How to Make a Cloud Chamber (Cosmic Ray Detector)
12,151
184
24
6 year old Samatha shows how to build a Cloud Chamber (simple, elegant, & inexpensive Cosmic Ray Detector) at home and detect cosmic ray muons/electrons, and alpha particles.
Step 1: Tools to Build a Cloud Chamber
1. 99% Isopropyl alcohol
2. Dry-ice
3. Black Felt
4. Clear plastic cup
5. Play-Doh or Plasticine
6. Black metal plate/pan
7. Flash Light
8. 2 neodymium magnets
9. Styrofoam cooler lid
All these items are available in grocery stores ( Meijer or Walmart), otherwise you can buy them online (Amazon or ebay).
Step 2: Place Metal Plate on the Dryice
  • Take the Styrofoam cooler lid and put some dryice (solid CO2) on it.
  • Caution: Make sure that you wear insulated gloves when handling dryice (-109.3°F or -78.5°C)
  • Now place metal plate on the dryice and wait for few minutes until the surface becomes very cold
Step 3: Put a Piece of Felt Inside the Plastic Cup
Step 4: Put the Magnets Inside and Outside the Cup So the Felt Won't Fall Off
Step 5: Soak the Felt With Isopropyl Alcohol
Pour isopropyl alcohol in the cup, soak the felt well and if extra isopropyl is left in the cup just pour it on the dry-ice.
Caution: Wear safety goggles when you are using isotropy alcohol.
Step 6: Use Play-doh Around the Top Edge of the Cup
To avoid any leakage of the alcohol vapor between the cup and metal plate, use paly-doh.
Step 7: Invert the Plastic Cup on to the Metal Plate
  • Invert the plastic cup on the metal plate and press firmly so that plastic cup sticks to the plate.
  • If your play-doh becomes too dry after coming in contact with isopropyl alcohol then switch to plasticine.
Step 8: Focus Flashlight at the Base of the Cup
  • Wait for 2 or 3 minutes and you will see alcohol mist inside the cup due to temperature gradient between the top and the bottom of the plastic cup.
  • This implies more alcohol vapor at the top of the cup becomes super cooled by the time it gets to the bottom of the cup where the temperature is too low for the vapor to exist, this is known as super-saturated state.
  • When an electrically charged particle zips through the supersaturated alcohol vapor, it will ionize the vapor atoms by ripping off the electrons along its path. This will trigger the condensation process and we can see trail (thread of droplets = cloud) of the charged particle.
  • Focus flashlight at the bottom of the cup to see tracks of charged particles which pass through the super saturated alcohol vapor.
Image: University of Birmingham, http://www.ep.ph.bham.ac.uk/DiscoveringParticles/detection/cloud-chamber/
Step 9: Identifying Subatomic Particles in the Cloud Chamber
Different types of charged particles will leave different trails:
  • Thick small tracks are alpha particles (due to radon atoms in the atmosphere, not related to cosmic rays)
  • Thin and long tracks are muons (originating from cosmic rays)
  • Wiggly tracks are low energy electrons, wiggly because of multiple scattering
Safety & Precautions:
THIS EXPERIMENT SHOULD ONLY BE PERFORMED UNDER THE SUPERVISION OF AN ADULT.
1) Handling dry-ice with out proper gloves is very dangerous. Always use insulated gloves when handling dry ice. It is highly recommended that all dry ice handling should be done by an adult.
2) Wear safety goggles when you are using isotropy alcohol.
3) Wearing an insulated apron is highly recommended all through the experiment.
  • Fandom Contest
    Fandom Contest
  • Woodworking Contest
    Woodworking Contest
24 Discussions
KathyCeceri
3 years ago on Introduction
Do the magnets affect the experiment, or are they just to hold the felt on? I have made this with peel and stick black felt, no magnets.
Those two magnets are just to hold the felt on, initially we used peel and stick felt but when we soaked it with rubbing alcohol it used fall down from the cup, that is why we used magnets. And those magnets are not that powerful to change particles tracks direction.
Putting a powerful magnet on one side of the cup, we can identify particle and antiparticle by their track deflection, like electron and positron. But to deflect muon, we need very powerful magnet.
Ruby LaserKranthi Gunthoti
Reply 1 year ago
Really? To the best of my knowledge the magnets would ABSOLUTELY affect the experiment. This is because the particles you are detecting all have charges and ,as you may know, charged particles are affected by magnetic fields.
BuildingTheBest
3 years ago
Though you could make it more neater.
VincentZ3
something tells me when you grow up you will be important
kelseymh
Awesome project! Congratulations on getting an article on the MAKE Magazine blog (http://makezine.com/2015/06/22/watch-6-year-old-build-cloud-chamber-detect-cosmic-rays/).
brightled
3 years ago
I did this along time ago great work,also try to control the flight of the vapor trails using some magnets from an old hard drive....WCH
impied
This is awesome!!! The cloud chamber is one of my favorite exhibits at the Exploratorium in San Francisco and it would be so cool to have my own for on demand hypnotic viewing pleasure :) :)
Kiteman
Oh, very cool, well done (rather than photographing the tracks, video is better, because you can take screen-grabs of any moment you like).
sypher
3 years ago
How long does this last?
