system can be applied to anything from a car to your bedroom walls!
All-in-all, the EL paint comprises a number of layers to achieve luminescence. The following directions outline the components and manufacture of each layerfor a simple, single layer, single sided EL Paint application.
All steps from here are written using the following electrically conductive products:
PEDOT:PSS
Copper Paste
Copper Tape
Step 3: Base Conductive Layer
The base coat conductive layer is applied to the desired substrate - in this case, paper. I use the copper tape or paint to as my base layer.
1. Apply a thin, conformal coating of you electrically conductive paint or a layer of your copper tape, as shown in the picture, to the paper. *note: thickness should be no more than 1mm - (if the copper paint is not conformal, it will 'arc' electricity between the ridges in the paint and short circuit your lamp. The ridges also make it harder to insulate the base layer). If you use copper tape, make sure you smooth it out if needed.
2. This base layer should normally form the rough outline of your EL lit field (the area that lights up). You will need to extend a 'tail' out from the square you just painted - this is where the inverter will connect to the base layer.
The following is only applicable if you chose paint as your base layer - not copper tape.
3. Use your heat gun to gently dry the base layer and allow to cool.
** Ensure you don;t over heat the paint or it will boil and cracks will form. This breaks to continuity of the base layer, resulting in only partial illumination.**
4. Test the resistance of the base layer using your multimeter. You need to achieve a resitance of less than 1ohm over the entire area. The lamp may still work if the reistance is higher, however the light will not be even across the entire area. this is because as the voltage drops, so does the light.
Step 4: Apply the Insulator
Now we need to insulate the base layer from the phosphor layer and top electrode.
BaTiO3 to Varnish ratio is 19.1g of BaTio3 : 80.9g of Varnish
1. Check the base layer is dry...(if you used the paint)
2. Apply a thin coat of the Dielectric paint over the base layer.
3. Ensure that the Dielectric paint extends out, over the edges of the base layer. This ensures it is fully insulated.
4. Do not paint over the 'tail', this needs to have the inverter connected to it.
5. Use your heat gun to gently dry this layer and allow to cool. ** Ensure you don't over heat the paint or cracks will form and it will short circuit the base layer to the phosphor and top electrode layers**
6. Connect your multimeter to the 'tail' and then to the insulated area of the lamp. You should not get a reading - because we insulated it ;)
Step 5: Apply the Phosphor!
This is the fun part ;)
EL Phosphor to Varnish Ratio is 30g of Phosphor : 70g Varnish
1. Prior to applying the layer, you need to re-disperse the EL Phosphor into the varnish. It would have settled quite quickly to the bottom of your container. Use the rotary tool and the UV light to mix and check the dispersion as you go.
2. Check the Dielectric layer is dry....
3. Once suitable dispersed, brush the EL layer onto the Dielectric Layer.
4. Use the UV light to check you achieve an even dispersion across the lit field.
Step 6: Apply the Top Electrode Layer
Now we apply the top electrode layer. I used the PEDOT:PSS for this as it's transparent and conductive.
1. Ensure the EL layer is dry...
2. Apply the top electrode. Ensure you don't paint over the exposed base electrode layer!! or you will short circuit the panel.
3. Wait until this layer is completely dry before moving onto the next part. I suggest not using the heat gun for PEDOT:PSS. Let it air dry.
Step 7: Apply the Bus Bar
The bus bar ensures an even application of electricity around the whole of the lamp.
Make sure the bus bar is applied so that it touches the PEDOT:PSS - It will also help to place an additional layer of PEDOT:PSS over the bus bar.
Step 8: Light It Up!!
Let the paint dry completely for a while then apply power to your two exposed electrodes.
Step 9: Examples of What You Can Do Armed With the Basics.
First Time Author Contest
Runner Up in the
  • Arduino Contest 2019
  • Party Challenge
    Party Challenge
65 Discussions
slusserw
Question 3 months ago
Can someone link the DC to AC inverter you're using??
conundrum2142
4 months ago
To some extent you can also make some using silver gilding foil and an ultrasonic cleaner.
I made enough to test for another classified project but alas it didn't work.
