How to Make a Decorative Wedding Bow
35,147
47
This is a simple ribbon bow that can add a little flare to your wedding decorations!
Supplies:
-One roll(at least three yards) of wired edge ribbon
-Four inches of florist wire
-Scissors
Step 1: Make a Loop
Begin by making one loop with the ribbon. From the tail of the ribbon to the loop should be 7-8 inches.
Step 2: Continue Making Loops
Continue making loops that are 7-8 inches in length until you have at least 5 loops on either side. Cut the ribbon so that the remaining tail is facing the opposite direction of the beginning tail.
Step 3: Pinch
Pinch the center of the loops so that both sides are the same length.
Step 4: Wrap With Wire
Wrap the pinched center with your four inches of florist wire.
Step 5: Pull the Loops Apart
Pull the loops apart to make your bow. Twist the ribbon to get the desired result. Finish by pulling the tails out to make the tail of the bow.
    • Fandom Contest
      Fandom Contest
    • Woodworking Contest
      Woodworking Contest
    • Arduino Contest 2019
    2 Discussions
