How to Make a "chameleon" With Arduino
35,005
210
30
About: You either hate me or love me.
You must have seen chameleons changing colors and blending in the surroundings, in an amazing way. The way that chameleons actually do this is really molecular. If you look at the skin of a chameleon, you find that they have several layers of specialised cells called chromatophores and these are cells that can change colour. And that's where I came up with an idea of building a device that acts alike, with arduino.
Supplies:
Step 1: Intro
Hardware Used
TCS3200 Color Sensor from DFRobot, $7.90
Arduino Nano from DFRobot, $22.00
Light Disc with 7 SMD RGB LED, $8.90
Breadboard, x1
Jumper Cables, a few
Here I used Arduino Nano because I want the device to be as compact as possible with a low power consumption. However, if you do not have power or sizing requirements, any other Arduino microcontroller will just do the job —— and saves money.
Step 2: Wiring
To connect the TCS3200 Color Sensor with Nano, you'll need to expand some extra ports. The wirings should follow correctly with the program, to ensure functionality. Connect the LED port of color sensor with 3.3V on Nano. See attached wiring diagram for details.
Step 3: Programming
After all wirings done, you can now go to Arduino IDE and upload the codes for your chameleon. Note: the Metro Library is needed. You can find it here and install it in advance.
Here I leave a zip file with the the code.
Step 4: Test and Enjoy!
I used different colored papers to do demo tests. Just put the colored paper beneath the color sensor, and it starts to change color accordingly! Looks a bit more like a "chameleon" now :p
The sensor data will also be affected by ambient light, so it works better in the night.
The container I used is a printed vase found on Thingiverse, I am sure you will easily find a nicer one at home or made by your self.
Enjoy.
    • Arduino Contest 2019
    • IoT Challenge
      IoT Challenge
    • Classroom Science Contest
    30 Discussions
    aliasjanedoe
    3 years ago
    I'm also getting errors with the code. I do have Metro installed. Anybody ever find a solution to this? Thanks.
    ittakaaldinialiasjanedoe
    Reply 1 year ago
    Me too, I got this error when running the code (already install the metro library at arduino libraries folder)
    Arduino: 1.8.3 (Windows 8.1), Board: "Arduino/Genuino Uno"
    chameleon_code:3: error: no matching function for call to 'Metro::Metro(int, bool)'
    Metro ledlightup = Metro(60, true);
    D:\CODING\!Colorsensor\chameleon_code\chameleon_code.ino:3:34: note: candidates are:
    In file included from D:\\CODING\!Colorsensor\chameleon_code\chameleon_code.ino:1:0:
    C:\Program Files (x86)\Arduino\libraries\Metro/Metro.h:37:3: note: Metro::Metro(long unsigned int)
    Metro(unsigned long interval_millis);
    C:\Program Files (x86)\Arduino\libraries\Metro/Metro.h:37:3: note: candidate expects 1 argument, 2 provided
    C:\Program Files (x86)\Arduino\libraries\Metro/Metro.h:36:3: note: Metro::Metro()
    Metro();
    C:\Program Files (x86)\Arduino\libraries\Metro/Metro.h:36:3: note: candidate expects 0 arguments, 2 provided
    C:\Program Files (x86)\Arduino\libraries\Metro/Metro.h:32:7: note: constexpr Metro::Metro(const Metro&)
    class Metro
    C:\Program Files (x86)\Arduino\libraries\Metro/Metro.h:32:7: note: candidate expects 1 argument, 2 provided
    C:\Program Files (x86)\Arduino\libraries\Metro/Metro.h:32:7: note: constexpr Metro::Metro(Metro&&)
    chameleon_code:4: error: no matching function for call to 'Metro::Metro(int, bool)'
    Metro processdata = Metro(50, true);
    D:\CODING\!Colorsensor\chameleon_code\chameleon_code.ino:4:35: note: candidates are:
    In file included from D:\CODING\!Colorsensor\chameleon_code\chameleon_code.ino:1:0:
    Metro();
    class Metro
    chameleon_code:5: error: no matching function for call to 'Metro::Metro(int, bool)'
    Metro TcsTrigger = Metro(10, true);
    D:\CODING\!Colorsensor\chameleon_code\chameleon_code.ino:5:34: note: candidates are:
    Metro();
    class Metro
    exit status 1
    This report would have more information with
    "Show verbose output during compilation"
    option enabled in File -> Preferences.
    Anybody know how to solve this problem? In some forum, I found someone said that i have to use the modified metro libraries, but the author of this instructable use the library straight from the github page and i use the same library file. Any help will greatly appreciated, thankyou.
    oanhhoang
    2 years ago
    I get chameleon code.zip. but can not open code with winrar. every help me open code.zip
    fishhome
    4 years ago on Introduction
    hi mindminus,,
    A great project you got here.. i am new to using an arduino and when i tried this project i am facing a few errors even after i have the metro installed.. please could u have a look and let me know, i have uploaded a picture as well.. thanks
    KristinW1
    Hey, I have this thing all wired up but the code has quite a few error messages. Do you have an updated code? thanks!
    TommyO1
    Hi,
    I really want to use your example, since its perfect for a project I'm working on. Although I get this error message trying to use it.
    I downloaded Metro from this link:
    https://github.com/thomasfredericks/Metro-Arduino-...
    As I can find on the net, this lib might be modified. Can you post or link to the version of Metro you are using?
    Thx :-)
    carlos_bernal
    4 years ago
    Where's the zip file? Thanks
    yashara
    5 years ago on Introduction
    HI, I want to do this project but I'm having a difficulty buying the
    "Light Disc with 7 SMD RGB LED" but I have found an alternative
    component found on ebay http://www.ebay.ph/itm/Cyclic-RGBuino-Shield-V3-0-Arduino-Compatible-/270951123760?pt=LH_DefaultDomain_0&hash=item3f15f20b30
    yet I don't know if it'll work because I'm not into this profession.
    Also the code will be affected right? Will you please help me? Thank you so much!
    Gustaaf
    Hi, I am very enthusiastic about this project, but when I try to upload your code into my arduino micro, (Metro library installed) I get a number of metro related error messages. Can you please advce me what I do wrong?
    Gustaaf
    Hi, mindminus
    Could you please have a look at the error message I get?
    I would very much like to finish this project and I am curious about the result.
    Thank you.
    Gustaaf
    Hi,
    This is the image of the error message, I am sure I installed the Metro Library.
    If I compile and transfer Metro examples they work flawless.
    Kind regards
    HCHAVEZ05
    Hi nice Project!, i have some problems, can you help me? pls. at the moment to compile the code, the next errors are indicated.