(note: email me for the FOIA request number)
HydrochromeI
1 year ago
hello
how do we apply the PEDOT:PSS,
can we mix it with 1k varnish and if yes how much quantity to 100ml of varnish
TimmyGrayHydrochromeI
Reply 4 months ago
As outlined in the instructions, the PEDOT:PSS doesn't require mixing with anything. Just use as is. Apply with paint brush, air gun etc.
darnstadium
1 year ago
Hi, just a heads up, PLEASE BE CAREFUL! Some of the compounds available online aren't legal under REACH as of June 2017 so if you purchase them expect significant legal hassle. Notably, anything with Sb, Ba or other heavy metals, phosphors may contain Cd or other nasties especially if new old stock and contaminated/mixed. For now, Sb2SnO5 is legal but importing it without the appropriate paperwork may not be and if you get caught trying to evade the regulations it would be treated as seriously as importing Class B drugs.
TimmyGraydarnstadium
Reply 4 months ago
Thanks for the heads up. I live in Australia, However I have suppliers here that sell it to me. Agree with your comments about the Cadmium, Barium etc. I should have elaborated a bit more on this. They are toxic, especially the phosphors. The phosphors are essentially metal powders doped with another metal.
KeithB85
7 months ago on Introduction
am i correct to assume that you dont need the copper paint if youre painting onto metal and you just need the other steps?
TimmyGrayKeithB85
Reply 4 months ago
Technically that's correct. However you'll be applying high voltage AC to the metal, so it needs to be completely sealed. For example, you could pain a car body panel, but it needs sealing.
SolB7
Question 1 year ago on Step 6
What's the ratio varnish to PEDOT:PSS ?
I bought this product online but is very watery!
1 answer
FiveFootSeventeenSolB7
Answer 1 year ago
PEDOT:PSS comes mixed with water, you don't add any to the varnish but use it as it is. I would recommend you don't use a water based polyurethane like it says in the instructions. The water based polyurethane will mix with the PEDOT:PSS and ruin the conductivity of the material. Also you will need to add 5% DMSO to your PEDOT:PSS to achieve full conductivity. I got all my PEDOT:PSS from glowbug20 on ebay he's also given me a lot of advice. For anyone else reading this I'd recommend you buy his PEDOT:PSS Ink, the regular stuff can pool on top of the polyurethane and the ink is supposed to be much more manageable.
Alejandro Mata
2 years ago
Where and how can I get de PEDOT:PSS and Electroluminescent Phosphor? :D
Piratekustoms
2 years ago
Do you still check in on this page? Have some questions
Piratekustoms
2 years ago
Any leads on where to buynthe El phosphor here in the US? Been looking on line and all i am finding is over seas suppliers with large amounts only.
TimmyGrayPiratekustoms
Reply 2 years ago
Unfortunately I don't know any US based suppliers. The China based suppliers may be able to give you a smaller amount if you ask? Failing that, I can sell smaller amounts as well.
PiratekustomsTimmyGray
Reply 2 years ago
And any suggestions on the PEDOT:PSS? Or a little clearer idea on what should be bought? I looked online and seems to be a lot of choices and not clear which would be best. Also looked for ATO and that seems to be the same with many choices but not a clear idea of which to buy
Reply 2 years ago
Wow, for some reason 5 months later i got a notification you replied. Would be interested in getting a smaller amount. Email me at Piratekustoms@gmail.com if you still can sell smaller amounts.
Minhgioi
2 years ago
Eleclumi phospho not in viet nam.
DennisG19
2 years ago
It's back! I was so close to trying this but then didn't have the guts to try it without the article to reference.
Amro77
3 years ago
Hi All
need help
Any one can help I am . Azam, my team and I are interested to the pigment ingredient for the EL Paint to use for our research project in the Master’s Degree in Nanotechnology
Thanks and best regards
Azzam
azamtec82@hotmail.com
whatsapp Mobile 00201003434648
Onyx Ibex
3 years ago on Introduction
Very sweet. I was just looking into this the other day. I made Ag nanoparticles as an additive. They are much cheaper to make/use and fairly easy to make if you know what you are doing. Conductivity looks promising. Haven't bought any phosphors yet though. Will update when I do (eventually)!
